need help clearing the engine bay
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 08-17-2008, 04:52 PM   #1
dragz is on a distinguished road
ok so i picked up a second gen and so far im not too into it with all the wires everywhere... first gens much easier...
anyway i pulled out all the a/c and heater parts and im looking for some help from some guys who have built their second gens and what wires they took out. where they relocated the computer and other "junk" under the hood, and cutting off the heater core from the engine?
i am about to bag this truck so the sooner i can get some help on this matter the better.
thanx guys.
Old 08-17-2008, 05:14 PM   #2
Happy with ugly truck
Buddha..'s Avatar
Buddha.. is on a distinguished road
Re: need help clearing the engine bay
e-fan and intake make some room under the hood. As for the wires and computer, i'm interested too.
Old 08-17-2008, 05:56 PM   #3
yeah ive already got that stuff taken care of and the ecu im planning on bolting against the firewall after i weld up all the holes from the blower motor.
im also wondering about the clutch master cylinder and the wires feeding in on the driver side right above the front wheel.
Old 08-17-2008, 10:34 PM   #4
SAS inprogress
zhillz's Avatar
zhillz is on a distinguished road
Im suprised wire tucks arent all over the place with yalls trucks looking so clean and a wire tuck is just sex it looks like the motor isnt even wires up. I did this on my civic you pretty much just extended the wires and place the somewhere else like your glovebox/underdash area.
NOT MINE
Old 08-17-2008, 11:53 PM   #5
1994sdime's Avatar
1994sdime is on a distinguished road
my bay not that clean but it works
Old 08-18-2008, 12:14 AM   #6
JSamsS10's Avatar
JSamsS10 is on a distinguished road
Whered the shroud piece come from ^^
Old 08-18-2008, 01:32 AM   #7
________________
Merritj2417's Avatar
Merritj2417 is on a distinguished road
My guess is it's custom made.
Old 08-18-2008, 07:54 PM   #8
yeah ive been out in the garage doing my best to sort through the mess of what everything is and im slowly making progress....
what are the 4 relays at the top of the firewall right above the engine?
Old 08-18-2008, 08:40 PM   #9
94 2.2, feel the power?
deathphoenix99 is on a distinguished road
blower motor and a/c relays.
Old 08-19-2008, 07:05 PM   #10
SCRREEECH!!!
****in brakes lol
aight this project just came to a screaming hault
just found out im havin a kid so the project and all the parts i have gotta go.
thanx anyway
Old 08-19-2008, 08:55 PM   #11
SAS inprogress
zhillz's Avatar
Old 08-21-2008, 07:20 PM   #12
haha funny
but we're not teens either
lol
college grads with good jobs
Quote: Originally Posted by zhillz
Old 08-22-2008, 10:48 AM   #13
SAS inprogress
zhillz's Avatar
i didnt make the moti so ...lol.
congratz man hope everything works for yall!
Old 08-22-2008, 03:27 PM   #14
where's ur ecu?
Old 08-22-2008, 03:51 PM   #15
SAS inprogress
zhillz's Avatar
Quote: Originally Posted by dragz
where's ur ecu?
thats one of the easiest things to move its probably in the cab.
Old 08-22-2008, 05:17 PM   #16
yeah i was planning on bolting mine to the firewall where the blower box was because i heard they have a tendancy to over heat so its better to keep it outside the cab
Old 08-28-2008, 07:05 PM   #17
SAS inprogress
zhillz's Avatar
the engine bay is hotter then the cab it just lacks air movement but it isnt a problem with civics i would imagine most would be ok including ours.
Old 08-28-2008, 10:14 PM   #18
ok the project is back up and running just going to be moving a bit slower at the moment
BUT..... who has removed their heater and how did you block off the 2 lines on the engine that run off the heater core?
Old 08-29-2008, 11:15 PM   #19
AcrophobiA MilitarY LOL
STEN_(d_slammd_1)'s Avatar
STEN_(d_slammd_1) will become famous soon enough
Just run a peice of hose connecting the 2 ports
Old 08-29-2008, 11:17 PM   #20
where's ur ecu?
Not 100% sure but that looks to be a carbed motor (AKA no ECU)
Old 08-30-2008, 11:58 AM   #21
Registered (Ab) User
Yogi's Avatar
Yogi is on a distinguished road
Take off the hoses and unscrew the hose barb fittings (lots of PB Blaster). I believe that the threads for the fittings are just 3/4 IPS (Iron Pipe Size). Just plug 'em with pipe plugs from the hardware store. Maybe Dorman makes some cooler plugs that are Allen hex head instead of square pipe plug head.
Old 09-05-2008, 12:50 PM   #22
yeah the top can be closed off by a screw in plug but the bottom side is a clamp on hose just like the radiator hoses..... how about that one?
Old 09-05-2008, 12:58 PM   #23
Yogi's Avatar
It looks like that one is pressed into the water pump. Get a rubber cap. If you can't find one, make one out of a short piece of hose and a 3/8" pipe plug. Hose clamp both ends of the hose.
Old 09-05-2008, 02:23 PM   #24
thanx dude....
ill let you know how it works out.
Old 09-05-2008, 02:25 PM   #25
Yogi's Avatar
thanx dude....
Cool!
Old 09-10-2008, 12:57 PM   #26
dimedragn's Avatar
dimedragn is on a distinguished road
what are the 4 relays at the top of the firewall right above the engine?[/quote]
So these relays are blower motor and A/C relays. If I got rid of all that then I can pull those wires then right?
Old 09-10-2008, 05:35 PM   #27
So these relays are blower motor and A/C relays. If I got rid of all that then I can pull those wires then right?[/quote]
i just tucked mine into the wire loom just in case
helps keep in clean and they are still there just in case i need them
pics will be up soon
just have to get the firewall smoothed and mount the ecu where the blower motor used to be and also hook up my prop valve and residual valve for the brakes (FYI dont ask auto zone or advanced for a prop valve because they have no clue what one is..... morons)
Old 09-11-2008, 12:40 AM   #28
dimedragn's Avatar
just have to get the firewall smoothed and mount the ecu where the blower motor used to be and also hook up my prop valve and residual valve for the brakes (FYI dont ask auto zone or advanced for a prop valve because they have no clue what one is..... morons)[/quote]
Yeah I don't think I am gonna need mine since I have no A/C and don't plan on putting it back in.
Page generated in 0.20943 seconds with 11 queries
