1996 Sonoma 2wd I Cant Bleed The Rear Brakes! - S-10 Forum
post #1 of 3 Old 06-24-2009, 01:06 AM Thread Starter
User is: clunky is offline
Somethings wrong i Broke a rear brake line, ok now i fixed the line ect goto bleed the rear brakes nothing no fluid flow at all.. Some valve somewhere is blocked...
Any one know how to to un lock the valve or recenter it the one that is stuck ? I only can bleed the front brakes not the rears..
Must be a solution Thanks..
my truck doesnt not have a valve under the master cylinder...has a big honkin box on the front fender that all the brake lines run into and out of...
Any ideas?
clunky is offline
post #2 of 3 Old 06-24-2009, 07:41 AM
Sold
Twin-10s's Avatar
User is: Twin-10s is offline
Re: 1996 Sonoma 2wd I Cant Bleed The Rear Brakes!
click here
should work for you. yours may not have a combination valve under the master.on your its on the abs unit where all the lines go in and out of.
Twin-10s is offline
post #3 of 3 Old 06-25-2009, 11:02 AM
Been around the block
CatDaddy52's Avatar
User is: CatDaddy52 is offline
Try using a vacuum bleeder that pulls the fluid through the system......
