Awsome tire size calc.
Location: Chester (Home of Popeye), IL User is: OffLine |
Re: Awsome tire size calc.
Dey took rrr jobs!!
R.I.P. Matt McCarville
*moved to Wheels and Tires.
Great find! |
I hate you
LOL, there are 25.4mm in an inch, so that makes 2.54cm in an inch. I think my math is right. |
Color Changin Member
Yeh 2.54cm = one inch.
I'm whipping one up in Excel.
Easy enough. |
Black SS
HAHA, a 3000 inch tire looks a little to big.
no more S10...
former owner
Those with pics are nice.
I like the one in my sig. No pics of the tires, but more info. like backspacing and it's effects on things, and effective gear ratios with different tires and such. Check it out (you have to scroll down past the wheels) |
wants a 2 door 98+ blazer
nice tools to use
me pique
I personaly used the one posted by powerhungrv8.
I prefer it beacuse you first put in your stock size and find a fitment close to stock. It also shows you how wide the tire is too. However the animated one is fun to play with. |
The " Dark MiniTrucker "
Location: Crestview, Hurlburt Fld FL User is: OffLine |
Hello there!
wrong thread.
Ole skule VW nut
Getting Layed
you know, they are cool to use...but the tire sizes are not correct. it says for 225/70/15 it is 27.1in. mine are only 26'' tall. for 245/40/18 it says 25.something. my buddy has that size and his tires are only 24'' tall. am i doing something wrong?
^^^^ A lot of it depends on brand of tire, air pressure, yadda yadda yadda. Plus you gotta remember on the truck and off the truck it will be different slightly because of the weight you are putting on them
sorry guys i dont really understand... if there is more than a 3% differnece in rim and tire size they wont fit my car.. or do i have to get a wheel alighnment or something... i just dont understand, can someone explain it to me.
Banned
#24 |
Banned
#25 |
#26 |
I Like Fire....HaHaHa
Curious if some one has an answer. I did the calculator for a 20" rear wheel on 35 series. The ones I have now are 16" with 40 series tires. Two things, it mention over 3% increase will increase possible brake failure. Any one have a problem with this? Also, it calculated speed say that with my stock ones @ 60 mph it would be 50 mph with the 20" wheels. Does that mean that when the speedo is reading 60mph I'll actually be going 50mph? Some one help explain this. Thanks
#27 |
back w/a s10
#28 |
i need some help to get my picture on here? s10 las vegas user name
#29 |
ok so maybe i am an idiot but trying all those i cant find the answer to what i am trying to do...
trying to go from 265/75 16s to ???/?? 20s want the same height but a lil bit wider not much this is on my f250 not an s10 so dont freak out.. |
#30 |
body droppin'
285/50/20 would work for you. the 265/75 16 is 31.64 inches and the 285/50/20 is 31.22
#31 |
So if your diameter diffrence is over 3% why is their a risk of brake failure. Also is there any way to correct for the speedo error or do you just live with it. I still use my stock wheel/tire for winter but use the newer ZQ8 235/55/16 in the summer. the diffrence is like 3.44%
#32 |
you can get a jet chip and correct the tire size when you reprogram, but idunno if its worth it if you are just using it for that.
#33 |
Glad you guys have found out Tire Calculator usefull. We get a tonne of traffic to our website fromyour post.
#34 |
Anything beyond a 3% change in ride height can cause ABS brake system faiilure, which is based off your stock ride height. Also it causes issues with vehicle computers, trip comp's, speedometer, gearing is off, and can lead to transmission failure as well. So they key is to keep it within that 3%.
#35 |
Drag Truck In Making
Location: Westwego, LA outside of New Orleans User is: OffLine |
Can anyone tell me what metric size tire I'd need for:
15''x8'' rim for 27'' tire height? Widest tire possible. Yes it's going on an 02' sonoma. |
#36 |
I think the biggest you would want to go is a 255/60R15. Allthough i'm not too sure if even that might rub when turning.
#37 |
Sorry to misconstrue. The 15''x8'' wheels will be on the back. I want the widest tires that will fit on the back of an 02' sonoma with 15x8 and 4'' backspacing.
HAVE: 15''x8'' rim WANT: Widest tire to fit on rear of truck with 27'' tire height |
#38 |
i just put in 64554 and it made the top left corner black make the rim size 165 |
#39 |
i pitty the fool!
when i thought about putting 15x8" on the back of mine i was going with 275/80 i think?
#40 |
ASASN8
here is one i found that i like alot. you can set the back spacing and it shows what the tire will look like on the rim. i will show you how much the tire will hang over the rim, how tall it will be, etc......
Wheel / tire size calculator / comparer - RIMS-N-TIRES |
#41 |
i pitty the fool!
i been using that one^ i love it! all the info you need
#42 |
does anyone know if '98 factory corvette wheels will rub on a '96 blazer?
front 245/45 R17 back 275/40 R18 |
#43 |
Banned
the calculator height is wrong
i have 235/55/16 it said 26.? and i measured and it said less than 25in |
#44 |
Can you fit 22" wheels on a stock Blazer Extreme?
#45 |
I Type Slow Too...
Eh... those other calculators are fun to play with but I like the 1010 calc the best still. I have been using that one for a long time. It is nice to just be able to look up the car's make and model and it will show you what size it came with from the factory, then you can compare 4 other sizes at the same time.
#46 |
Stepsider
#47 |
PHAT JOE
sweet
#48 |
Got Rice,No Really Im AZN
Location: Louisiana and Georgia is home but currently Turkey User is: OffLine |
Hehe...definately something to play with while Im on my 16 hour night shift!~
#49 |
#50 |
bowties in my bloodstream
So i think for my tire sizes, i decided on a 245/55/16 for the rear and 225/50/16 for the front. 9.5 wide in back and 8.5 wide in front. Thoughts?
