Strange problem a Vibration at 65 mph
Hi, I developed a strange problem, the other day my serp belt snapped, I got the truck (97 S-10 ext cab 4.3 V-6 auto) pulled right over didnt have time to overheat or anything. Went right out and got a new belt put it on and all was fine UNTILL I hit the freeway, now I get a vibration at 65 mph its there even when I pop it in neutral. I NEVER had the vibration until that belt popped. I did a little google research and found that others had similar problems like mine but I couldnt find a solution, anyone here know what I could do to get rid of the vibration??? Thanks
I SHIT BRICKS
Re: Strange problem a Vibration at 65 mph
tires are not balanced
Like I said no vibrations befor the belt popped, I was on the freeway doing 75 mph when the belt popped, BUT just to ease my mind I had the tires rebalanced...they balance was perfect...I'm at a loss, Oh also had the driveline checked at dealer it was in tolerance.
you might have thrown your a/c compresser out of alighnment or your alternator or your power stering pump
Registered (Ab) User
Location: League City, TX (Houston) User is: OffLine ![]() |
When you put it in neutral at 65 mph does the vibration change? Is there less vibration in neutral? Have you tried turning the motor off at 65?
SAS inprogress
are you sure its just at 65 or at the same RPM throughout the different gear
Thanks to the person that PM'ed me, you nailed it, it was just what you said THE BELT TENSIONER, I would have never gussed it. Thanks a million.
Aquatic Goat Farmer
Location: Houston-aka Northern Mexico User is: OffLine ![]() |
the belt tensioner gave you vibrations, thats badass. I have vibrations in my pickup truck and will give that a try, got an oreilly lifetime tensioner years ago so I'll swap it out and see what happens.
as much of a smart elleck as im going to sound when i say this im not trying to be...how would a belt tensioner even do that?
When the belt came apart, it might have damaged the bearing in the pulley slightly. Also see alot of the springs in the tensioners fail & make the assy wobble.
