Security light comes on while driving, gauges quit working - S-10 Forum
post #1 of 7 Old 01-14-2011, 02:44 PM Thread Starter
User is: Butch50 is offline
Hello!
I am new to this forum. Did a lot searching on this particular problem but no joy.
1998 S10 2.2L Automatic
Occasionally while driving my gauges go out, or in some cases give innacurate displays. From the bottom up: Gear selection does not show. Oil pressure zeros out. Amps zeros out. Gas gauge zeros out. Speedometer innacurate - slower than actual. RPMs inaccurate - lower than actual. Several of the top warning lights light up, including security light.
The truck still runs fine. If I shut it off, the security light stays lit. The truck still starts and runs.
So far it has not be much of a problem other than trying to guess how fast I am going. But...I am afraid that whatever this problem is, it will get worse with time.
Has anyone got an idea what is malfunctioning - and how to fix it?
Thanks in advance for any and all suggestions.
Butch50 is offline
post #2 of 7 Old 01-15-2011, 01:41 PM
User is: bodaciuos is offline
Re: Security light comes on while driving, gauges quit working
i would think its the cluster going bad. u should try pulling it out and resetting it in place. to see if its just have bad contacts to to vehicle.. or try getting it replaced. u dont want a short . could make thing worse good luck..
post #3 of 7 Old 01-16-2011, 12:44 AM
UnfiNished PRoJecT
User is: jeffwpayne is offline
^^ that or bad ground, maybe alternator is going bad
D.R.A.G.G.I.N-ASS
post #4 of 7 Old 01-17-2011, 08:49 AM
User is: 2.2whiteS10 is offline
I am having the same problems. I found this thread but have not had a chance to check for this loose ground. Here is a quote from the thread that gives you the best idea where it is.
My truck did the same exact thing. There is a bolt that runs into the bottom of your dash on the left side on the fuse panel side. As your dash slopes down it will be right at the bottom close to the hood release i think. There is a ground wire on that bolt, and it is prolly loose. I think its the main ground for your dash lights n stuff. I just tightened the bolt up and made sure the wire didnt wiggle. Dash lights never went out again. This could b ur problem. Hope that helps.
http://www.s10forum.com/forum/f104/d...licker-238450/
post #5 of 7 Old 01-17-2011, 11:04 AM
User is: swigs84 is offline
my truck did the same thing ended up being the cluster itself
swigs84 is offline
post #6 of 7 Old 01-18-2011, 12:32 PM Thread Starter
Thanks for the tips!
Checking the ground under the dash will be my first step - since it will be the cheapest.
I will also run a voltage output check while the lights are working properly, and another if they fritz on me again - to see if there is a difference.
If that doesn't work then I will try pulling and replacing the cluster to see if freshening the contacts helps.
If that doesn't work then I will replace the cluster.
By the way - I had a new alternator installed several months ago. It shows a good charge when running. I didn't have the lights problem back when the old alternator was going bad. Not that that means it isn't the alternator this time.
I appreciate the feedback - a lot!
Butch50 is offline
post #7 of 7 Old 01-20-2011, 01:30 PM
Typoe99's Avatar
User is: Typoe99 is offline
im having a similar issue where my security light will come on randomly. the cluster doesnt stop working but lately the security light just randomly comes on and will go away if i turn the truck off and restart it. do you think it could be a grounding issue as well?
1998 S10 Pickup
2.2L 5-Speed Manual
Typoe99 is offline
