Trailer Wiring Color Codes - S-10 Forum
post #1 of 5 Old 03-11-2011, 07:14 PM Thread Starter
User is: jamiet757 is offline
Question Trailer Wiring Color Codes
I have a 2000 Sonoma, and I recently got a cap for it. I have the wiring harness to plug into the cap, but I need to tap the CHMSL wire and a hot wire for the dome light.
I have a trailer wiring harness already installed, but I can't remember which color is which and if anyone here can tell me without me having to test each wire with my multimeter, I would appreciate it.
Also, there is a light-blueish wire inside the framerail next to all the other wires that is looped around and has a tag on it, I think this is the CHMSL wire but the tag is so worn I can't really read what it says.
Anyone know off hand if that is the CHMSL wire, and where I can find a constantly-hot wire for the dome light without running wires all the way up the truck?
TIA!
post #2 of 5 Old 03-11-2011, 07:32 PM
Registered Hoosier
Hoosier Rick's Avatar
User is: Hoosier Rick is online now
Re: Trailer Wiring Color Codes
According to my 2000 Jimmy owner's manual, the light blue wire is aux stop lamp. There is not a constant 12v wire, unless you have the 8 wire harness. It is common for people to hook the dome light to the tail light circuit instead of running a new hot wire. You just turn on parking lights to operate dome lamp.
2000 Jimmy 4x4 4dr. 252,000 miles
2002 rcsb, 2.2 at, 253,000 miles
1967 C10
post #3 of 5 Old 03-11-2011, 07:36 PM Thread Starter
Yeah that's what I was hoping the blue light was, but there isn't a constant 12v for the trailer I guess huh?
Maybe I will run a wire from the front then, maybe I could even get fancy and splice it in with the dome light in the cab?
post #4 of 5 Old 03-11-2011, 08:55 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
No constant 12V back there anywhere. I ran a 10 gauge stereo wire up the drivers side frame rail to the 12v positive lug on the fuse box so could put in a cigarette lighter plug as well as hooking up the light in my topper. I wired in a lighted on off switch for the lighter plug and light as well.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #5 of 5 Old 03-11-2011, 09:13 PM Thread Starter
that sounds like probably the best route for me, thanks!
