Shift Indicator - S-10 Forum
post #1 of 5 Old 06-19-2011, 01:22 AM Thread Starter
User is: Bviers is offline
Shift Indicator
I have a 94 s10 ext. 2wd with and automatic transmission and the shift indicator on the column does not line up with the proper gear. You can still drive the truck by counting the number clicks the shifter goes down. I was just wondering if there is a fix to this issue or, if it could cause problems later on.
Any Advice is appreciated.
Bviers is offline
post #2 of 5 Old 06-20-2011, 10:45 AM
Big Blue Nation
SSfan's Avatar
User is: SSfan is offline
Send a message via AIM to SSfan
Re: Shift Indicator
You can still drive it, alot of them did it, its just a little wire that looks like a twisty tie that connects the indicator with the shifter...mine did that too, I fixed it by puttin a blazer floor shift in lol....but it wont affect anything as long as you know what gear youre in
-S-Clusive Ohio Chapter-
'94 Diamond White S10 SS
'02 Olympic White S10 ZR2
SSfan is offline
post #3 of 5 Old 06-20-2011, 11:03 AM
Electrical Mod
deathphoenix99's Avatar
Re: Shift Indicator
Just remove the trim piece around the cluster and you can adjust the pull wire.
post #4 of 5 Old 09-18-2011, 07:02 PM
Ford guy stuck w/ chebby
n8rsk8r's Avatar
User is: n8rsk8r is offline
Re: Shift Indicator
Mine has all the sudden gotten REALLY bad. As in the shifter it's self moves in and out of the spot.. it hasn't switched a gear by its self, but it is not tight and doesn't "light up.. indicate" what gear it is in all the time. I can get it to by minipulation of the shifter, like going over the gear to get it to light up, and coming back to that gear. Also "1" will not light no matter what. I CAN switch to different gears, that isn't an issue, but having the indicator show what gear it is in, and to have the shifter "stick" where it is supposed to be.. doesn't always happen.
Anyone have any info for me on this? This is my initial search for this problem. Didn't know what to call it though..
1999 2WD Automatic S10 standard cab.
I have nearly rebuilt this damn truck 100%!!
n8rsk8r is offline
post #5 of 5 Old 09-20-2011, 05:53 AM
Vig Pimpin
viggy58's Avatar
User is: viggy58 is offline
Re: Shift Indicator
well, from your description in this thread, i'd say a bad shift cable or one of the brackets / attachments that holds the cable in place is broken.
___________________________________________
2001 Blazer
4.3L 5 speed manual trans, 2wd
180k miles
ALL STOCK!
Profile Baja amp, 100w x4
Sony Xplod 1000w x1
Alpine type R 12in. sub
viggy58 is offline
