32X11.50??? Stock Zr2 - S-10 Forum
post #1 of 10 Old 10-10-2007, 02:22 PM Thread Starter
HighRidinS10's Avatar
User is: HighRidinS10 is offline
Send a message via AIM to HighRidinS10
I haven't been on here in a while..hope everyone's doin good..
I had a quick question that hopefully someone could answer..
I have a 95 S10 Zr2..with 31x10.50s right now.. It looks like there's room but I didn't want to get them and then not have them fit, so..does anyone know if 32x11.50s will fit on my stock 95 s10 zr2?
Thanks!
95 S-10 ZR2 4.3 Vortec 5spd
155k on motor, runnin' like a champ
Flowmaster 40 Series Muffler
Push Bar With Baja Offroading Lights
post #2 of 10 Old 10-10-2007, 11:30 PM Thread Starter
Re: 32X11.50??? Stock Zr2
no one knows?
post #3 of 10 Old 10-11-2007, 11:53 AM
WGPV8S10's Avatar
User is: WGPV8S10 is offline
Bump I want 32's also
2012 R56 S
2011 F800GS
1991 500hp LM7 S10 For sale
WGPV8S10 is offline
post #4 of 10 Old 10-11-2007, 05:02 PM
User is: Thanatos56 is offline
Thanks!
I would not recommend going to the larger tire. They are almost guarnateed to rub during cornering. They might look like they have clearance when the wheels are straight, but most of the time 32 or 33 inch tires are going to hit the fender lips when turning, not to mention contact underneath the vehicle.
Only way to know for certain? Is to go to a retail outlet, have them test fit one tire, mount it on the vehicle, and then steer through the arc in both directions (on the ground, not in the air). At the Goodyear outlet that I manage, we will do this for most customers that are "money in hand", and not just wasting our time.
post #5 of 10 Old 10-11-2007, 05:06 PM
Slap my meat on your pita
GeorgesBlazah's Avatar
User is: GeorgesBlazah is offline
Unless you want to trim they wont fit. It wont be minor trimming either. Gonna hafto do a decent amount. If you do a 2in BL you should be able to get away with 32s(on stock wheels) with minor rubbing if any.
George
98 Blazah 6in SL - 2in BL - 4.56s - Detroit ITS AN ANIMAL 4x4 BUMPER. IT IS NOT MADE ANYMORE, BUT YOU CAN BUY MINE FOR $6000
BLAZER PICS AND INFO CLICK ME
Founder/Godfather of the Anti-Bag Coalition
"Bags are for groceries"
post #6 of 10 Old 10-11-2007, 11:54 PM Thread Starter
One more question, with 31s can I go any wider than a 10.50?
post #7 of 10 Old 10-12-2007, 09:34 AM Thread Starter
dun dun dun... BUMP!
post #8 of 10 Old 10-12-2007, 02:07 PM
You can try, but I would exspect some rub from it. Since the factory wheels/tires get kinda close to frame and whatnot.
George
post #9 of 10 Old 10-14-2007, 09:58 PM
VIRev's Avatar
User is: VIRev is offline
i have 32x11.5 BFG MTs on my 03 Sonoma ZR2, with a 2" body lift. i had to remove the front flarettes (small flares attached to front bumper, and trim a little off the corner on the bottom rear of the flares to clear, also have the TBars cranked a bit to level the truck out (still within "Z" specs). i get rubbing on the sway bar at full lock turning, but other than that i have full clearance. i wheel it pretty hard and never rub anywhere else, but its very tight in some places while turning. on that note it seems that almost every ZR2 seems to have different ride heights and whatnot too...
VIRev is offline
post #10 of 10 Old 10-14-2007, 11:15 PM Thread Starter
nice rig!!
