Rattle at higher rpm
I have a rattle at higher rpm if you get on it more then normail it does it in any gear but if you stay in it increasing the rpm from that point it stops its just around the rpm range it quits or if u let out of it... it sounds like a heat sheild or somthing but ever thing i can think of is tight.... what could make my truck sound like its flying apart??
got a new grille!
Re: Rattle at higher rpm
no clue but mine does the same thing lol and its annoying
err I know its kinda embrasing evertime i goto pass someone it does it ![]() |
Registered (Ab) User
Location: League City, TX (Houston) User is: OffLine ![]() |
Try putting higher octane gas in it for a while.
got a new grille!
its not pinging..it really is like a rattle lol
I had a bad low speed rattle once on my Blazer. Turned out to be a bad cat. Replaced the cat and the noise was gone. Try hitting your cat with a hammer or shaking it, and see if it rattles.
my truck had a rattle aswell and it was my cat it was broken in two, so try replacing it
yeah it kinda sounds like a head sheild but it sounds like my powerstearing pump cus it wines and gets its loudest right when it makes that sound....but my converter is starting to smell a bit....
its kinda like a hissing rattle are the magnaflow converters for our trucks just bolt on? cus I can get one cheaper than the local muffler shop charges to put on a universal cat. plus there not as restricked as most ( http://cgi.ebay.com/ebaymotors/MAGNA...spagenameZWDVW ) Last edited by t-scene : 08-06-2008 at 02:28 AM. |
got a new grille!
hmm mine rattles at higher rpms and sounds like a heat shield of some sort too..never checked the cat tho cuz i dont wanna dish out the money lol
03 s-10 mine did the same thing for till i put new spark plugs ac delco platinum
i had the same problem it was the heat sheild and it was hitting the bumper cuz some one taped us.
damned 4banger
mine has a rattle, but i replaced the catalytic converter, and the rattle is still there
I hate thieves
My "rattle" kicks in at 3500 RPMS and goes away at 4K. I can feel it in the gas pedal. I agree it's super embarrassing when I get on it to pass someone or merge on the highway. It's not the cat, just replaced with Magnaflow last summer and new Bosch plugs at the same time. I think it's the exaust manifold heat shield. I'm looking into it this weekend when I install my ASP pulleys and new radiator (hopefully a Taurus fan too).
Stock
mine does it too... I got no cat on mine, but I think it might just be the exhaust rattling.
1996 2.2l auto reg.cab DD
same here. mine is coming from around the tranny or around my feet. any one else have info from where you think it is coming from, when sitting in the driver seat?
The How-To Guy
Location: Cache, OK User is: OffLine ![]() ![]() ![]() ![]() |
It might be a long shot but check your flex pipe where it connects to the manifold, if the joint broke loose it could be your rattle.
ex. ![]() |
I had a rattle just like that.. came at higher revs... but it turned out to be not a loose heatshield or exaust flex pipe... it was the timing chain tensioner on my 2.2. Replaced the whole setup and run much better and loads quieter.
Just a thought.. |
just did that last saterday lol mine was the same damn thing! lol its nice now
No G/F=More Cash Moneys
mine did it, and it was a bad cat so i replaced it sounds a lot better and the rattle is gone, but my truck rattled at low rpms not high.
I thought that was animal cruelty. Mine meowed then hissed at me? Last edited by Jaynen : 11-21-2008 at 06:01 PM. |
i hit a lil pussy last night
