rear turn signal not working - S-10 Forum
post #1 of 13 Old 04-20-2012, 08:04 AM Thread Starter
User is: Crankbait09 is offline
OK, not sure how it is on other Chevy vehicles but I have a 2002 Chevy S10.
When one of my turn signals burn out my turn signal light in the dashboard blinks a lot faster and makes a fast clicking noise. Which alerts me when one of the bulbs needs replaced. So then I swap the bulb and all is well. The blinker light on the dash slows to the normal speed and the clicking noise is back to normal.
Just a few days ago, when turning on the right turn signal, the light on the dash started blinking fast to alert me. Right now it is the right, rear tail light that is out. (the front right turn signal works fine) I replaced the bulb, and nothing. Thinking I might have had a bad bulb, I switched the left bulb and placed it in the right....still nothing.
Obviously, it's not a fuse issue cause all other blinkers work fine.
What else could the problem be? How can I go about investigating further?
I can't figure out why it stopped working.
post #2 of 13 Old 04-20-2012, 08:40 AM
User is: knock9876 is offline
Re: rear turn signal not working
sounds like a grounding issue to me
post #3 of 13 Old 04-20-2012, 08:58 AM
Electrical Mod
deathphoenix99's Avatar
Could be a fuse, the rear tails are on separate fuses, check under the hood.
post #4 of 13 Old 04-20-2012, 10:01 AM Thread Starter
under the hood....hmmmm, didn't think of that. I only checked the fuse on the side of the dash........good idea. I will check tonight.
as for a grounding issue, how can that be? all lights work, tail lights work (except the right rear). wouldn't the ground issue cause the lights to work and then not work? (inconsistantly??)
post #5 of 13 Old 04-20-2012, 10:17 AM
Electrical Mod
SOmetimes a ground issue will cause intermittent, but normally a ground issue is either no contact or broken wire, therefore they won't work at all. But when this happens, it will usually cause a whole side to go out, or random lights to turn on dimmly when another light turns on (power backfeeding). This sounds more like a fuse issue rather than a ground one.
post #6 of 13 Old 04-20-2012, 10:28 AM Thread Starter
like i mentioned, i never thought of the fuses under the hood, i will check them tonight.
thanks again
post #7 of 13 Old 04-20-2012, 12:30 PM
AWD V8's Avatar
User is: AWD V8 is offline
Their won't be a fuse for just one brake light.
It's either an open in the harness, unlikely, or a bad combi-switch.
Not a bad ground, the ground would affect the park light as well.
My bet's on the combi switch. The brake light circuit goes through the signal switch so that when you step on the brake with the signal on you can have a brake on one side and a signal on the other. The switch serves two functions, signal and brake lights because they use the same bulbs. If the switch fails you can lose one function or the other to one side.
AWD V8 is offline
post #8 of 13 Old 04-20-2012, 01:44 PM Thread Starter
hmmmmm, would it be possiblef ro you to send me a picture of where this switch is OR explain it to me? I am not savvy on vehicle electrical work at all. Hoping this is something I can do myself.
post #9 of 13 Old 04-20-2012, 01:56 PM
Electrical Mod
Actually, if you look at a wiring diagram for 98+, they do separate the rear tail lights so that the left is on one fuse and the right is on another. The same with the parking lights. However, if the brake light works for the rear right side, then it is not the fuse, and something to do with the multifunction switch (turn lever, wipers etc....switch mounted to the steering column).
post #10 of 13 Old 04-20-2012, 02:02 PM Thread Starter
oh ok, i know what it is then.....how hard is it to install if it is infact the faulty switch?
post #11 of 13 Old 08-13-2016, 12:11 AM
User is: mackmobile43 is offline
There are 2 set of turn signal fuses, front and rear and that will cause the issue you're having, I know I just replaced a left rear fuse with the same symptoms and cured the problem and my issue was the result of a wire shorted in my trailer plug outlet.
post #12 of 13 Old 08-13-2016, 12:20 AM
Wrong there are fuses for front and rear all individual
post #13 of 13 Old 08-13-2016, 08:30 AM
I'm super serial
manbearpig's Avatar
Did you join the forum just to argue in a four year old thread?
WANTED: 98+ radio delete panel, antenna hole plug.
Crew cab airbag switch delete panel
