Anyone with BOSS 335s?
Old 10-28-2009, 09:32 AM   #1
mattclifford's Avatar
I know I've seen these on S-10s before, but as I was looking at the specs and noticed that the 20x8.5 has a bs of 5.671 and os of +25mm. Will these work on my truck? Am I going to need a pretty big spacer? Planning on running 245/35/20 tires.
Old 10-28-2009, 09:59 AM   #2
chaospartners's Avatar
Re: Anyone with BOSS 335s?
I got them on my 91. I just used a 1in adapter. the problem is if u dont use an adapter ur hub will stick out and wont allow the center cap to go on the front
Old 10-28-2009, 11:34 AM   #3
did you really need that big on an adapter? or could you have gotten away with a smaller one?
Old 10-28-2009, 02:07 PM   #4
on the front u do! on the rear u dont need nothing i just wanted my wheels to all sit out about the same so i used a set.
Old 10-28-2009, 11:45 PM   #5
Laying hard on zq8s!
colbye32's Avatar
looks like they stick out too far now..
more pics
Old 10-29-2009, 05:45 PM   #6
'00 Dime
alarm_the_alarm's Avatar
i dig that wheels. Clean and simple.
Also looks easy to clean
Old 10-29-2009, 05:46 PM   #7
pearl91chevy's Avatar
looks like it'll be a bitch to clear the fender if you lay it out
Old 10-29-2009, 05:49 PM   #8
pearldrop's Avatar
That would be a great wheel to use when bodydropped. My 20x8.5s with a +15 offset are just a little too far out for me. They barely clear the fender lips.
Old 10-29-2009, 05:52 PM   #9
Stock Height
slonlow2000's Avatar
If your running an adapter/spacer then an inch is as thin as you can go. If anyt thinner your stock lugs will stick out of the spacer causing interference with the wheels.
Old 10-29-2009, 07:19 PM   #10
'00 Dime
no.
I couldnt get my center caps on my front wheels and i was able to get 1/4 inch spacers that just slide on. It was all i needed to be able to put the center caps on.
The only prob with them is that they bend then there shot.
Old 10-29-2009, 11:46 PM   #11
OBS FSC
e3mcgrath's Avatar
i have nothing productive to add
Old 10-29-2009, 11:56 PM   #12
Knowledge is power.
s10pimpin209's Avatar
yup 1/4 spacer and your good
Old 10-30-2009, 02:27 AM   #13
<3 redheads
556mm's Avatar
OBS ftw!! new background.
Old 10-30-2009, 08:55 PM   #14
well u might be able to get away with 1/4 spacer on the 2nd gen but i know i needed atleast 1/2 in on mine so i just used 1in adapters.. And i try to get some pics soon its kinda a mess right now
Old 11-03-2009, 09:16 PM   #15
nice! thanks, that's all i needed to know. you have any more pics with those rims? that truck's hella clean.
Old 11-03-2009, 09:22 PM   #16
Knowledge is power.
yeah here are a couple. thanks its my buddys truck.
Old 11-03-2009, 09:56 PM   #17
It Is What It Is
Biglawrence44's Avatar
I would really love to see these on a Blazer..
Old 11-03-2009, 10:38 PM   #18
'00 Dime
iv seen um on a new escalade in 22s they looked tits. Clean and simple wheel cant beat it
Old 11-04-2009, 10:42 AM   #19
You meant the spacers here, right?
Page generated in 0.60996 seconds with 31 queries
[Output: 100.70 Kb. compressed to 92.99 Kb. by saving 7.71 Kb. (7.66%)]
