Weak Spark on Cylinder 4 - S-10 Forum
post #1 of 4 Old 04-08-2017, 07:15 PM Thread Starter
User is: Saintlouis74 is offline
I have a 1997 S10 with a 2.2 4banger, that i completely rebuilt myself. New main bearings, cam bearings, piston rings, reseated valves, all new gaskets, new coils, plugs and wire, control module, fuel injectors, new air/fuel filters, new fuel pump regulator.. Did a compression test (12 cranks) 149-152 psi through out all cylinders. even switch the ECMout with a different one..
My problem is that Cylinder 4, when i pull the plug off to check the spark, it barely makes it out the boot. and when i disconnect it, theirs no drop in the performance of the engine. 1-3 has a strong spark, and when i pull those off the engine starts to hesitate more.
I switch the ECM with a junkyard one(it fired the car right up but had the same issues) because it threw a ECM replacement code with the ODB scanner
Codes: P0200, P0405
i have no blinking CEL
ive tried tracing the 5v 12V coming from the ECM, when i uplug the EGR connector the 5v and 12v are there, but as soon as i connect it to the EGR it goes away.
post #2 of 4 Old 04-15-2017, 08:13 AM Thread Starter
Re: Weak Spark on Cylinder 4
Codes: P0200, P0405
code: p0200 = was a short in the fuel injector harness (fixed)
code: p0405 = was a bad EGR (replaced)
after getting those 2 things fixed, and reseting the codes in the PCM.. truck is back up and running on all 4.
i also switch out the MAP sensor with a used one from the Junkyard(not sure if that a difference) but between those 3 things my truck is running again
post #3 of 4 Old 04-20-2017, 11:25 PM
Alumni: Anger Management
joesmokabo's Avatar
User is: joesmokabo is offline
Glad you got it going.
I've seen others mention a blinking CEL. What does it mean if it blinks?
post #4 of 4 Old 04-21-2017, 03:33 AM
It's mostly BS
rimara's Avatar
User is: rimara is offline
It means you are probably damaging your emission control system...i.e. your cat.
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
