Oil Pressure High
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 08-04-2008, 07:04 PM   #1
aconklin is on a distinguished road
Oil Pressure High
My oil pressure has been sky rocketing past 80 when I first start the truck up until the engine temp reaches 210. As soon as the engine is warm to 210 it stays between 30 but if I get down on it say around 4000 RPM the needle goes to about 60-70. The engine sounds fine. And my last oil change was about 2000 miles ago with mobile oil. The truck is a 2002 S-10 with about 56,000 miles. Do you think it is a sensor? Or?????
Old 08-04-2008, 10:28 PM   #2
southpawz's Avatar
southpawz is on a distinguished road
Re: Oil Pressure High
Seems about right to me....mine does basically the same thing and it has 155,000 miles on it
Old 08-04-2008, 10:33 PM   #3
addicted... to RC !
xdude2001's Avatar
xdude2001 will become famous soon enough
you using 5/30?wt...higher wt will give you more pressure......
Old 08-05-2008, 04:18 AM   #4
yea i'm using 5-30. so with the oil pressure going to around 120 i shouldn't worry about it? Just let it warm up I guess before I take off
Old 08-05-2008, 06:37 AM   #5
southpawz's Avatar
Mine doesnt get that high at startup.... first thing in the morning when I start mine it will get right at 80 when I take off until it warms up then it is around 60-65 while driving and around 35 or so at idle.
Old 08-05-2008, 04:05 PM   #6
Registered (Ab) User
Yogi's Avatar
Yogi is on a distinguished road
If the pressure is really going to 120 psi, you could blow the filter housing and loose all of you oil, and make one hell of a mess too. First thing that I would do is replace the oil pressure sending unit. If it does the same thing with a new sending unit, you may have to replace the oil pump - not an easy job.
Old 08-10-2008, 11:20 AM   #7
pakirsch2005's Avatar
pakirsch2005 is on a distinguished road
wow 120 my 95 hits 80 at start then stays at 60-65 it has 160,000 on it
Old 08-10-2008, 02:26 PM   #8
Teamgeek6 is on a distinguished road
BAD. Shouldnt get much past 60. 80 (correct me if incorrect) is the end of the gauge reading? The only two things that can cause runaway pressure are stuck bypass piston in the pump (has one?) or a restriction in the pump output. 5 - 30 is thin, im using 10-40 at 210000 miles and pressure goes to 60 -ish cold.
Old 08-10-2008, 03:00 PM   #9
Yogi's Avatar
Yeah, my gauge only goes to 80 so I wonder where he's getting 120 from?
Maybe we've been punked?
Old 08-18-2008, 08:34 PM   #10
Well mine only goes to 80 to but it burys past 80 so im just saying 120 who the hell knows it could only be 100 and no its not no punked thing
Page generated in 0.11199 seconds with 11 queries
