s10 third door window wind noise - S-10 Forum
post #1 of 9 Old 01-28-2013, 08:45 PM Thread Starter
...mhmm
blackedfivethree's Avatar
User is: blackedfivethree is offline
hey guys i have an 02 s10 ext cab with a 5.3L my issue is that the weather strip or seal on the window doesnt seal anymore due to being worn or the latch wont pull it tight enough and was curious has anyone had this problem and how did you fix it? any thoughts or input will be greatly appreciated.
5.3L (stock) , auto (built) , Port and Polished TB, 3.73's w/ true-trac posi, custom CAI, 3" exhaust through spin-tech pro-streets w/ E-cutouts.
soon to come:long tube headers, cam and heads.
post #2 of 9 Old 01-29-2013, 02:13 AM
Z28_ZR2's Avatar
User is: Z28_ZR2 is offline
Re: s10 third door window wind noise
I have the same issue, except for me the wind noise comes from the front of the drivers door.
'96 ZR2 S10 - SOLD
'00 Z28 Camaro - Daily Driver, Not Stock
'01 Silverado Z71 ECSB - Toy Hauler
Z28_ZR2 is offline
post #3 of 9 Old 01-29-2013, 02:32 PM Thread Starter
...mhmm
I also have that but it's simple to fix, just a little door tweaking will fix that.
Sent from AutoGuide.com App
post #4 of 9 Old 01-29-2013, 02:44 PM
the youngest has been
tippmann243's Avatar
User is: tippmann243 is offline
You could try adjusting the latch so that the door closes tighter.
-mark
89 s10 blazer 5.7 vortec/t56 0411 pcm powered
03 zr2 s10 with some mods
post #5 of 9 Old 02-04-2013, 12:13 AM Thread Starter
...mhmm
it isnt the door at all the door is flush, its the window in the third door i can reach back and pull it tight and the noise stops im just stumped on how to fix it
post #6 of 9 Old 02-05-2013, 03:17 PM
mike_dave's Avatar
User is: mike_dave is offline
What I did was I popped the door panel off and put some self drilling screws through it to pull it tighter. Works perfectly now!
post #7 of 9 Old 02-11-2013, 01:22 AM Thread Starter
...mhmm
self drilling screws? where did you screw them to keep the rear window tighter? very interested if you have any pics that would be great cause at like 70 it sounds like a jet is taking off next to me.
post #8 of 9 Old 02-12-2013, 03:37 PM
Tech Mod
beandip's Avatar
User is: beandip is offline
I cracked open the latch to that window a tad. It slightly tightens the window and stops the noise.
-Jonathan
2009 Harley Nightrain
beandip is offline
post #9 of 9 Old 02-13-2013, 04:12 PM
mike_dave's Avatar
Unfortunately I can't get you pics.. I've hurt my back and need to rest but I believe I put a few in.. I remember I drilled out the rivets with a pilot bit and put two in there, and then I put in two others.. to determine where they went I just looked at it to see where it needed more tension. If this is the route you take I suggest to only get them started with the drill, and tighten them by hand so you don't strip them. Good luck
