#501 |
Shred The Shit
re: Backspacing and offset UPDATE!
So this has most likely been asked, but 10 pages is too much.
1992 S-10 2wd. I was looking to do a 3" drop and 15x10's in the rear and 15x7 in the front. I would like the wheels to line up with the body rather than stick out. What backspacing and what not would be required? Thanks -Chris |
#502 |
Senior Member
I went with 15x10 with a 5.5" BS and 15x8 with a 4.33" BS. I am going to run 275/60/15 & 235/60/15 with a 3/4 drop. I have not done this yet but it will be done in the next few weeks.
#503 |
Low Class
Just as mentioned above, this has probably been asked many times before but I too am way lazy to search 11 pages....
I want to run a set of 18" wheels on a bagged 2nd gen. What is my best choice to tuck this wheel? tire size? offset? backspace? Thanks...Josh |
#504 |
ok i have a question now. im still kinda confuzed on how the backspaceing and offset is. the rim that im look are looking at crager 397 series black soft 8
RIM: 15x7 Bolt: 5x4.75 |
#505 |
it going a 93 gmc jimmy 4x4
#506 |
found this nice little site with some good pics and a lil chart, hope it helps
http://www.streetdreams.org/tech.php |
#507 |
HUNG LOW
ok well im thinking about buying a set of cragar wheels and i didnt know the offset cuz they are on craigslist
i know they are 16x8 but that is it anyone know if they will fit??? i think the offset is 13 by the way i have a 2wd with a 4/5 drop extcab sonoma Last edited by sonomasweet-n-low : 11-12-2009 at 11:48 AM. |
#508 |
Re: Backspacing and offset UPDATE!
How's it going? I would like to kno w about two offsets for the s10.
20 x 9- 10 mm offset/ 20 x 9 15mm offset: The tires size is 254/ 35-20 and already purchased.. Which one is the better fit or are they about the same? Thanks in advance. |
#509 |
I am currently running the Boss 304's on my 1st gen. The fronts are 18x9.5" and the rears are 20x8.5". My problem is that the fronts are too wide (Rim rubs tie rods and shocks) and the rears aren't wide enough. I found a set of rims that are 18x8 for the front with a 4.5" bs and 20x10 for the rear with a 6.225" bs. Now from what I've been researching, it seems as though 6.225" bs is too much and will hit the inside of the frame, so I was thinking would they fit if I were to add a 1/4" spacer? Keep in mind that I plan on removing the inside lip of the rear wheel wells to create more clearance and also my 1st gen lays frame
#510 |
ok I am lost on this I bought a set of wheels that was supposedly for my s10 but turn out they are not here are the specs
17x8 bs: 6.5 I can get a set of adapters which I will need to make em fit anyway that are 1.25 width now with those adapters will these will work on a 2000 s10 please any help is greatly appreciated ![]() those are the wheels adapter link Last edited by dfl8tdsoon : 01-01-2010 at 09:37 PM. |
#511 |
hey guys i've read the post and from what i've read they wont fit but im wondering if i can convert my hub or something to get these to work.
the rims are 18x8.5 with 38mm offset. bolt pattern is 5x4.75. is there ANY way these can work cause i want them bad haha can i adapt anything or modify anything for it to work? my trucks lowered 5/7 first gen i think that you would need to know that part as well. thanks guys. |
#512 |
Offset: -12mm Backspacing: 5.00" Bolt Pattern: 5-475
Rec. Tire Size: 255/35-20 does anybody know if this 20x9 will tuck 1st gen on bags i think it will |
#513 |
ok guys need to make sure these wheels will fit on my truck...18x8 offset:2 and 20x8.5 offset:14 is it gunna work?
#514 |
I need help picking up some spacers for my S10. I have corvette wheels 17, 18 combo. Fronts are 5X4.75 and rears 5X4.50. I will be running 8.8 ford rear end.
What spacers should I be running? Last edited by V8Sonoma96 : 02-01-2010 at 09:59 PM. |
#515 |
where it all begann
hi guy´s! i´m running a 4 wd nowaday´s and there not many wheel´s/ rimms over here anyway .but i have issuies i wold like to x-change but how do i put in pictures so i can explain.4wd are sensitiv to bearings / expensiv too swedp
#516 |
where it all begann
bmw has a wide choise of rimms but centrumhole i don´t know, and i believe they are 5/120 sharp
#517 |
heres a pic that helps alot:
#518 |
hey i can get centerline wheels for a good price ... they were on a 86 vette
will i need spacers ... do you think they would just bolt up to my s10, it is 2wd i found that a 86 vette used 6 inch back spacing ... with 225/50/16 these wheels are 17inch what do i need to do ? thanks a lot jason Last edited by stillnotaplayer : 02-06-2010 at 03:50 PM. Reason: more info + |
#519 |
I have a 98 s10 2wd with a 4/5 drop. I found a set of wheel vintique smoothies they are 15"x6" for the fronts and 15"x8" for the rears. What would the correct backspacing/offset be so i get minimum rubbing? Also a good tire size suggestion for both front and rear would be nice too. I've read the info for both, but i want to get a few other opinions too while im at it.
#520 |
i have a 2001 s10 with a 2/3 drop spindles and leafs i am looking at 18 rims with 5x4.75 lug with 35 offset and hub bore 73 the rims are 8.5 wide can i fit these on my s10 and will i need wheel spacers plz help
#521 |
takes 2 balls in our game
I have a 2000 2wd truck with 17x11''s on the rear with 315-35-17's with 6 inch backspacing and fit fine WITHOUT spacers.
#522 |
I have a 95 s10 and i wanted to get a 15x10 wheel on the back, would a 4 1/4" rear spacing rim work? If not what spacing would I need and what size tire would work?
#523 |
With a 10 inch rim, I would use a 5inch backspacing, 4 14 might stick outside the bed
#524 |
Do you think I would need to cut out or alter any part of the bed?
#525 |
so I'm new to the whole s10 world, I'm used to having an import and you just have run a FWD offset and be done with it! I have a 91 2WD blazer and I am looking at getting 20 X 9 rims with a +10mm offset. I'm just wondering if these fill fit without any major issues. I will be bodydropping it next winter so
i want to make sure these wheels will work. |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f14/backspacing-and-offset-update-107156/
| took the blazer dragging over the weekend - ERMCA.com | This thread | Refback | 06-17-2007 03:45 PM | |
