Orange goop in radiator cap - S-10 Forum
post #1 of 16 Old 09-08-2013, 04:11 PM Thread Starter
User is: dunes_ny is offline
Hello all. I've been getting some weird orange goop in my radiator cap for some time now, the stuff even comes back a couple months after doing a coolant flush. Any idea what might be causing this? The photo off the cap was taken after cleaning it, that's how much stuff was caked on there. Thank you.
dunes_ny is offline
post #2 of 16 Old 09-08-2013, 05:36 PM
Sold :'(
s10xtremist's Avatar
User is: s10xtremist is offline
Re: Orange goop in radiator cap
After the flushes, are you putting Dex-Cool back in there? It could be leftover stuff still in the system that the flushes didn't break up, and it's breaking up over time and rising to the surface, which would pretty much be the cap. Flush it again and be sure it's thoroughly bled of air and topped off.
Getting better with every failure
Project threads:
Punching bag
Unicorn XJ
post #3 of 16 Old 09-08-2013, 05:42 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
Replace that cap too if you haven't already. You would be surprised how many I come across that don't hold the proper pressure anymore.
TelAmeriCorp
post #4 of 16 Old 09-08-2013, 06:18 PM Thread Starter
No dex-cool. I have been getting rust-colored fluid before flushing. I never used distilled water when adding coolant, but now I am going to switch to distilled water from now on, but I first need to know where all this junk is coming from so I can fix it if necessary.
dunes_ny is offline
post #5 of 16 Old 09-08-2013, 06:37 PM
Sold :'(
Use regular water from your garden hose when flushing. When you've drained it for the last time and and are about to fill it up with whatever you're gonna run in it, fill it with distilled and run it again, then drain. THEN fill it with the bottles of pre-mixed coolant. Using this guarantees you're getting a 50/50 mix with distilled water. I agree about replacing the cap.
Project threads:
Punching bag
Unicorn XJ
post #6 of 16 Old 09-08-2013, 07:18 PM
B4U Task Force
Rhotpursuit's Avatar
Chevy has an updated cap (several years ago) to replace the old caps with. They have yellow printing on them so it's easy to distinguish.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #7 of 16 Old 09-08-2013, 10:11 PM
User is: Alsuchy is offline
IMO: this looks like oil getting into coolant. Possible causes, crack in block leaking head gasket. Not always does water show up in the oil with a leaking head gasket. If you are getting excessive off white gunk on the oil filler cap also then this is most likely the problem. Do you know if there has been stop leak put in the coolant? That may be flushing out. To check for a leak @ the head gasket remove radiator cap (cold) run and watch for bubbles or gurgling, indicating exhaust being forced into the cooling system. Also check over flow tank for a black oily film, this is another sign of the same problem. These checks are not fool proof but don't cost anything. Compression leak down test can indacate this also, but you must be able to interpret the results because it can show other things as well.
My ram had much the same crap going on. Leak in head gasket, also had stop leak in it which made the mess worse.
Do use distilled water and dex cool as the the hard water from most taps isn't good for engines containing aluminum, or any for that matter. Bi metal corrosion, calcium deposits when the hard water gets hot and redeposits in the smaller passages in the engine and radiator.
Alsuchy is offline
post #8 of 16 Old 09-20-2013, 11:49 PM
User is: uhlya is offline
I'm sort of a noob at this but I am having a similar problem... (oily film in overflow tank) their was also a little water knocked out of the spark plugs, my truck won't start but it sounds like it wants to...I'm thinking if just pulling off the head and send it to get shaved and checked for cracks...any advice it's appreciated..
uhlya is offline
post #9 of 16 Old 09-21-2013, 06:20 PM
8/31/1897 - 4/29/2004
BravadaX's Avatar
User is: BravadaX is offline
#1 be careful of the "girls" in Thailand aka check for proper equipment before rental.
#2 down the hatch,not in the snatch.
#3 don't put your mouth on it,you don't know where it's been.
#4 take it to a shop
I turned mine into an Oldsmobile, bitches love Oldsmobiles.
BravadaX is offline
post #10 of 16 Old 09-21-2013, 07:44 PM
B4U Task Force
Apple Red 96 SS
post #11 of 16 Old 09-21-2013, 07:50 PM
slamburger
koeberle04's Avatar
User is: koeberle04 is offline
im getting this tattooed across my waistline in between my peepee and button hole
Neil
2000 - S10 - 2.2 - Vin 5 Flex - RCSB - Auto - 115k
post #12 of 16 Old 10-02-2013, 11:27 AM Thread Starter
Hey everybody just wanted to say thanks to those who tried to help. This repair turned out to be a great success. I took out the thermostat, pulled the drain plug (a pain literally and figuratively) and flushed that bad boy until the brown goop surrendered. Now I have nice clean green coolant and no orange goop.
My moral of the story is that radiator flushes are bull-shite. If you want to clean your cooling system flush out the engine block.
dunes_ny is offline
post #13 of 16 Old 10-02-2013, 06:14 PM
B4U Task Force
If you flush correctly, the engine gets flushed also...along with the core. Glad it worked out.
Apple Red 96 SS
post #14 of 16 Old 10-03-2013, 08:29 AM
User is: Cleatus is offline
question---should we use Dex or green in these old-ass trucks?
Cleatus is offline
post #15 of 16 Old 10-03-2013, 09:05 AM
B4U Task Force
If you are good about maintaining it..Dex...I would use green anyways.
Apple Red 96 SS
post #16 of 16 Old 10-03-2013, 02:45 PM
Check your ground
556mm's Avatar
User is: 556mm is offline
I use green.
556mm is offline
