wiper motor FRUSTRATION!!!!!
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 11-06-2009, 09:47 PM   #1
Well after going to the wreckers and getting a wiper motor for my 94' Sonoma and spending time changing it , the damn wipers still don't work. I hear noise even when the switch isn't on but when i turn it to high guess what no noise. The wreckers told me they tested it and it worked. Any idea next!!!!
Old 11-06-2009, 09:49 PM   #2
travisn's Avatar
Re: wiper motor FRUSTRATION!!!!!
switch/lever on the column
Old 11-06-2009, 09:55 PM   #3
is it a big job to change the switch???
Old 11-06-2009, 11:00 PM   #4
i heard that there is a ground wire attach to the motor. I just notice that on top of my wiper motor( away from the circuit board plug ) there is a wire attached to a screw on top should this be grounded. My windshield fluid sprays when turned on.
Old 11-06-2009, 11:03 PM   #5
CODE4LS1's Avatar
For sure mke sure that wire is to good ground.
Old 11-06-2009, 11:22 PM   #6
BINGO ran a ground wire and they came on. now how do you synchronize them? When I took the motor out i disconnected the drivers side and moved it now they aren't in sync.
Old 11-07-2009, 09:12 PM   #7
You...Tonight
mostizzle's Avatar
i'm not sure what u mean by synchronize them but turn off the motor then pull the wiper arms off and put em back on so they're both even in the off position and you should be good to go IF thats what you meant lol
Page generated in 0.56343 seconds with 31 queries
[Output: 58.69 Kb. compressed to 55.29 Kb. by saving 3.40 Kb. (5.79%)]
