ignition switch
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 05-14-2008, 01:01 PM   #1
boomerOUsooner is on a distinguished road
ignition switch
Has anyone ever changed the ignition switch on a 98 s-10. the one with all the wires in the steering console, not the key switch. Is there any tricks or anything i need to watch out for?
Thanks
Old 05-14-2008, 04:05 PM   #2
NOBAMA NOBAMA
96Dropped-dime's Avatar
96Dropped-dime is on a distinguished road
Re: ignition switch
REMOVAL & INSTALLATION
1994 Vehicles
For anti-theft reasons, the ignition switch is located on top of the steering column assembly and is completely inaccessible without first lowering the steering column. The switch is actuated by a rod and rack assembly. A gear on the end of the lock cylinder engages the toothed upper end of the actuator rod.
  1. Disconnect the negative battery cable.
  2. Remove the lower column trim panel, then remove the steering column-to-instrument panel fasteners and carefully lower the column for access to the switch.
  3. Remove the turn signal switch from the column and allow it to hang from the wires (leaving them connected). For details, please refer to the procedure located earlier in this section.
  4. Remove the buzzer switch assembly.
  5. Carefully remove the lock cylinder screw and the lock cylinder. If possible, use a magnetic tipped screwdriver on the screw in order to help prevent the possibility of dropping it.
CAUTION
If the screw is dropped upon removal, it could fall into the steering column, requiring complete disassembly in order to retrieve the screw and prevent damage.
  1. Unfasten the steering column support bracket assembly hex head bolts and remove the bracket.
  2. Unfasten the dimmer switch assembly screws and remove the switch.
  3. Place the ignition switch in the OFF-LOCK position.
  4. Remove the ignition switch-to-steering column retainers, then remove the assembly.
To install:
  1. Before installing the ignition switch, place it in the OFF-LOCK position, then make sure that the lock cylinder and actuating rod are in the Locked position (1st detent from the top or 1st detent to the right of far left detent travel).
Most replacement switches are pinned in the OFF-LOCK position for installation purposes. If so, the pin MUST be removed after installation or damage may occur.
  1. Install the activating rod into the ignition switch and assemble the switch onto the steering column. Once the switch is properly positioned, tighten the ignition switch-to-steering column retainers to 35 inch lbs. (4.0 Nm).
CAUTION
When installing the ignition switch, use only the specified screws since over length screws could impair the collapsibility of the column.
  1. Install the dimmer switch and the steering column support bracket.
  2. Align and install the lock cylinder set.
  3. Push the lock cylinder all the way in, then carefully install the retaining screw. Tighten the screw to 22 inch lbs. (2.5 Nm) on tilt columns or to 40 inch lbs. (4.5 Nm) on standard non-tilt columns.
  4. If necessary, install the buzzer switch assembly.
  5. Reposition and secure the turn signal switch assembly
  6. Raise the column into position and secure, then install any necessary trim plates.
  7. Make sure the ignition is OFF, then connect the negative battery cable.
1995-99 Vehicles
See Figure 1
Fig. 1: Exploded view of the ignition and key alarm switch
  1. Remove the column shroud halves.
  2. Remove the column-to-dash attaching bolts and slowly lower the steering column, making sure that it is supported.
  3. Remove the multifunction switch if necessary.
  4. Remove the key alarm switch, if equipped by gently prying the alarm switch retaining clip with a small screwdriver. Rotate the alarm switch 1/4 in. (6mm) turn and remove.
WARNING
Extreme care is necessary to prevent damage to the collapsible column.
  1. Make sure that the switch is in the LOCK position. If the lock cylinder is out, pull the switch rod up to the stop, then go down one detent.
  2. Remove the two screws and the switch.
To install:
  1. Before installation, make sure the switch is in the LOCK position.
  2. Install the switch using the original screws. Tighten the screws to 12 inch. lbs. (1.4 Nm).
  3. Install the key alarm switch, if equipped . Make sure the retaining clip is parallel to the lock cylinder. Rotate the alarm switch 1/4 in. (6mm) turn until locked in place.
  4. Install the multifunction switch if removed.
CAUTION
Use of screws that are too long could prevent the column from collapsing on impact.
  1. Replace the column. Tighten the nuts to 22 ft. lbs. (29 Nm); the bolts to 20 ft. lbs. (27 Nm).
  2. Install the column shroud halves.
Old 05-15-2008, 09:14 AM   #3
Re: ignition switch
Wow, thats exactly what I was needing.
Don't look to bad to do.
thanks
Old 05-15-2008, 01:30 PM   #4
NOBAMA NOBAMA
Re: ignition switch
looks a lil harder than it actually is
Old 08-17-2008, 06:43 AM   #5
www.s-clusive.com
mysdime02's Avatar
mysdime02 is on a distinguished road
Re: ignition switch
does anyone have a part number for that ignition and key alarm switch? i am having trouble locating it.
Page generated in 0.10021 seconds with 11 queries
