Temp Gauge Not Working - S-10 Forum
post #1 of 22 Old 02-03-2007, 01:32 PM Thread Starter
Kryp Toker
spitnhard79's Avatar
User is: spitnhard79 is offline
Ok i have a 1997 extra cab 4.3 auto , and for some reason my temp gauge just dont work , it stay at the bottom after doing some research i learned that it could be the temp gauge sender so i installed that this morning and still nothing ...
anyone have any ideas ?????
I got to have my temp gauge and dont want a aftermarket one !!!
post #2 of 22 Old 02-03-2007, 04:38 PM
TwoWheelJay's Avatar
User is: TwoWheelJay is offline
Send a message via AIM to TwoWheelJay
Re: Temp Gauge Not Working
are ur connections at the back of the cluster intact?
02 Blazer Xtreme Blk/Blk
94 xcab **SOLD** re-7/re-8/sd flame bridge/viar 380/york 209/2 5 gal/custom swirlies/20% tint/ tweed interior/
pioneer hu/alpine, jl audio speakers/alpine , zapco amps/ kicker cvr 15's/7" in dash/ps2/e-fan/msd box/msd coil
post #3 of 22 Old 02-03-2007, 04:46 PM
drop and dragg
sonoma99beast's Avatar
User is: sonoma99beast is offline
Send a message via Yahoo to sonoma99beast
does your heater work? does it blow really hot? mine temp gauge wouldnt move and my heat wouldnt work and all i had to do was replace the thermostat it was stuck wide open
www.cardomain.com/ride/2471279
lookin for a 99+ gmc jimmy front bumper cover pm me if you have one
post #4 of 22 Old 02-03-2007, 06:42 PM Thread Starter
Kryp Toker
I could see how that wouldnt let the heater get very hot but make the thermostat not even move , No Way the thermostat only holds back the water untill the engine reach's whatever temp thermostat it is , even if it was stuck open it would heat up to 170 180 which should would show on the temp gauge ...
I am about to give up and take it to my mechanic ,
post #5 of 22 Old 02-03-2007, 06:43 PM Thread Starter
Kryp Toker
Which cluster ???
post #6 of 22 Old 02-03-2007, 07:35 PM
how many gauge clusters do u have? im just saying, at the back of the gauge cluster, are any connections missing... if youve pulled it out before or anything, its possible a wire/connection was missed.
post #7 of 22 Old 02-03-2007, 08:17 PM Thread Starter
Kryp Toker
nope never been touched , also i changed the temp gauge sender today and before i replaced i grounded out the plug and the gauge jumped so i know its hooked up !!
post #8 of 22 Old 02-04-2007, 02:00 AM Thread Starter
Kryp Toker
You know what i just noticed that the temp gauge only goes up two small lines after 100 even when ran for a hour+ im lost for stuff to try , where is the thermostst located ???
I know on most cars its located on the manifold under the main radiator hose , is this where this one is at ????
I looked and it looks like it could be electronic and i have a 4.3...
post #9 of 22 Old 02-04-2007, 03:11 AM
when you look at the top//front of the motor, the radiater hose comes up, and then goes down into where the intake manifold is. That hose connects to the water outlet, and you have to unbolt it to get to the thermostat.
post #10 of 22 Old 02-04-2007, 10:58 AM Thread Starter
Kryp Toker
will i need to buy a new gasket ??
post #11 of 22 Old 02-04-2007, 05:26 PM
radarblue95's Avatar
User is: radarblue95 is offline
ye sit comes with the thermo
post #12 of 22 Old 02-04-2007, 06:43 PM
^ actually no it does not
the therm gasket will come with it (an o-ring typ)
however you need the water outlet gasket (also known as housing seal), which is a seperate part number.
THM 540099 $11.99 is the thermostat you need (the good one, not the cheap econemy version) the o-ring type gasket is included.
NGA 31273 $1.99 is the housing seal (water outlet gasket) that you will need.
both are napa part numbers and online prices, your local retailer may have a better/worse price
post #13 of 22 Old 02-04-2007, 10:19 PM Thread Starter
Kryp Toker
if the thermostat was removed , the gauge should still move up to almost 200 once hot right .?/??? My problem is my gauge barley moves once warm , seriously it moves to small lines and thats it....
post #14 of 22 Old 02-04-2007, 11:06 PM
well with no thermostat it would take a long ass time to warm up, and depending on the temp outside, i dont know if it would get up to 200, cuz your fan would still come on probably.
post #15 of 22 Old 02-04-2007, 11:21 PM Thread Starter
Kryp Toker
here in FL its 80degrees in the days and even after driving for a hour it still wont move past the 2nd little line .......
and what do you mean fan would still come on , the fan is always on !!!
It is connected to the belt , or do these engines (4.3) also have electric fans as well....??
post #16 of 22 Old 02-05-2007, 02:33 AM
oh ya, sorry i kinda blanked on that. Mines got an e-fan so im used to it having an on and off point.
post #17 of 22 Old 02-05-2007, 08:28 AM Thread Starter
Kryp Toker
no problem i just spoke to the original owner of the truck and he said he changed the water pump about a year ago and before that it worked perfect ...????
post #18 of 22 Old 02-05-2007, 10:14 AM
i dont think the water pump would directy affect the reading on the temp gauge, unless it wasnt working, in which case the truck would overheat/
post #19 of 22 Old 02-05-2007, 10:42 AM
B4U Task Force
Rhotpursuit's Avatar
The entire cluster has one connection that is stationary. It's either connected or not. Of course if the cluster is seated in place it would be connected.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #20 of 22 Old 02-05-2007, 11:22 AM
^^mine wanted to pull out with my cluster, not stay stationary..weird
post #21 of 22 Old 02-05-2007, 08:19 PM Thread Starter
Kryp Toker
He said he replaced the water pump b/c it was running hot !! LOL
You only replace the water pump when it leaks ..... The mechanic probably just pulled the thermostat and said he replaced the water pump b/c the pump does not look new !!! This guy i bought the car from was a Total Duck !!!
My next step in the process of elimination is the thermostat so i will update ....
I wanted to do it tonight but i got off of work late and it was already dark out !!!
Hopefully 2morro night ....
post #22 of 22 Old 02-06-2007, 04:54 PM
Banned
User is: cobra22nd is offline
I have the same problem. I am switching the thermostat next week to see if that works. I thought about doing the sending unit, but that looks like a real PITA. Was it?
