New starter/ new Flywheel grinding - S-10 Forum
post #1 of 4 Old 10-21-2011, 08:25 AM Thread Starter
Nrethemeyer's Avatar
User is: Nrethemeyer is offline
Hey Guys and Gals,
I recently had my '98 S-10 4.3l v6 vin x raised from the dead.
Truck had been sitting for a little over 2 years waiting for my brother to do something with it.
I had my parents replace the engine to get it running again so I could buy it from them. The engine runs beautifully, nice and smooth, no jumps or drops in rpms, and nice and quiet. So started drive home from Ft Lauderdale to Orlando...
Thats where the issues started...
The engine was replaced with another 4.3l from a salvage yard. Problem 1 was difference in mounting bolts for starter, old bolts were metric, engine was drilled for standard. I'm thinking the mechanic unwittingly swapped a vin x and a vin z engine, but both have same flywheel/starters listed at advanced.
Next issue was the guy left some of the tranny bolts out so it was only mounted with 3 instead of 8. After having starter and flywheel eat each other I had them replaced and that was when I found out about the missing bolts.
Current issue is the new starter and flywheel are still grinding and it struggles to turn over. The truck is throwing a bad crankshaft sensor code and I'm hoping that is the underlying issue.
Any Ideas?
'98 S10 4.3l v6 Vortec
post #2 of 4 Old 10-21-2011, 08:36 AM Thread Starter
Re: New starter/ new Flywheel grinding
To get a bit more in depth into starting issue, It doesn't grind at first. It engages just fine first few attempts, then starts grinding and chunking. Almost like the flywheel is engaging, but the engine can't figure out which piston to crank on. Eventually it does start though.
post #3 of 4 Old 10-21-2011, 10:56 AM
love to work on my truck
Jons1995s10's Avatar
User is: Jons1995s10 is offline
sounds like maybe a shim in the starter might help
1995 S10 LS 4.3 vortec 136k 1" block on back front stock, 4 wheel disc brakes gt4/g80 rear diff
2000 Blazer LT 4.3 Vortec
2001 Chev Silverado 4.8 Vortec 2wd 47K miles Wicked Flow exhaust K&N cold air intake moon visor
Keep on Minitruckin'
post #4 of 4 Old 10-21-2011, 03:09 PM Thread Starter
I thought that but shimming results in no change. It doesn't seem to be hitting the flywheel, as it doesnt start grinding til 3rd or 4th attempt. The first and second attempts to start are clean, but usually unsuccessful. Will see what happens after I replace the crankshaft position sensor.
