Overheat? Now wont start - S-10 Forum
post #1 of 15 Old 06-08-2009, 01:10 PM Thread Starter
User is: MrPab911 is offline
Over the winter I had heater problems(no heat) then summer came no air. In the winter temp was @150 deg. Summer its been running 200-225 deg.
Pulled in the driveway last night and steam came out from under the hood and I could hear the coolant bubbling. I bought a flush kit and ran some cool water through it this morning but it wont start, just keeps cranking but wont turn over.
Is this a blown head gasket? If it is blown with this engine better to replace engine or gasket?
Sucks becasue this is my work truck
TIA PAB
MrPab911 is offline
post #2 of 15 Old 06-08-2009, 02:16 PM Thread Starter
Re: Overheat? Now wont start
It looks like the HG.
Half turn on the oil plug and water was dripping out. I didn't go any further....
MrPab911 is offline
post #3 of 15 Old 06-08-2009, 02:18 PM Thread Starter
TIA PAB
Guess this is my #1 question now...
MrPab911 is offline
post #4 of 15 Old 06-08-2009, 05:37 PM
another half pint to go
Half_Pint's Avatar
User is: Half_Pint is offline
if it didnt get too hot, i would think just replace the head gasket. but not sure...
2OOO Xtreme......4/4 drop on 235's. SOLD
2OOO S10 ZQ8......stock for now.
1999 GMC Sierra ECSB Z71......7" lift, 315 AT's.
post #5 of 15 Old 06-08-2009, 05:41 PM Thread Starter
I dont think it did. It never got all the way over to hot.
I'm in the middle of trying to get the head off. Any links to instructions? The intake..s@*ks!
MrPab911 is offline
post #6 of 15 Old 06-08-2009, 09:46 PM Thread Starter
WOW, what a PITA!
The hayes book says push rods and rockers have to come off, is that so?
Well I'm up the exhaust manifold....2 more bolts, bottom back ones...yeah!
MrPab911 is offline
post #7 of 15 Old 06-09-2009, 12:22 AM
Half_Pint's Avatar
what size motor?
post #8 of 15 Old 06-09-2009, 08:44 AM Thread Starter
what size motor?
Sorry, its the 2.2l
MrPab911 is offline
post #9 of 15 Old 06-09-2009, 12:51 PM
threehouse's Avatar
User is: threehouse is offline
I know its kinda late to try this but when I drained my coolant, flushed the system (just used water to flush it) and refilled it I needed to fill it, drive it up the block and back, let it sit for like 30 min, then fill it again, I did this 2 times and it worked well with no overheating issues. Sometimes it needs to circulate the coolant all around the system.
The only way I knew to try this is I had a major prob on my bimmer which has a purge valve you need to let the air bubbles out of and need to rev the engine at like 2000-3000 rpm for like 30 sec, purge the system and repeat 3 times… Retarded I know it took me like a month and 3 times taking the front of the engine apart to figure it out… I know the s-10 doesnl;t have a purge valve and is a much simpler system but trying what I said above might work for ya… or maybe not and you have a different prob but yea…
For the q of engine or head gasket. I would say try head gasket its like say $50 fix at max if you do it yourself compared to like 300+ for a motor.
"Drive it like you stole it!"
post #10 of 15 Old 06-09-2009, 02:22 PM Thread Starter
Do you think its the HG?
MrPab911 is offline
post #11 of 15 Old 06-09-2009, 02:37 PM
southpawz's Avatar
User is: southpawz is offline
I would say yes with all the rust that has formed in the cylinders.... I would also take the head and get it checked out too to be sure it isnt cracked or warped.
post #12 of 15 Old 06-11-2009, 12:25 PM Thread Starter
The rust was light coat, just like brake rotors when rain hits them. Alittle motor oil and it wiped right out. I used a straight edge on the head and it was straight. No visible cracks or crazing..
I had to work these last 2 days...I'll finish friday.....and.....pray it works....otherwise off to the yard for an engine...
MrPab911 is offline
post #13 of 15 Old 06-13-2009, 12:41 PM
sweetS10's Avatar
User is: sweetS10 is offline
Send a message via AIM to sweetS10
it dosent seem like its the head gasket mainly because you didnt say anything about burning coolant,you blow a head gasket and you burn coolant and it looks like a cloud is comming out your exhaust and you dont have anymore coolant to bubble,when you flushed it out did you do it the correct way? cause there actually is a wrong and right way to do it.you might just have something stuck in there or the thermostat failed?
sweetS10 is offline
post #14 of 15 Old 06-13-2009, 01:05 PM
always something new
S10dude's Avatar
User is: S10dude is offline
you can burn coolant OR you get water in the oil like he said in post #2
if it was mine i'd have the head checked since it's off already
All truck pics
S10dude is offline
post #15 of 15 Old 06-26-2009, 12:12 PM Thread Starter
Well, I've put about 400 miles since replacing the HG and all seem well.. TG!!
I the best tip I found was to take the driver wheel well out. It made it much easier to get to the exhaust bolts(atleast getting them back in)
Thanks everyone
MrPab911 is offline
