Intake manifold or head Gasket? - S-10 Forum
post #1 of 11 Old 04-15-2012, 12:09 PM Thread Starter
User is: TreeFiter is offline
I've got a 96 Sonoma with a 4.3 that has a coolant leak under the A/C compressor. I put radiator pressure test on it and I could hear it hissing from under the compressor. When I pulled it off, it was all rusty looking like it had been leaking coolant too. It looks like it is right at the front corner of the head, but it also looks like the intake manifold stops there too. So I'm wondering if there is a way to tell if it is the intake manifold gasket or the head gasket that is leaking?
post #2 of 11 Old 04-15-2012, 12:44 PM
Catrell92's Avatar
User is: Catrell92 is offline
Re: Intake manifold or head Gasket?
Is the thermostat housing in that general area because i think someone posted onthis issue before and thats what it ended up being... Housing to block gasket,
My LSX Swap- http://www.s10forum.com/forum/f213/f...swap-o-504055/
98 Noma Stepside ECSB
2/3 on ZQ8
5.3 LSx Swap- 228r- 3.73 Ford 8.8- 4L80e-Circle D 3200 Stall- midmount on3 76mm Turbo
post #3 of 11 Old 04-15-2012, 01:43 PM
LOG
LOG's Avatar
User is: LOG is offline
id say intake manifold gasket thats were my leak was on my 2002 s10 4.3.
you learn the true meaning of life when you see houses and cars blow by like leaves on a windy day.
LOG is offline
post #4 of 11 Old 04-16-2012, 05:54 PM
goin broke but n style
S15vortecpwr's Avatar
intake. My blazer was leaking external there also. My blazer was also leaking internal as well.
if you have choc milk as oil. DO NOT DRIVE IT. ENG DAMAGE WILL OCCUR.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #5 of 11 Old 04-16-2012, 10:35 PM Thread Starter
No foam in my oil. Only symptoms I had were overheating and hard starting. Overheating was likely gunked up cooling system. It took me about 10 hours of flushing to get it halfway clean. It only leaks from that spot when i put the pressure test on it, and when its overheating and boiling off. I am trying a stop leak and hoping it helps. I guess I'll know if it worked tomorrow when I drive it.
post #6 of 11 Old 04-17-2012, 01:23 AM
Outhet's Avatar
User is: Outhet is offline
When you say hard starting, describe what it does. Does it start and run rough for 5-15 seconds when you start it and it clears up? If so, the intake gaskets are probably leaking into the cylinders and need to be replaced.
Outhet is offline
post #7 of 11 Old 04-17-2012, 03:46 PM Thread Starter
It takes a bit of cranking before it starts. Sometimes 10-15 revolutions before it fires. Sometimes it will start as soon as you tap the key. When it starts hard, there is a second or two of hesitation before it runs right. I think the general consensus is that I need an intake manifold gasket.
Is there anything else I should be thinking about doing while I have everything apart. This is a 200k mile truck.
post #8 of 11 Old 04-17-2012, 03:52 PM Thread Starter
By the way, the stop leak didn't work. Looked promising last night. It ran for a few hours and stayed at a good running temp (less than 200) the whole time. I drained it all out and flushed the system with water, but when I ran it today it heated right up, and started leaking from the spot under the AC compressor.
post #9 of 11 Old 04-17-2012, 05:27 PM
User is: aa21830 is offline
Sounds similar to my '96 Sonoma at about 190k. I think it had been leaking for some time prior to that, but the leak was in the same spot as yours. Seemed to be leaking to the outside of the engine, which is probably better.
If you by chance need a new power steering pump, now would be an excellent time to replace it. The re-installation of the intake manifold would be so much easier if that power steering pulley wasn't there (you can still pull it off if you want; most guys don't). It gets pretty tight, but still can be done without pulling the pulley. If you haven't found this link already, I like it best...lots of photos.
2004 Blazer ZR2
aa21830 is offline
post #10 of 11 Old 04-18-2012, 04:54 PM Thread Starter
You guys were right about the intake manifold gasket. I got the old one out, cleaned everything up and put the new one in. The old one was in really bad shape. I'm surprised I didn't see more leaking than I did. A few more hours of putting everything back together, and hopefully I'll be able to drive my truck again.
post #11 of 11 Old 04-18-2012, 09:20 PM Thread Starter
OK, I got it back together, but when I put the plenham back on and tightened it down, the fuel injector connection didn't stick up far enough to fully seat the electrical connector. I can get it to start, but the engine vibrates the connector out and it runs rough and stalls out. Any thoughts on how to fix this? Do I have to pull the plenham back off, or do you think I can tap on the top to seat it better or something?
