Leaking Intake manifold gasket, 2002 S-10, 4.3L - S-10 Forum
post #1 of 27 Old 11-28-2007, 06:11 PM Thread Starter
User is: marc515 is offline
How many of you guys had to replace the intake manifold gasket on your S-10's due to it leaking?
I had to do mine on my S-10, 4.3L at 61,000
I've read on the web that Dexcool caused gasket problems.
Thank you,....marc
marc515 is offline
post #2 of 27 Old 11-28-2007, 06:34 PM
Boards don't hit back
00s104.3's Avatar
User is: 00s104.3 is offline
Re: Leaking Intake manifold gasket, 2002 S-10, 4.3L
My brother-in-law and I replaced mine on my 2000 back in February. Not too difficult of a job.
I don't know if dexcool was the problem or not. I was just driving to work one day and the engine started feeling sluggish and then died. I had it towed home after work and started checking it out and saw the sludge on the dipstick. I knew what it was immediately.
When we took the intake manifold off this is what we found...
By the time you realize this doesn't say anything it's too late for you to stop reading it.
00s104.3 is offline
post #3 of 27 Old 11-28-2007, 08:06 PM
I AM CANADIAN
tt85_GM's Avatar
User is: tt85_GM is offline
I replaced mine at about 81,000mi, it was leaking at the front just behind the A/C compressor, it had the factory gasket and I used a Fel-Pro gasket, it's a strong metal base with big rubber openings, and I will say use that one, because alot of people do without any problems.
Make sure you torque up the bolts in 3 steps to the proper torque and don't mess up the sealant you have to use on the ends when you place the manifold back on because it will leak if it is not a good seal.
-'02 Jimmy 2dr 4x4, 2" lift & 31's
-'08 Altima coupe
-2000 Sonoma, 4.3L, polished ZQ8's- SOLD
Polishing ZQ8's thread:
http://www.s10forum.com/forum/f14/po...roject-366831/
Leather Seat Swap: http://www.s10forum.com/forum/f26/leather-seat-swap-346677/
tt85_GM is offline
post #4 of 27 Old 11-30-2007, 09:32 AM
I am a LAZY BITCH
scooters355s10's Avatar
User is: scooters355s10 is offline
Send a message via AIM to scooters355s10
Its a very common problem on these motors. Just did mine at 49,000 miles. Dont know if its the dexcool that does it or just a poor choice in the material that the gasket is made out of. But the replacement upgraded fel-pro gaskets should last alot longer. But i would recommend if anyone does replace anything cooling system wise to flush out the dexcool and put in regular green antifreeze cause gm did find out that dexcool promotes corrosion to aluminum parts. Thats y they dont use it anymore. So ive been told by a gm tech.
1992 gmc sonoma gt #543 lowered 6/5 cowl hood soon to be bagged!!!!!!!!
post #5 of 27 Old 11-17-2010, 03:08 PM
BATMAN's Avatar
User is: BATMAN is offline
I'm looking at buying a 2002 with the intake manifold gasket leak and bad cats.
If there was a leak would that cause major problems with the rest of the engine?
2005 GTO Maggie, Kooks LTH, Lingenfelter intake, Forged engine, ceramic coated heads, Magnaflow X-pipe, Koni shocks with King Springs, Addco Sway bars, SS-braided brake lines with EBC Red Stuff pads.
1993 NSX Kenne Bell 2.1, Laminova, Tien EDFC, Adjustable Sway Bars, K&N, Headers, X-pipe exhaust, HID high/low, PIAA HID driving lights, 17/18 Enkei RP03, APR GTC 300, chassis bar
BATMAN is offline
post #6 of 27 Old 11-17-2010, 05:08 PM
tech n9ne listenin member
Einstein's Avatar
User is: Einstein is offline
Send a message via AIM to Einstein
Sorry to jack your thread but I think im about to tackle the same repair.. I just had a question
Is it possible for the coolant to leak inside the engine, and not mix with the oil? I have disappearing coolant and my oil looks fine but the level is very high.. What are the chances that this is a cracked head and not a lower intake manifold gasket? Thanks and sorry again
Originally Posted by orangesonoma View Post
this guy claims he is going to shoot him self and people talk about taco bell
Einstein is offline
post #7 of 27 Old 11-19-2010, 05:17 PM
00 gmc sonoma owner
drew_budr's Avatar
User is: drew_budr is offline
I had the same problem at 40,000 miles in a 2000 sonoma 4.3. Turns out it was the bolt in the intake behind the a/c compressor. When it came loose somehow it caused the plastic intake gasket to melt and eventually crack. I lost about a gallon and a half before i noticed and water in the oil, but when i did the oil looked like butterscotch pudding.
post #8 of 27 Old 04-15-2011, 12:59 PM
BATMAN's Avatar
I'm looking at buying another S10 and the owner said that at 110k miles he developed an intake manifold leak and there was a ticking sound too.
Any ideas if what that might be?
BATMAN is offline
post #9 of 27 Old 04-15-2011, 03:51 PM
User is: 1997ZQ8 is offline
I just changed mine at 253,000. It was leaking at the corners, but never got into the oil. The plastic around the water passages crumbled. I haven't used Dexcool since '99.
1997ZQ8 is offline
post #10 of 27 Old 04-16-2011, 08:56 PM
Overhead Console Expert
Raven's Avatar
User is: Raven is offline
Send a message via AIM to Raven
Changed mine at 95K. It was leaking into the oil, and down the tranny bellhousing. Its not that bad if your mechanically inclined....its just time consuming.
And its not totally the Dexcool. Its part dexcool, part faulty plastic that makes up the gaskets. GM has since redone there gaskets with a new metal frame to deal with the degrading plastic issue.
1999 S10 4.3L Zr2
Overhead Console Dude
Raven is offline
post #11 of 27 Old 04-21-2011, 02:05 AM
bagddime's Avatar
User is: bagddime is offline
notorious s10 problem. i replaced mine at 100xxx miles on my 98. leaked in front as well. took me 4 hours.
bagddime is offline
post #12 of 27 Old 04-21-2011, 05:10 AM
Vig Pimpin
viggy58's Avatar
User is: viggy58 is offline
coolant CAN leak straight into the intake chambers and mix with the fuel. you'd prob see some smoke though... one way to tell. pull your plugs. if they look "clean" instead of carboned/burned/used, you prob have coolant leaking into the combustion chamber.
if coolant is in the oil, it will mix, and you'll def be able to see it.
___________________________________________
2001 Blazer
4.3L 5 speed manual trans, 2wd
180k miles
ALL STOCK!
Profile Baja amp, 100w x4
Sony Xplod 1000w x1
Alpine type R 12in. sub
viggy58 is offline
post #13 of 27 Old 08-14-2011, 09:31 PM
Einstein's Avatar
My coolant is leaking somehow into my motor. But it doesnt mix with the oil to create the "milkshake" like most have. when i remove the drain plug, the oil comes out first, but then suddenly turns into coolant. can anyone explain why they dont mix together?
Einstein is offline
post #14 of 27 Old 08-15-2011, 03:16 AM
Vig Pimpin
viggy58's Avatar
probably just has to do with the type/brand of coolant you are using. if ANY coolant is coming out of the oil pan, you have a major problem (intake gaskets and/or head gaskets) that needs to be fixed asap. i wouldnt drive it until it is fixed.
how do you know coolant is in the oil. is it obvious when you drain the oil. can you give us a pic, or a better description of what you're seeing?
2001 Blazer
180k miles
ALL STOCK!
Sony Xplod 1000w x1
viggy58 is offline
post #15 of 27 Old 08-22-2011, 09:52 PM
Einstein's Avatar
Its obvious. As in... Oil comes out... then brand new coolant like its being poured out of a jug, lol. And im not driving it. Its just sitting. Probably just going to sell it how it is to get it out of my garage.
Einstein is offline
post #16 of 27 Old 09-20-2011, 03:49 PM
Mcfly Minis inc
Mcfly Minis's Avatar
User is: Mcfly Minis is offline
Send a message via AIM to Mcfly Minis Send a message via Yahoo to Mcfly Minis
I just did mine at 160,000. Wasn't too bad, the worst part was cleaning out all the butterscotch oil from everything. All four corners were shot. I ended up doing 2 oil changes within an hour of getting it back together. Everything seems fine now.
post #17 of 27 Old 09-20-2011, 06:45 PM
Real Men Wear Bow Ties.
vinster888's Avatar
User is: vinster888 is offline
This issue is typical with almost all GM motors from this period. Changing the gasket and using green antifreeze is the suggested repair. Dex-Cool was known for causing premature failure of intake gaskets by dissolving the gasket material. Supposedly the formula was changed but, I would not trust it with an enemies motor. Let alone my own. I have had three motors with this same issue and the suggested fix has been holding up just fine. More than 100000 miles later.
'99 S10 LS Extended Cab 4.3L V6
post #18 of 27 Old 09-22-2011, 01:26 AM
Vig Pimpin
viggy58's Avatar
exactly like mine, (same spot for the leak) but mine made it to 140k
2001 Blazer
180k miles
ALL STOCK!
Sony Xplod 1000w x1
viggy58 is offline
post #19 of 27 Old 11-21-2011, 05:03 PM
BJames32's Avatar
User is: BJames32 is offline
yeah mine is leaking at 122,000 but i am doing my manifold and value cover gaskets to at the same time. it just seem to be easier
BJames32 is offline
post #20 of 27 Old 11-21-2011, 06:58 PM
User is: Sonoma995 is offline
Felpro Gaskets for the win.
its a normal problem with the 4.3's and the 5.7's. did the tahoe a few months back. pretty straight forward.
SOLD! 95 Novada 2.2 5sp
post #21 of 27 Old 11-25-2011, 01:05 AM
Take a back road
User is: may22 is offline
My 2000 s10 zr2 stutters at low rpm and more so when it is cold and gradually getsw better throughout the day. i know i need an intake gasket repair. the CMP retards to -14, shouldnt this be around 0 ? Would that make the engine stutter? the service engine light all the cyclinders are misfiring. can anyone help? thanks
may22 is offline
post #22 of 27 Old 11-26-2011, 11:11 AM
User is: rickettes is offline
i have a 1997 s10 with a 2.2 liter and its ticked ever since ive had it, i bought it with 94,000 miles and its got 137,900 now runs as good as ever
post #23 of 27 Old 07-04-2013, 04:35 AM
User is: brickfollett is offline
For my 2002 S10 2.2L vortec, I got the Volant intake for $170. Very happy with it. Nice sound and seemed to add a little extra HP. Also did the Taurus fan mod. well worth it. Considering upgrading the alternator to an AD244 and doing the big 3 upgrade
post #24 of 27 Old 01-25-2016, 10:27 PM
User is: daddyreno is offline
I have a 2001 S-10 with 4.3. Replaced the water pump but wasnt the problem. It appears to be leaking behind the altenator. Could this also be the intake gasket? Please help. My brother is going to take off altenator tomorrow.
post #25 of 27 Old 01-26-2016, 01:16 AM
User is: lmleck is offline
That is what mine looked like. Coolant seeps from the corners of the intake manifold showing up as drips, or leaks into the motor oil, causing damage.
2003 sonoma 4.3l.
lmleck is offline
post #26 of 27 Old 01-27-2016, 12:05 AM
rgrah01's Avatar
User is: rgrah01 is offline
Same here, 2002 w/130k before she started leaking behind the alt at the corner of the manifold, it was about to start leaking onto the cam, at two different points..... It's a combo of a really crappy gasket and dexcool. Def spring for the Fel-Pro upgrade, you'll clearly see the difference in quality! Pretty straight forward, I had a hard time getting the damn wiring harness out of the way, other than that easy. Take your time and torque everything correctly!
rgrah01 is offline
post #27 of 27 Old 02-01-2016, 03:32 PM
gamefoo21's Avatar
User is: gamefoo21 is offline
Dexcool has changed it's formula, it no longer carries a plasticizer in it. Be careful though, the Prestone formula last I checked still carried the plasticizer in both their Dexcool and universal replacement version. At a local dealer they had both versions of Dexcool on the shelf.
I use a long life mixed fleet diesel/gas HD antifreeze that works really well for me.
An important thing to do is to check the 'warning' label if it has anything but ethylene glycol listed, and it's a salt(can't remember the name at the moment), it's got the plasticizer and you should not use it.
