Tach wont work
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 05-23-2008, 09:37 AM   #1
kjm762 is on a distinguished road
Tach wont work
Last night I installed my new tach cluster in my 95 2.2L pick up. Everything works perfectly but the tach wont move. I checked the pins in the bulkhead connector against both the old & new clusters & I see pins in all the places that the new cluster has marks on the printed circuit. It got late and I just stuck it together enough to drive today. Looks like there is a white wire that sends signal from igntion coil to the tach, common ground circuit between them all. Before I get real deeply involved, anyone gone thru this?
Old 07-23-2008, 12:45 PM   #2
Re: Tach wont work
Ok, found the problem is in the cluster. Have signal at pin 8 and ground is good. Got continuity on printed circuit from pin 8 to the tach connection. So I guess I have to take it apart to see whats going on.
Old 08-26-2008, 06:24 PM   #3
No mor bags juice or dubs
juicedondubs's Avatar
juicedondubs
Re: Tach wont work
im having the exact same problem same truck. i havent had a chance to check yet, but did you get a pulse on the tach wire at the cluster. My meter stays at work most of the time so it will be next week before i can tinker with it again. when i figure it out i will most definetly post since there is no thread on this particular issue with this model truck. did your cluster come from a 4.3?
Old 08-28-2008, 09:46 AM   #4
Re: Tach wont work
Mine is a 2.2L auto cluster. Rare as hens teeth. I took mine out & apart. I have I think a bad inner IC board chip from what we can tell. It seems there are alot of people that do things here but when a problem comes up, there is not a lot of deep answers. I'm going to locate another tach & swap IC boards to see if that fixes it or is it the meter.
Old 08-28-2008, 10:44 PM   #5
2001 Stepside s10 FTW!!
SlamThiz's Avatar
SlamThiz is on a distinguished road
Re: Tach wont work
well i no its probly dif but, on my 2.2 5 speed i had to get to the guage cluster plug ins and run the green wire? i dont remember good, to a white beige looking 1.. its working till this day.
Page generated in 0.07610 seconds with 11 queries
