thermostat replacement 2001 4.3 - S-10 Forum
post #1 of 19 Old 01-11-2011, 10:11 AM Thread Starter
User is: rhursey is offline
Hi I'm new here and need help replacing the stat on my s10. Step by step instructions on how to remove all the parts in the way (Air intake etc) would be helpful.
rhursey is offline
post #2 of 19 Old 01-11-2011, 03:49 PM
User is: jesuscarrasco is offline
Re: thermostat replacement 2001 4.3
yes please i also need to know how to do this aswell can someone post a step by step and pictures would be great, like where it is actually is in the engine
post #3 of 19 Old 01-11-2011, 03:56 PM
Dump em' Out
Bootylicious's Avatar
User is: Bootylicious is offline
I am not going to do a step by step because if you SEARCH you will MANY threads on this same subject. Search, use it....love it.
You want to remove your air cleaner off the throttle body.
You will see below that a black "tube" like thing directly over the motor in the middle towards the front of the motor with two bolts on it. Remove it and inside will be the thermostat. If this didnt help and you cant figure out how to do it by searching on this forum.....go buy yourself a Haynes manual, which is a good investment anyway.
post #4 of 19 Old 01-11-2011, 08:18 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
You have to remove the throttle cable brackets as well as you can't get the studs out of the thermostat housing with them in place. Just swapped mine out this past weekend.
There's a thread somewhere in the 4.3 section with pics and complete step by step.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #5 of 19 Old 01-12-2011, 03:28 PM Thread Starter
I know where the stat is located but don't want to waste time out in the cold trying to figure out how to remove the air cleaner from the throttle body. Have searched but the only info says remove the air intake but not how.
rhursey is offline
post #6 of 19 Old 01-12-2011, 03:39 PM
User is: sfhellwig is offline
To get the bonnet off of the TB, my 98 has a plastic wingnut bolt that you unscrew. Once it is loose you angle the bonnet, forward I thing and it comes away. My bonnet has a picture of the motion on it. Installation is reverse of removal. And of course yours could be different.
post #7 of 19 Old 01-12-2011, 04:37 PM Thread Starter
No Wing nut. no visible way to remove it easily. Thanks anyway!
rhursey is offline
post #8 of 19 Old 01-12-2011, 08:38 PM
Zeeke98's Avatar
What year? Any 96+ 4.3 intake has a wingnut on top of the throttle body holding it on. I've seen the ears break off on some but there's still the bolt/stud there holding it on.
Wade
Zeeke98 is offline
post #9 of 19 Old 01-13-2011, 12:20 AM Thread Starter
2001 s10 No wing nut.
rhursey is offline
post #10 of 19 Old 01-13-2011, 07:37 PM
Zeeke98's Avatar
It's behind the hat that goes over the throttle body. You can just see it sticking up here in this picture. I don't have any better ones and have a cold air intake now.
Wade
Zeeke98 is offline
post #11 of 19 Old 01-13-2011, 11:54 PM Thread Starter
Thumbs up Re: thermostat replacement 2001 4.3
Thanks Zeeke!
rhursey is offline
post #12 of 19 Old 01-14-2011, 02:47 PM Thread Starter
hey zeek98 I just got a chance to check on my problem. The reason I could not see a wing nut is because it was not there. It may have been removed in a previous repair and was never replaced. Will change the stat on Saturday when it is a little warmer here. Thanks Again
rhursey is offline
post #13 of 19 Old 01-14-2011, 04:38 PM
Dropped at birth
WhiteDime73's Avatar
User is: WhiteDime73 is offline
Send a message via AIM to WhiteDime73
Bud if you're having trouble figuring out how to get the intake tube off how do you plan on changing the thermostat yourself? Not trying to be a dick or anything, I just hate seeing people get in over their heads lol.
2011 Ram 1500 RCSB 4x2 Hemi - Daily Driver
1998 Dakota Sport- 5.2 5 spd 3.90 posi 2wd
post #14 of 19 Old 01-15-2011, 02:13 PM
Bold as Love
Harry Canyon's Avatar
User is: Harry Canyon is offline
You might want to stick something on there to hold the TB hat on, it can pop loose, and inhale dirt/spring vaccum leaks.
1998 S10 4.3/Auto daily driver.
1984 S15 2.2 Diesel.
1988 S10 2.5 5-speed lowered 4/4.
post #15 of 19 Old 04-29-2011, 08:37 PM
hansonmorrison's Avatar
User is: hansonmorrison is offline
It's been months since i visited this club and finally came out here. Well, there are so many discussions that could help you address the issue you've been in thru. some websites offer repair manuals at around $20. All you need is to input the car make and model of your auto. On the other hand, you're still free to drag your car to the nearby repair outlet. Done the replaced almost two years ago in a shop named AAMCO of Pittsburgh. the service was great and guys out there were patient...im recommending this place as your second option. Just contact bill and told him you were referred by me. here's the contact information by the way;
4065 Greensburg Pike,
Pittsburgh, PA, 15221
412-271-3980
Pittsburgh auto repair shops
post #16 of 19 Old 04-29-2011, 08:52 PM
Zeeke98's Avatar
Spam much? Why would you have something done in PA but your location says AZ.
Wade
Zeeke98 is offline
post #17 of 19 Old 04-29-2011, 09:54 PM
residing in PA right now man...sorry for not putting an update to my profile...
post #18 of 19 Old 04-29-2011, 10:02 PM
Zeeke98's Avatar
Looked like spam with the random post on a thread from January and a link in the sig.
Wade
Zeeke98 is offline
post #19 of 19 Old 05-02-2011, 10:45 AM
User is: bodaciuos is offline
u should really get a bolt or something to tighten it down.. u could be wasting more gas . suck more a8ir in and it cant be read by comp. the truck will consipate with more gas injection..
