2010 Camaro SS wheels??? - S-10 Forum
post #1 of 28 Old 07-21-2009, 09:50 AM Thread Starter
Iroc-10's Avatar
User is: Iroc-10 is offline
Has anyone tried or put on the new Camaro SS wheels yet? I found a set for sale with tire and less than 100 miles on them. They are 5x120 bolt pattern, but no idea on offset or bs or even width. I tried to post a pic but can't for some reason, so here's the link, and if your interested you can shoot them an email. If you have a pic of your truck with them on it please pm me a pic.
[IMG]file:///C:/Users/Rick/AppData/Local/Temp/moz-screenshot-11.jpg[/IMG][IMG]file:///C:/Users/Rick/AppData/Local/Temp/moz-screenshot-12.jpg[/IMG][IMG]file:///C:/Users/Rick/AppData/Local/Temp/moz-screenshot-13.jpg[/IMG]
http://stlouis.craigslist.org/pts/1280394996.html
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #2 of 28 Old 07-21-2009, 09:55 AM
MVP
FireBall's Avatar
User is: FireBall is offline
Send a message via AIM to FireBall
Re: 2010 Camaro SS wheels???
From what I have read, camaro and corvette wheels fit right on a 4x4. Some 4x4 owners run a 2 inch spacer on the rear to push it out a little bit.
Saying that, I believe you would need to run a 2.5 spacer all the way around on you 2wd truck.
If i'm wrong please correct me!
BTW....those wheels would look badass on a dime
FireBall is offline
post #3 of 28 Old 07-21-2009, 09:59 AM
Slap my meat on your pita
GeorgesBlazah's Avatar
User is: GeorgesBlazah is offline
FireBall - Those were for the 4th gen wheels. I dont think anyone here has tried the 2010 wheels yet.
Iroc - Im sure if you goto GMs website and option out a Camaro it will tell you the width of them. Not sure where you are going to find the offset/bs.
George
98 Blazah 6in SL - 2in BL - 4.56s - Detroit ITS AN ANIMAL 4x4 BUMPER. IT IS NOT MADE ANYMORE, BUT YOU CAN BUY MINE FOR $6000
BLAZER PICS AND INFO CLICK ME
Founder/Godfather of the Anti-Bag Coalition
"Bags are for groceries"
post #4 of 28 Old 07-21-2009, 02:51 PM
DFWminis.com
Dragginblazer's Avatar
User is: Dragginblazer is offline
Send a message via AIM to Dragginblazer
S10 is 5x120.65
2010 Camaro
Bolt Pattern: 5x120
Offset Range: 35 to 45
Wheel Size Range: 20x8.0 to 22x9.5
DFWminis.com
'85 s15 bagged/bodied
'06 CC Canyon daily
post #5 of 28 Old 07-21-2009, 09:28 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
I've got a set of 19" wheels from my wife's G8 that are the same bolt pattern/offset(38mm) as new Camaro wheels are. I need to dig them out of the barn and test fit them to see what kind of spacer I would need to run for them. The problem I'm finding is trying to find adapters from a 120mm bolt pattern to 4.75".
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #6 of 28 Old 10-02-2009, 05:46 PM
User is: ShortBus_Kustomz is offline
just curious, but couldnt you just get s hop to drill the bolt circle out to the 5x4.75 for the s10??? Its not really that much
post #7 of 28 Old 10-02-2009, 09:25 PM
hmmm...
spazattack's Avatar
User is: spazattack is offline
wouldnt boring it out run the risk of failure?
post #8 of 28 Old 10-04-2009, 02:00 PM
i wouldnt think so, cause they would only need bored out another.65 to match the s10 pattern........i was just asking!!! I will be going to my tire guy this next week to ask, cause i would love a set of these wheels powdered black for my jimmy!!!
post #9 of 28 Old 10-04-2009, 04:45 PM
hmmm...
spazattack's Avatar
yeah that would look pretty good
i just recall reading somewhere that boring out wheels runs the risk of failure. i could be wrong tho.
let me know what your tire guy says
post #10 of 28 Old 10-22-2009, 10:18 AM
G4Ls10's Avatar
User is: G4Ls10 is offline
well im pretty sure the camaro wheels are 5x4.75 or 5x120.65mm this ad on ebay says they are but others say 5x120 but ive seen alot of guys use 5x120 wheels on s10s but the backspacing im not sure if it will hit anything on a 2wd truck but u might just need a spacer.
http://cgi.ebay.com/ebaymotors/2010-...item3a53e1600c
G4Ls10 is offline
post #11 of 28 Old 10-22-2009, 04:53 PM
Blue-X
yz85608's Avatar
User is: yz85608 is offline
you wont be able to bore out the wheel not safely, but for the rear you can have the axle shafts redrilled for 5x120
Shawn
Blue Xtreme
Xtremely Stock
yz85608 is offline
post #12 of 28 Old 10-22-2009, 08:33 PM
Zeeke98's Avatar
2010 Camaros and 2008-2009 G8's both have 5x120mm pattern. 67-02 Camaros all had 5x4.75" bolt pattern.
Wade
Zeeke98 is offline
post #13 of 28 Old 10-22-2009, 08:46 PM
Float like a butterfly
dimerunner88's Avatar
User is: dimerunner88 is offline
Send a message via AIM to dimerunner88 Send a message via MSN to dimerunner88
you can not bore out your lug pattern safely,it will fail
Tom
1988 S-10 2.8/5-spd - scrapped
1992 k3500 CCLB
2002 blazer 4wd 5spd
post #14 of 28 Old 10-22-2009, 11:28 PM
keepin it freshhh
Slowlowandbangin's Avatar
User is: Slowlowandbangin is offline
new camaro wheels are the same offset and such as c6 vette wheels.
i saw in a magazine they put a 5th gen in the 11's with a cam and bolt ons, and some slicks they had on zo6 c6 wheels.
Slightly static dropped: SLAB
Totaled
1st Time Around
Follow me on Instagram! @slowlowandbangin
Originally Posted by IhaveNoPantsOn View Post
You shut your whore mouth!
Originally Posted by BlazerZR5 View Post
all straight fact based on observations of your continued retardation.
post #15 of 28 Old 10-27-2009, 08:09 AM
<Severed TIES>
bdydragns10's Avatar
User is: bdydragns10 is offline
Send a message via MSN to bdydragns10
I have a set if anyone is interested
<> Severed TIES <>
post #16 of 28 Old 10-27-2009, 04:48 PM
FooldU
NikeCheck246's Avatar
User is: NikeCheck246 is offline
Send a message via AIM to NikeCheck246
you can run a 5x120 no problem...we install them all the time at work. Some guys us E.T. lug nuts, but you usually dont even need those.
BRRW Afterhours Administration - Dropping & Destroying since '01
Damaged Goods Inc. [Vice]
Bodydropped Coalition...reppin' for the NC boys
post #17 of 28 Old 10-27-2009, 11:08 PM
josmo's Avatar
User is: josmo is offline
wobble bolts ftw
josmo is offline
post #18 of 28 Old 10-29-2009, 06:24 PM
'00 Dime
alarm_the_alarm's Avatar
User is: alarm_the_alarm is offline
'00 S10 ( Arrest Me Red ) 4.3L, Reg Cab,3/2 Lift, Soft 8s, 31x10.5/15 Mickey Thompson MTZ, Chrome grille, Window Tint, Custom Cold Air, LED tails, Line Of Fire And Ice, Leather buckets and center console.
Truck For Sale 6500 PM me.
post #19 of 28 Old 08-24-2010, 09:32 PM
User is: TRUCKEE18 is offline
i also found a new used set of 2010 camaro wheels that would look nice under my s10 so will they fit yes or no thanks
post #20 of 28 Old 08-24-2010, 10:12 PM
User is: Jeremy is offline
Yes.
Jeremy is offline
post #21 of 28 Old 08-24-2010, 10:22 PM
User is: prostreetnoma is offline
I bought a set that size to put BMW wheels on my truck, which also uses 5x120
http://adaptitusa.com/index.aspx
These people will hook you up. Good service
post #22 of 28 Old 09-21-2010, 10:17 PM
2004 Blazer 2DR
jonboys10's Avatar
User is: jonboys10 is offline
On my 93' S10 The 2010 Camaro wheels fit nicely as far as the lug bolts lining up with the wheel dead on...
The problem lies in the hub on the S10 being too long and too large for the hub center of the wheels on the front of the truck. The rear will bolt right up but those hubs up front are going to piss you off. I had to order these so they would fit:
5X4.75 to 5X4.75 Adapters 1.25 inches thick
Here's where I got them from:
http://www.mywheeladapters.com/servl...5-Wheel/Detail
Johnny
post #23 of 28 Old 09-23-2010, 08:21 PM
one of a kind
southernrock20's Avatar
User is: southernrock20 is offline
i wouldnt think so, cause they would only need bored out another.65 to match the s10 pattern....!!!
i know you where just asking and im not flaming, but "only" .65 is actually ALOT, I def wouldnt do it.
DTS Turbo pushing close to 230rwhp, MSD full ingition (wires, dis-2 box), Greddy boost controller, Snow Performance meth injection kit, ASP performance Pullies, Hurst short throw shifter, Zexel Posi Unit, Cal trac Bars, Z28 rear sway bar, full drilled and slotted rotors, Disc brake conversion in the rear, 2/3 belltech leaf drop with nitro shocks, Foose 17x8 polished Rims, Wings West full body kit, Custom made s10 and turbo badges
post #24 of 28 Old 09-23-2010, 11:55 PM
pearldrop's Avatar
User is: pearldrop is offline
I would still only run the correct bolt pattern, but really it isn't much at all. That is .65 of a millimeter, which is only .325 millimeter per lug.
If You Ain't Sittin' Low, You Ain't Sittin' Pretti ... since 1989.
post #25 of 28 Old 09-24-2010, 12:05 AM
ZDiesel's Avatar
User is: ZDiesel is offline
I know I've seen a picture of a white S10 with 2010 camaro SS wheels on it...
Can't find it right now, I'll see if I can find it tomorrow for ya!
Member Project Build Thread: Project daily driven Xtreme
LSx Section Thread: Xtreme L33 Swap
ZDiesel is offline
post #26 of 28 Old 09-24-2010, 03:44 PM
one of a kind
oh ok, i didnt realize it was in millimeters, .012 is just a shaving, i wouldnt worry about it then, most people probably have that much from wear
post #27 of 28 Old 05-16-2013, 10:09 AM
I still watch cartoons!
zoideraserb's Avatar
User is: zoideraserb is offline
Send a message via AIM to zoideraserb Send a message via MSN to zoideraserb Send a message via Yahoo to zoideraserb
.65 of a MILLIMETER is NOT a lot by any means. Going from one wheel maker to another you could have that variance on what's supposed to be the exact same lug pattern. No one makes a 5x120 to 5x4.75 adapter for a good reason... because its pointless.
-Gear
A recent study shows that 92% of all teenagers converted to emo/punk etc. Put this in your sig if you're one of the 8% who stayed gangsta as shit.
Don't be a pussy, use her parent's bed...... If the mom walks in, just say "Hi, you're next!"
post #28 of 28 Old 04-04-2014, 07:38 PM
User is: groverboy83 is offline
I have a 96 noma I have the 2010/2011 camaro 5 spoke wheels 20/8 front an 20/9 out back anyideas what spacer I need for them as far as thickness?
