ABS & Parking Brake Lights On. Could use some help - Page 2 - S-10 Forum
post #51 of 106 Old 11-23-2011, 08:40 PM
User is: Metallifan9 is offline
Re: ABS & Parking Brake Lights On. Could use some help
Originally Posted by brandon2282 View Post
my brake and abs light would come on when it felt like it? (one day then not the other) took it to advanced auto parts and they told me to check the vaccum lines (mine were dryrotted to where you could here them sucking air ) they replaced them and installed them for me for under $2 and fixed it
when you pop the hood its in the top right hand corner by the dash its three lines put together by a connector
what year/engine is your s-10? mine is a 2000/4.3 and may be a little different than yours...
post #52 of 106 Old 12-04-2011, 02:13 PM
User is: Davidearlcox is offline
Since buying my 1996 S10 2.2l several months ago, the ABS light has always been on.
I took it to a brake service specialist to have the codes read. They quoted me $1350-$1400 to diagnose the problem. If I agreed to pay the diagnostic fee, they could then give me the total cost to repair, saying the scanner showed a bad ABS control module, numerous wiring failures and possibly bad wheel sensors.
Total BS. With help from this forum and an ohm meter, I found the front driver's side wheel sensor completely open and both front sensors damaged by abrasion from packed mud around the tone rings in the hubs.
Total cost to repair was $85.98 for the sensors, two cotter pins and about an hour of my time. This was an easy fix. Just sayin...
post #53 of 106 Old 01-04-2012, 01:13 PM
User is: rahjah is offline
Originally Posted by wavrun2000 View Post
Yeah mine does it to but not all the time. It is hit or miss, this makes me think that maybe it is just the hub on mine.
hey im new to the site it says your online but i just see very old posts. my name is austin. i have a 96 blazer s10 both my break lights are on. i think my power booster has been out for like 3 months and ive been driving on it. i think that because it was extremely hard to stop but it worked, & the pedal didnt go all the way to the floor. as of last night it does go to the floor and barely barely barely works at all. any suggestions where to start at all?????? please help
rahjah is offline
post #54 of 106 Old 01-04-2012, 04:42 PM
User is: Ed98 is offline
RAhjah,
Do you know anything about brakes?
I'd get all the codes pulled first. Have a pencil in hand and right them down as they are called out. Autozone will do it for free. Then tell us what the codes are if there are any. Otherwise we are just going to have to go over the entire brake system, which is why I asked can you do that? Change pads, take off rotors, look for leaks, etc.
I will tell you to check your vacuum hose and checkvalve on the front of the Booster, maybe you can get lucky and have a vacuum leak and just fiddling with the hose will fix it.
Does anyone know whether Autozone can pull the ABS codes?
Ed98 is offline
post #55 of 106 Old 01-06-2012, 01:00 AM
User is: sukivel is offline
My local autozone does not read ABS codes. Does anyone know what the front and rear sensors are supposed to Ohm out at?
sukivel is offline
post #56 of 106 Old 01-07-2012, 12:09 PM
WSS Temp vs Sensor Resistance (S-Pickup)
-40 to 40*F 3915 to 5820 ohms
41 to 110 4760 to 6800
111 to 200 5560 to 8040
201 to 302 6600 to 9406
(S-Utility and T-Truck)
Same temps as above:
920 to 1440 ohms
1125 to 1700
1305 to 2000
1530 to 2310
Ed98 is offline
post #57 of 106 Old 02-04-2012, 02:07 PM
User is: MikeS is offline
I have a 96 chevy blazer. The ABS light came on so i pulled the wheels and found the wire for the right front speed sensor was rubbing the wheel and wore down to the copper and shorted out. I fixed the wire with solder and heat shrink tubing. I then unhooked the battery for a few minutes to try to reset the light. The light stayed on so I took it to have the code read and reset, at Auto Zone. The code scanner came back with no code stored. Had them reset it anyway but the light is still on. The ABS is working, I can't make the wheels lock by braking hard. What can I do to shut the light off? Or could the shorted sensor have messed up something in the control module.
MikeS is offline
post #58 of 106 Old 02-04-2012, 03:14 PM
1996 4.3 5 speed xtra cab
tommyboys10's Avatar
User is: tommyboys10 is offline
you need a scanner that deals with abs codes and erases abs codes. Not a cheep one either, the scanner at auto zone and the likes usually erases typical cel codes, not abs codes. I had to go to a local automotive school that had one. Bought the tool guy lunch. Took him ten minutes.
1996 5.7 l31 S10 NV 3500 2wd extended cab
post #59 of 106 Old 02-06-2012, 02:56 PM
The AutoZone here does read abs codes. I had a problem a few months ago and they read the code for me. It turned out to be the rear speed sensor that time, and they reset it. The light went out until the drive home to fix it. After I put the new sensor in, the light went out. Are you saying that AutoZone's ABS code reader is cheap and can't read every code? I suspected operator error. I will try taking it somewhere else. How do you know if they are using a cheap or good scanner? Any other suggestions on where to take it? Most people I ask can't read abs codes.
MikeS is offline
post #60 of 106 Old 02-07-2012, 12:07 AM
snap on , their where keys involved too that where inserted into the harness to fit the diagnosis plug. Good luck!
post #61 of 106 Old 02-11-2012, 05:36 AM
User is: Wolfman_Swe is offline
Guys, just my two cents:
I have a '96 S10 that had similar problems:
ABS and brake lights on, no lockup and no Heater at all.
Turned out to be the relay (middle one of the three under the hood, pass. side, the one furthest to the left is for the fuelpump btw)
However: after replacing the relay and the fan started working, the abs and brake lights went out.
Then after a couple of weeks the ABS came back on, fan still working.
Checked the Fuse in dash, it was OK.
Gonna check the fuse under the hood and the wheel sensor wiring and the brake pads, i suspect the pads since the car wobbles slightly when braking..
post #62 of 106 Old 04-09-2012, 01:16 PM
User is: 70ChevelleRagtop is offline
I had a similar problem with the Brake Light and the ABS Light coming on randomly on my daughters 2000 S10 ZR2. After checking the wheel sensors and lines and replacing the vacum lines (including the one all the way back to the tailshaft of the transmission) the lights kept coming on. So, I checked the ground on the radiator support. It was badly corroded and the eyelete end actually popped off the wire as I was cleaning it. I soldered a new end on and cleaned up the connection and added dieletric grease. So far, after about 30 miles of driving, no more lights...fingers crossed this fixed it.
1998 S10 2wd 2.2 / Auto
1999 S10 2wd 2.2 / 5 spd
2000 S10 4wd ZR2
post #63 of 106 Old 06-24-2012, 09:33 PM
thesilverbullet's Avatar
User is: thesilverbullet is offline
tried the vacuum lines and still getting lights randomly. i'll check the ground wire next. thanks for the tip...
30+ yrs driving chevy trucks!
2007 Honda 07S2K, 2.2L 220HP, 155MPH TOP Speed
2003 S10 4.3L, Auto, 2wd, Z83, 3.42, Std Cab.
1999 S10 4x4 4.3L Auto, std Cab
1998 Sonoma 4.3L Auto, ext cab, lowrider
1991 S10 4.3L, 700R, 2wd, 3.42, Std Cab
1978 Chevy Luv, 1.8L Auto, 80HP, 86MPH top speed!
1972 Ford Van, 300 cu-in in-line 6cyl
post #64 of 106 Old 06-24-2012, 09:41 PM
Originally Posted by Wicked Mayhem View Post
my lights were on.. brakes always acted fine so im not worried about it. i just cut the traces to the dummy lights so they cant ever come back on.
nice LUV truck (looks like '79 / '80 model) - i drove my dad's through high school and college. it was a '78 2wd standard cab automatic "MICKADO" trim/package. we had to rebuild / replaced the tranny 3 or 4 times... the auto tranny was from GM and everything else was japan... after about 13 yrs of me driving it like is was stolen, i finally spun a rod bearing at ~120k hard miles.
post #65 of 106 Old 04-01-2013, 12:02 PM
User is: jtfitz23 is offline
ok, i have a 2000 blazer with the same problem. I do have a snap-on modis scanner that i'm able to use for diagnostics. I determined it was the VSS not giving a signal to the VCM. I replaced the VSS for about $60. Still doesnt work. checked all fuses and wiring. still No speedo reading have both abs and brake light on and the vehicle wont shift out of first while driving. I tested the wires that go from the blue 32 pin connection on the VCM to the VSS (Green/black & Purple /white) i have continuity on both. I also checked the VSS signal output wire (yellow/black) to the EBCM and i have continuity there too. BAD EBCM or VCM??? It worked fine just the other day. I had an issue with the control wire on the back of the VCM for the Evap vent solnoid and found a loose wire on the back of the white connector and repaired it. so i figured i bumped something, so, I checked all other wires for connectivity on all the connectors. all seem fine. Does anyone else have any tricks or know any secrets for fixing this?? did i miss anything??
jtfitz23 is offline
post #66 of 106 Old 04-03-2013, 10:04 PM
SSRT-S10
my_nightmare's Avatar
jtfitz23 - sounds like you have a cluster and or harness to cluster problem from what you described
Whomever:
Usually.., from what I have seen at work..., the ABS brake light being on with the brake light being on as well leads to the following:
Low brake fluid or nasty brake fluid in M/C (brake light only)
Speed Sensor (abs sensor at the XX wheel)
The speed sensor wiring
A bad hub/bearing assembly
EBCM module
Corroded fuse in Fuse block
Corroded wires/pins/connectors in fuse block to ebcm or abs or both..
or in worse case...the VCM or harness to VCM
Best way is to get use of a good diagnostic scanner and scan the abs system for codes in its history and pending codes. If it has more than 5 codes.., clear them all and drive the vehicle 10-20 miles - stopping every 5 miles and shutting down the vehicle - yes I mean shut it off. The restart and continue driving another 5 miles. The light most likely WILL come back on...
Rescan the ABS codes....
1) IF it has a bad wheel speed sensor/bad wiring to speed sensor.., it wont take long for that ABS light to come back on... - 1-3 miles or less. Sometimes putting it in reverse, then stopping and shutting it off and then recranking will make the light come back on if it is a speed sensor.
2) IF the EBCM module is going out/defective..., this will show up after the 12-15mile part... Usually the electronics part is the culprit... try it first.., if still no fix.., replace the entire module... bleed the entire system good... and use the scanner to bleed the module...
3) If the VCM is going out.., this could be a fast ABS light or a random ABS light - The mileage you put on it wont matter. Check all the connections and make sure ALL grounds are in good shape. Also check the harness for any broken connections.
I've run into corroded pins in the VCM, bad harnesses, broken wires, you name it..I almost have seen it happen to make a ABS light come on...
Also note: I've ran in to speed sensors that "Showed" the correct mv/ohms coming thru it and, yes, it was still a bad sensor. When hitting a bump or taking a hammer and tapping the rotor.., it would drop to ZERO and then magically restart back to the correct amount.
Hub bearing assemblys are the worse on this. I can guarrentee that usually every week I get 4 to 7 that has to be replaced. Lopping out $100.00 up to $500.00 per hub can get kinda costly to the customers. And I seen some that ppl let go till the stupid wheel fell off. It cost them over $1000.00 and up to fix what all was damaged by letting this happen.
post #67 of 106 Old 05-01-2013, 07:26 PM
User is: flatlands is offline
Here's my story: Went to Arizona for 4 months, came back to Kansas, charged my battery (+cable removed) overnight, started truck the next morning and that was the first time I ever had the ABS light lit (after starting). It's on all the time while the key is on. And it's only the ABS light, not the brake light or anything else. It's a 95 Sonoma 4.3 vin Z, front discs, rear drums. I've been to two places to scan for codes, but neither could connect to the ABS codes. I connected the 2 pins in the OBD connector and got a repeated 1-2 signal, meaning it was communicating, but no DTC codes.
I'm thinking it's the brake control module and it has the broken/cracked solder joints on the board. Haven't done any other troubleshooting at this point.
Any ideas or suggestions?? When the problem is ONLY abs light and it's on ALL THE TIME without ANY OTHER problems, what is the likely cause of this??
1995 Sonoma SLS extracab 4.3 TBI Auto completely stock
post #68 of 106 Old 05-01-2013, 08:14 PM
User is: Hellcat1 is offline
Sounds like your ABS controller took a dump. Try going to O'Reilly's and ask to use their Code scanner. They should have an Innova LAT3120. After it connects and scans DTC's, you can press the "DTC" button on the bottom left and choose to scan the ABS codes.
Hellcat1 is offline
post #69 of 106 Old 05-06-2013, 05:27 PM
ABS Problem FIXED
I fixed my problem. When I first had the problem, the truck had been sitting in the garage for 4 months. Came home, charged the battery, started the truck and the ABS light never went out. Since I hadn't used the brakes, hadn't moved the truck, my reasoning is that it MUST be the control module. There was no chance of a bad reading from any of the sensors because no movement of the truck.
So I took a chance, found a new GM ABS Brake Module GM# 88880026 (93-95 S10, GMC Jimmy) on ebay for about $93 delivered to the house. Removed the washer tank (one screw 10mm holds it in above the top of the tank against the fender - turn it sideways to get room to remove the screws holding the module), unplugged 2 plugs on the module, removed the screws, took out the old unit, installed the new unit, replaced the screws (remember where those 2 short ones go), replaced the plugs, re-attached the washer tank. Started the engine, abs light on - but just for a couple of seconds, then OUT like it was never on.
$93 isn't much more than the mail-it-in fixit places, and it's a new module, so I think it's a great investment. And by the way, I went to 3 national chains to have them scan my truck's computer and not one of them could get a reading. I did the terminal short method and got a consistent 1 - 2 reading which means the computer is communicating - but no other DTC codes were found.
post #70 of 106 Old 05-06-2013, 05:50 PM
O'Reilly's scanners can do ABS (Innova 3120LAT), but the counter monkey operating it probably didn't know how. That being said, if you were unable to communicate with the ABS controller, that might have been why you had an ABS light on in the first place.
I've been working at O'Reilly #779 in Spring, TX for over 4 years, and some of the stories I hear from customers about my colleagues from other stores and from other competitors stores baffles me. I don't understand how companies that sell auto parts will put people behind the counter that can barely look up a part, let alone tell you how it works or what kinds of symptoms it will cause when it fails.
Hellcat1 is offline
post #71 of 106 Old 05-15-2013, 09:34 AM
Captain DIY
D.T.'s Avatar
User is: D.T. is offline
My new to me Jimmy has been fine for two weeks and now all of the sudden both the ABS and brake lights are coming on!
Going to scan it now and see if I get a code.
I do have mis matched tires, but they are the same size numerically.
1997 GMC Jimmy 4 wd, 2 DR SLS, W engine, TP mod, snorkel removed - Smoky Caramel Metallic
RIP
New one!
2001 GMC Jimmy 4wd, 2 dr SLS Pewter Metallic
Quote: Originally Posted by yepitslow
Red bull gives you wings my ass!
D.T. is offline
post #72 of 106 Old 05-15-2013, 10:52 AM
Captain DIY
D.T.'s Avatar
Well, I just scanned and didn't see anything.
ABS and brake lights were NOT on the dash when I turned the key though.
So you need a special scanner for the brakes?
Looks like I need a C Chassis code scanner?
http://www.obd-codes.com/trouble_cod...ssis-codes.php
RIP
New one!
D.T. is offline
post #73 of 106 Old 05-15-2013, 11:39 PM
Very common when they are beginning to fail. The will intermittently be on or off when you start the vehicle. From what I understand there is a relay that fails inside the ABS controller.
Yes, you need a scanner that can talk to your ABS controller. Try going to O'Reilly's and ask to use their Code scanner. They should have an Innova 3120LAT. After it connects and scans DTC's, you can press the "DTC" button on the bottom left and choose to scan the ABS codes.
Hellcat1 is offline
post #74 of 106 Old 05-16-2013, 12:13 AM
A work in progress...
jasond's Avatar
User is: jasond is offline
I had the same problem with my 2000 blazer. I replaced the ebcm with a known good unit. Problem solved. There are some companies online that can repair your ebcm. There are solder joints on the circuit board that crack. I think it's www.modulemaster.com
jasond is offline
post #75 of 106 Old 05-16-2013, 12:40 AM
get over it....
Bad-S10's Avatar
User is: Bad-S10 is offline
im starting to have the same thing with mine 03, when I first turn it on in the morning its off, after driving awhile it comes on, but after stay off for couple hours that cools down a bit it goes off again and so on so forth...
2003 blazer 4 door 4x4 black. lowered 3/3 c6 wheels, ZQ8 Box, K&N CAI, HP Trans.Cooler, PCMPowerTunes, Magnaflow with no cats..
2000 s10 ls, (SOLD) n Missed...
2008 Chevy Aveo ls....( SOLD )...
Brasilian by Birth , Bostonian by Choice
follow me on instagram: @ Bad_S10
Bad-S10 is offline
post #76 of 106 Old 07-26-2013, 09:41 AM
Mr.
User is: Mr. is offline
Originally Posted by IMScorched View Post
I just stumbled upon a way to get those stupid lights to go out!! With the engine running, I turned the ignition key "Just A Little" toward the start position until the lights go out (My shift indicator, odometer, and clock also went out), release the key and it will recycle the entire light cycle again and GUESS WHAT!!,, the ABS and Brake Light went out!!! Be Careful NOT to turn the key all the way to the START Position. I decided to take it for a test drive to see if they would stay out, no such luck!! 25 yards down the road they came back on! While I was still moving, I repeated the above procedure, same results, the lights went out. I proceeded with my test drive. I ended up going almost 10 miles with no ABS or BRAKE Light glowing in my eyes!! This is the first time in about 10-12 months that those foolish things haven't been on!
What a pleasure that was!!!!! Not sure at this point if it will last... (Fingers Crossed) Hopefully this might shed some light on a new CAUSE to be investigated.. Maybe it recalibrates some sensor etc., I haven't a clue. Please post YOUR results as I am extremely curious whether this is a fix or just my S**t Luck..
My abs and brake also turns off when I jiggle the key when its running. My lights came on one day after I adjusted the rear drums.
Mr. is offline
post #77 of 106 Old 07-31-2013, 07:21 PM
User is: likaboss302 is offline
my 2000 blazer 4.3l is having the same brake problem both abs and parking and my check engine light is on says something about tranny but already put in a new solenoid and flushed fluids haven't checked hoses or ebcm or sensors
post #78 of 106 Old 10-12-2013, 10:08 AM
User is: tinman50 is offline
If you can solder you can probably do this fix yourself:
tinman50 is offline
post #79 of 106 Old 10-12-2013, 10:09 AM
or maybe these guys can help you out
http://www.myairbags.com/abs.php?gcl...FdBxQgodeWQAOQ
tinman50 is offline
post #80 of 106 Old 10-16-2013, 11:46 AM
User is: barnyardTERROR is offline
am I the only one here who disabled his ABS?
when in doubt, empty the magazine
post #81 of 106 Old 10-16-2013, 08:10 PM
Nope, I removed the controller from my 2001 about 2 years ago. I'm in the process of deleting it completely.
Hellcat1 is offline
post #82 of 106 Old 03-10-2014, 09:11 AM
User is: charlesfrance is offline
hello I have the same problèm with the ABS and brake lights comming somme times and I read lot of things and the ground could be one of the problem
is any body can explain ti me "very simply" because I am in France where is the ground undun the radiator as I don't find it
thanks
post #83 of 106 Old 05-09-2014, 02:13 PM
eeore39648's Avatar
User is: eeore39648 is offline
Hellcat1, Removing the controller, is no problem.
Were you able to disable the dash light?
post #84 of 106 Old 05-09-2014, 11:35 PM
Not as of yet, but that is due to having a 7MO son at home. I haven't had much time or money to work on the projects. My S10 is apart in the garage for a Turbo conversion.
Hellcat1 is offline
post #85 of 106 Old 05-14-2014, 04:55 PM
4 wheels aren't as fun
serpentracer's Avatar
User is: serpentracer is offline
I know brake cleaner will mess up the wheel sensor. I ruined 2 of them. Now I just wipe the dirt off with a dry rag.
And the brake light will come on with the abs light. When you first start the truck the abs module runs a self check. If a problem is found it illustrates the abs light. The fact the light comes on should mean the module is functioning properly.
02 sonoma 4.3L auto
97 sonoma 2.2L manual
post #86 of 106 Old 05-17-2014, 05:26 PM
eeore39648's Avatar
Thanks, serpentracer.
Is there any way to Reset the ABS light?
Or disable the ABS dash light?
post #87 of 106 Old 05-17-2014, 07:11 PM
Not that I know of. Other than removing the bulbs or fixing the problem. When you fix the issue the light will stay off.
With so many in junk yards fixing it shouldnt cost much. I bought my wheel sensors from one 6+ years ago and they still work.
02 sonoma 4.3L auto
post #88 of 106 Old 05-17-2014, 11:19 PM
eeore39648's Avatar
There is no bulb.
I took out the instrument cluster, it is like a circuit board.
When I got the truck both front wheel sensors the wires were broken. I replaced them both.
I have been told to remove the battery cable for at least 3 hours, and it will reset.
Anybody here heard that?
post #89 of 106 Old 05-18-2014, 11:57 AM
must be led then. there must still be a problem.
not sure if the codes have to be reset because I didn't do it to mine.
02 sonoma 4.3L auto
post #90 of 106 Old 05-19-2014, 09:24 PM
eeore39648's Avatar
Disabled the ABS LED light. Thanks to the help of terry10, a member here.
Here is how, follow the link step by step How To!
http://www.s10forum.com/forum/f221/0...ml#post7960689
post #91 of 106 Old 05-22-2014, 09:40 PM
User is: luvthatsound40 is offline
I had the same trouble and I found a cool video on youtube. Here is how I fixed mine...Take out the air cleaner box and up against the radiator support you will see one single wire that grounds to it. Take it off and wire brush it and the radiator support where it grounds. Problem fixed.
97 Chevy Silverado 4x4
99 GMC Jimmy
03 Chevy Cavalier
post #92 of 106 Old 05-22-2014, 09:42 PM
That ground I was talking about also will throw off the shift points so when the abs and brake lights are on you will notice it will be sluggish too.
99 GMC Jimmy
03 Chevy Cavalier
post #93 of 106 Old 05-23-2014, 09:21 AM
eeore39648's Avatar
Happy it worked for you!
I cleaned up the Ground point, under the air box. No Go, for my truck!
post #94 of 106 Old 05-24-2014, 04:32 PM
User is: ImHellbound is offline
check your ABS fuse, thats what mine does when the fuse is blown/disconnected.
post #95 of 106 Old 05-15-2015, 09:21 AM
User is: ks_skyhawk is offline
To Tinman50. Thanks for the video and narrative on fixing the ABS brake light problems! I followed your instructions and I believe I now am problem free. As was foretold, removing the cover was the hardest part. I'd suggest heeding Tinman50's advice about using a solder iron-gun that has sufficient heat to melt the solder quickly. There are other how-tos with photos on this site that were of assistance. Many thanks to them, also!
post #96 of 106 Old 06-20-2015, 09:48 PM
User is: 2002LM7X is offline
Finishing up the 5.3 swap in our 02, and now once everythings said and done, the abs and parking light are on. Scanned the abs system, cleared the codes, and they immediately came back. Turns out in the process of the swap, we forgot to plug the left and right wheel speed sensors back in. However, now that everything is plugged in, the lights are still on. But with no dtc codes at all. I can't figure out what the problem is. Grounds are all good. Wires appear to be good (no kinks, or corrosion). When plugged into my scanner, i can tell it top clear codes (even though there aren't any), and each light will will turn off for about 2 seconds, then come back on. Any ideas? Suggestions and tips would be hugely appreciated.
2002LM7X is offline
post #97 of 106 Old 07-19-2015, 02:18 PM
desertpatriot
desertpatriot's Avatar
User is: desertpatriot is offline
You think you got it bad, the employees here in California can barely speak English!
2000 S10 LSx, 2.2L , 4L60E automatic, 181K miles, Blazer brake changeover front & rear (4w abs disk), Blazer sway bars front and rear, GU6 3.42 rear end
post #98 of 106 Old 07-20-2015, 07:55 AM
I finally got blown
99xtrm's Avatar
User is: 99xtrm is offline
Some cars have to be driven to turn the lights off basically the computer is looking for good inputs from all the wheel speed sensors before it will be happy.
best time of 13.9 looking for 12's. Pics and vids https://myspace.com/270507651
99xtrm is offline
post #99 of 106 Old 08-24-2015, 09:17 PM
User is: tmc1357 is offline
just tried the ground wire behind the air cleaner box ..cleaned up the connection with a dremel tool with a wire wheel......no more abs and brake light!!...was told that i needed a new abs unit ..$1000.00...cost of this fix..$0.00...about 15 minutes of my time...awesome!
tmc1357 is offline
post #100 of 106 Old 12-16-2015, 05:18 PM
not sure if this is the correct way to do it, but we hooked up a vacuum hose from the abs module in the drivers fender, to the extra vac nipple on the passenger side of the 5.3's intake manifold. you just clip off the little tip, and hook the hose up. our abs light went away
2002LM7X is offline
