2wd vs 4wd rear backing plates - S-10 Forum
post #1 of 5 Old 02-02-2010, 12:02 PM Thread Starter
User is: xthrowinsparx is offline
Hey All-
I have searched the forum up and down and cannot seem to find a definitive answer to a question, maybe someone knows or can direct me to the correct thread.
I am going to do a rear disc conversion on my 93 s10 blazer 2wd and picked up a set of backing plates off a newer 4wd truck. Does anyone know the difference between the 2wd and 4wd backing plates, other than the location that the caliper mounts? On the 2wd the calipers mount closer to the rear of the vehicle and on the 4wd the calipers mount closer to the front. I know the camaro guys that use this set-up use 1-2wd backing plate and 1-4wd backing plate because of the staggering of the shocks. Other than this, the rest (rotors, calipers) I believe can be for the 2wd.
Any help is appreciated.
post #2 of 5 Old 02-02-2010, 09:54 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
Re: 2wd vs 4wd rear backing plates
The brake setup is exactly the same 2wd to 4wd in terms of caliper, rotor and pads. The backing plate is different and you'll need a spacer to put 4wd backing plates on a 2wd rear. I know S10 Warehouse on ebay was selling the spacers at one time.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #3 of 5 Old 02-03-2010, 08:18 AM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
i have a set of the 4x4 and the 2wd blazer brakes sitting here at the house. the only thing different is the position the axle mounting bracket holds the caliper. The abutment bracket is exactly the same and the calipers are the same. either will work fine on a 2wd rearend as long as you run the 2wd rotors.
The mounting plate thats welded to the rearend sits back an 1/8" or so closer to the pumpkin then the same bracket does on a disk brake rearend so you will need to make a little spacer to sllide between the axle mount and the disk brake bracket before ya bolt it on. If ya dont feel like making a nice little spacer, several guys have just used 2 washers on each stud.
post #4 of 5 Old 02-03-2010, 11:31 AM Thread Starter
Excellent. Thanks for the help guys.
post #5 of 5 Old 02-03-2010, 12:27 PM
dark side member
User is: bbcc is offline
You're right, except the rotors are different between the 2wd and 4wd. The 4wd has close to 4" of offset and the 2wd has around 2.5" iirc. Quick search came up with a thread here for a visual comparison.
bbcc is offline
