Intermitent blinking battery light!! - S-10 Forum
post #1 of 12 Old 02-06-2011, 01:41 PM Thread Starter
damn it! not again!
Blue S10's Avatar
User is: Blue S10 is offline
Question Intermitent blinking battery light!!
i have a 01 chevy s10 v4 4.3
I was on a long road trip. Out in the middle of no where my battery light started intermittently going on and off. I immediately checked the volt meter. It was normal at 14v. I keep driving. They light eventually stopped coming on. About 150 miles later the light started doing it again, this time the volt meter had dropped about 11-12 volts. I was still about 120 miles from home so I turned off my stereo, my AC. I was determined to make it home. I made it home. I pulled out the alternator and had it bench checked. They guy at Napa said that it was bad so I replaced it.
After I replaced it I thought that would fix the problem but it didnt. I just got the new aternator installed and went for a short drive. The battery light is still intermittent. The volt meter in the truck reads 14-16. When I turn on everything, AC on max, Stereo and Lights on bright, it drops down to 14v but never drops lower. So the alternator is working but what could cause the battery light to be intermittent. When I say intermettent I mean that it comes on for 3 seconds, goes out for 5, comes on for 2 seconds, going out for 3. Its always coming on but never in a constant pattern.
i put a new battery in aswell but still nothing! WHAT IS CAUSING THIS???
life is a biach, i'm just playing on the sand.....
Blue S10 is offline
post #2 of 12 Old 02-06-2011, 08:52 PM
B95
Early Member
B95's Avatar
User is: B95 is offline
Re: Intermitent blinking battery light!!
You can't completely go by what you alternator gauge is showing. It is just a ballpark figure. Double check you battery connections and battery cables. Even though you bought another alternator doesn't mean it can't be bad. Also check the serpentine drive belt, excessively worn belt can affect the alternator output. One more thing check your alternator wiring.
1995 Black S-10 X-Cab 4.3 CPI. '96 Jimmy 4dr Power-leather seats(converted to flip forward). '98/99 Bravada headlights and grille. Envoy bumper cover and fog lights. 2" drop spindles. Headlight wire upgraded with relays. Blazer floorshift. '96 Blazer leather steering wheel and air bag. '96 Jimmy leather door panels.
B95 is offline
post #3 of 12 Old 02-07-2011, 07:31 AM Thread Starter
damn it! not again!
Blue S10's Avatar
i went out and got my new alternator and battery tested at 4 diferent places and was told they were fine, i cleaned the battery terminals, and the belt seems to be fine, what else can i check?
Blue S10 is offline
post #4 of 12 Old 02-08-2011, 12:32 AM
B95
Early Member
B95's Avatar
Well, your electrical sytem is only a 12v sytem. Trace all of your cables to and from your battery. Make sure they are good. Double check you wiring at the alternator. A wire may be hooked up wrong. If you have the old alternator, compare it to the new one. You could have a alternator that is wrong for your application. I never get a new part without comparing new to old.
B95 is offline
post #5 of 12 Old 02-08-2011, 12:35 AM
B95
Early Member
B95's Avatar
Oh, btw, You state your vehicle is '01 v4, 4.3. What is the v4?
B95 is offline
post #6 of 12 Old 02-09-2011, 03:25 AM
B95
Early Member
B95's Avatar
Thought about your issue last night. Have you checked the fusible link and battery junction block? These might also be causing the problem. Fusible link is inline with the battery. According to the repair manual there are 2 fusible links.
B95 is offline
post #7 of 12 Old 02-09-2011, 05:57 PM Thread Starter
damn it! not again!
Blue S10's Avatar
ive been pulling my hair off trying to find a solution!! i had a squequing noise so changed the belt, tensioner and pulley so the noise is gone. lately sine ive been messing with it i have been having problems with the rpms after a reconnect the battery it shuts off when i put it in gear but after about 4 times it back normal. could this be part of the problem? how can i go about fising it? THANKS A BUNCH FOR THE HELP!!!
Blue S10 is offline
post #8 of 12 Old 02-09-2011, 06:22 PM Thread Starter
damn it! not again!
Blue S10's Avatar
i forgot to mention that i put a blazer alternator in, could this be causing all this problems too?
Blue S10 is offline
post #9 of 12 Old 02-10-2011, 12:54 AM
B95
Early Member
B95's Avatar
The alternator for a blazer should be the same.
B95 is offline
post #10 of 12 Old 02-10-2011, 04:28 PM
B95
Early Member
B95's Avatar
I went looking today for Tech. Service Bullentin for my truck and yours, dealing with the battery indicator light. There is a TSB for our trucks. I don't know how much good this will do. But the TSB is #3130, issued Jan.01,2004. I just googled TSB 2001 Chevy S10.
B95 is offline
post #11 of 12 Old 02-10-2011, 05:09 PM Thread Starter
damn it! not again!
Blue S10's Avatar
the rpm problem got really bad now, to the point I can't pull out of my driveway so I'll try and clean the iac and hope for the best
Blue S10 is offline
post #12 of 12 Old 02-10-2011, 08:01 PM
B95
Early Member
B95's Avatar
Also check your EGR valve.
B95 is offline
