ZR2 Rear End? - S-10 Forum
post #1 of 18 Old 02-27-2007, 04:10 PM Thread Starter
User is: farris8010 is offline
ZR2 Rear End?
I have a Sonoma and I'm wanting positraction for the rear end. I have the opportunity to purchase a ZR2 rear end (Which i have been told comes factory with the locking differential) cheaper than getting posi installed on my current rear end. Would the ZR2 rear end fit in my truck with little to no fab work?
post #2 of 18 Old 02-27-2007, 04:13 PM
forum idiot
orangesonoma's Avatar
Re: ZR2 Rear End?
is your sonoma 4x4?
Brian
orangesonoma is offline
post #3 of 18 Old 02-27-2007, 04:13 PM Thread Starter
Re: ZR2 Rear End?
yeah it's a 4x4
post #4 of 18 Old 02-27-2007, 04:14 PM
forum idiot
Re: ZR2 Rear End?
they should be fine...but i would just swap out the diff
Brian
post #5 of 18 Old 02-27-2007, 04:15 PM
forum idiot
Re: ZR2 Rear End?
the rear also may have a different gear ratio..since the truck comes stock with 31 inch tall tires...
Brian
post #6 of 18 Old 02-27-2007, 08:09 PM
no longer has a 95
95 S_Trucker's Avatar
User is: 95 S_Trucker is offline
Send a message via AIM to 95 S_Trucker
Re: ZR2 Rear End?
It will also be 4-6 inches wider
99 Blazer 2 Door, 4wd, NV3500, 8.5
99 K2500 LS CCSB 7.4, 4L80E
post #7 of 18 Old 02-28-2007, 09:24 AM
sportsdime's Avatar
User is: sportsdime is offline
Re: ZR2 Rear End?
in my 02 i have a limited slip diff, dont know if thats the same as what you want, but if so, it comes stock on an 02s10, just a thought, sorry if its not what your looking for,
2002 s100 2" home made lift shackles 1" t bar crank 265/75's, cherry bomb, spray in bed liner, push bars, dual fog lights, cb radio,
soon---back to 30x10.5x15's. hood scoop. dual exhausts
some day---6" lift and 33's. 10k lb winch.
post #8 of 18 Old 02-28-2007, 09:44 AM
slammed89n92s10's Avatar
User is: slammed89n92s10 is offline
Send a message via AIM to slammed89n92s10
Re: ZR2 Rear End?
measure the rearends to see the width, and for it working trial and error
post #9 of 18 Old 03-04-2007, 12:51 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Re: ZR2 Rear End?
Isnt the ZR2 rearend wider then stock 4WD?
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #10 of 18 Old 03-04-2007, 02:59 PM
Flying Bison's Avatar
User is: Flying Bison is offline
Re: ZR2 Rear End?
yes but as mentioned erlier just swap out the diff, and also as mentioned check the gear rations
try finding a limited slip diff out of a standard 4x4 s10 at a junkyard or something cause they were an option from the factory, then you dont have to dealwith axle widths and gear ratios
AJ
post #11 of 18 Old 03-04-2007, 04:03 PM
User is: srt4drew is offline
Re: ZR2 Rear End?
I've got a 2wd 95' s-10 and am intersted in installing a locking or lsd differential. I want to turn the truck into a baja like offroad truck. good for snow & dirt. any ideas on what might wok best to give me some off raod traction?? thanks.
srt4drew is offline
post #12 of 18 Old 03-04-2007, 04:36 PM
jtcfanof3's Avatar
Re: ZR2 Rear End?
Ok,also isnt a ZR2 a 8.5,thus the reason I didnt think you could just swap out the gears.
I may be wrong though.
I agree though,go too a junkyard and look for the newer 2nd gens with an G80 RPO code,thats the limited slip dif,my 2WD ZQ8 has this option,so its not just 4wd's.
post #13 of 18 Old 03-05-2007, 01:18 AM
Bowtie Supply, RIP
theoriginalbowtie's Avatar
User is: theoriginalbowtie is offline
Re: ZR2 Rear End?
Posi/limited slip/G80 was optional in most S10's I believe, and it may have been standard or mandatory in some models (like the SS.)
The 4wd is wider than the 2wd and the ZR2 is wider yet, 3.9-4" wider but not sure if that measurement is over the 4wd or 2wd--could be over the 4wd. The ZR2 has the 8.5" and most of the others have the 7.5/7.625" though I think some v6 5-speeds had the 8.5" too. The 8.5" is the same type used in mid-80's 442 & GN's, not sure if the same # of splines. The 7.5/7.625 is similar to the Monte SS & Camaro but I think later years may have had more splines.
As for posi/limited slip, make sure you figure out which size & splines you have first, then look for a unit from a 4wd, they should be easier to find with a limited slip in it than a 2wd. I personally have never seen a 4wd that wasn't posi/G80/limited slip.
Also keep in mind that you just can't take a unit out of one and just slap it into yours--rearend gears have to be set up properly with backlash and pinion depth and preload, so you will still have to pay to have it installed & set up properly... some places want the rear out of the vehicle and some will do it in the vehicle for more money.
That's why it's usually cheaper to go with a complete rearend that matches (2wd-->2wd, 4wd-->4wd.) Wheels also have a different backspacing because of the wider rearends in 4wd & ZR2.
post #14 of 18 Old 03-05-2007, 06:05 AM
jtcfanof3's Avatar
Re: ZR2 Rear End?
The ZR2 has the 8.5" and most of the others have the 7.5/7.625" though I think some v6 5-speeds had the 8.5" too. .
Actually the G80 code is not found very often,and its about as much of a crap shoot in 4wd's as it is in 2wd's.Although all the new fullsize 2wd's have the G80,its standard now and not just an option.
Im pretty sure all 2nd gens have the 7 5/8's rear,I forget what year they switched.
S10warehouse is always selling rear ends,but your looking at about $500-$600 for a full OEM rear end.
Good luck though guy.
BTW,just an FYI,my wifes old 2001 GMC Jimmy 4WD was not a G80,but my lowered ZQ8 03 2WD is a G80 so go figure,LOL.
post #15 of 18 Old 03-05-2007, 06:22 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
Re: ZR2 Rear End?
With all that said
G80 was standard on the ZR2 right? I test drove a Zr2 highrider yesterday and it did have the G80 code. I always though posi and 3.73 gears was what all the ZR2 Rigs came with as part of the ZR2 package.
post #16 of 18 Old 03-05-2007, 05:59 PM
jtcfanof3's Avatar
Re: ZR2 Rear End?
That I dont know,but Ive got 3:42's,or GU6/G80 combo.
post #17 of 18 Old 03-01-2011, 04:15 PM
johnny9's Avatar
User is: johnny9 is offline
Re: ZR2 Rear End?
i checked mine this morning to see what my lil 4x4 had,,it has the gu6 code and g80 beside it,,so i see its 3.42,s but does the g80 beside it mean its a 8.5 rear end in my 95 model? it is wider than my other s-10,s i had also?
i was gonna swap it out for a 8.8 rear and match a d30 straight axle up front,but if it has a 8.5 rear"it is lsd" then maybe i should keep it in there and not go to the trouble with the 8.8..
i know the 8.8 will hold up to 35,s easy and a d30 is a good match for the front..any opinions? thanks
johnny9 is offline
post #18 of 18 Old 05-08-2014, 03:52 PM
User is: Wildevilman is offline
Re: ZR2 Rear End?
^^^^^ Bump! I have the same question as the post above me. I have a 2002 sonoma 4.3 4x4 an the GU6 G80 codes. Does that mean I have an 8.5 rear axle?
