How to remove shift knob - S-10 Forum
post #1 of 36 Old 02-18-2010, 01:07 AM Thread Starter
drop the pressure
ILLS10's Avatar
User is: ILLS10 is offline
How do you remove the shift knob on a 97 s10 5 speed, i looked at it and couldnt figure out a good battle plan to take it off no set screw or anything on it do i just need to unscrew it? if so which way? i wanna do an 8 ball, and searched around the forum but there was no real explanation on how exactly you get the damn thing off
Wanted:
-bags, bag brackets for rear, valves, and beer
ILLS10 is offline
post #2 of 36 Old 02-18-2010, 02:30 AM
Tech Mod
beandip's Avatar
User is: beandip is offline
Re: How to remove shift knob
ok basically you cut the rubber off the top and there will be a plastic shell inside. then simply smash this shell on the concrete (wear eye protection) until most of it breaks off then with some channel locks you can remove the remaining plastic pieces.
the end of the shifter is not threaded. the hole piece is glued on. might not sound pretty but its really easy.
-Jonathan
2009 Harley Nightrain
1984 CUCV - Rock crawler
beandip is offline
post #3 of 36 Old 02-18-2010, 11:14 PM Thread Starter
drop the pressure
ILLS10's Avatar
nice can i just unscrew the whole shift lever and knob? or is it harder than it should be?
Wanted:
ILLS10 is offline
post #4 of 36 Old 02-18-2010, 11:17 PM
Tech Mod
beandip's Avatar
push down on the shift boot and you can see the bolt that holds the shift lever in place. loosen the bolt and unscrew the whole thing.
-Jonathan
beandip is offline
post #5 of 36 Old 02-19-2010, 12:02 AM
User is: sidewalksurfer301 is offline
changed out mine today, I got a billet shifter, shaft and all. Just give it a good turn it will come loose and screw off, the top piece im not sure about. But to get the whole thing off, just put something between your teeth and twist, it will come loose.
Owner/Fabricator, New Dimension Customs
post #6 of 36 Old 02-20-2010, 11:55 PM
Wondersmith
StirFrey's Avatar
User is: StirFrey is offline
mine was threaded?
It isn't a death wish. It's about living.
-95 Noma (see thread >) - 2.2 5-speed http://www.s10forum.com/forum/f30/pr...sinoma-433674/
StirFrey is offline
post #7 of 36 Old 02-21-2010, 12:04 AM
halfbake 870's Avatar
User is: halfbake 870 is offline
all i did was unscrew like normal and pulled up and off it came
post #8 of 36 Old 02-21-2010, 12:29 AM
Tech Mod
beandip's Avatar
I don't see any threads here
and i was polishing it with the drill to make this if you wondering.
-Jonathan
beandip is offline
post #9 of 36 Old 02-21-2010, 10:29 AM
parker215's Avatar
User is: parker215 is offline
where did you find a shift knob to fit that. the top looks like a bigger than a nornal shifter with threads.
96 s10 4.3L 5spd Lowered Longbed
post #10 of 36 Old 02-21-2010, 12:39 PM
DTFD28's Avatar
User is: DTFD28 is offline
Send a message via AIM to DTFD28
It is! Its been driving me crazy for a few years. i just gave up and stuck with the crappy one that came with my truck.
DTFD28 is offline
post #11 of 36 Old 02-21-2010, 08:08 PM
Tech Mod
beandip's Avatar
you guys need to post a pic of yours. i guess GM might have changed them internally over the years
I have no clue man, a buddy of mine gave it to me and he said he bought it at autozone a few years back. it just slips on and you tighten 3 set screws.
since then i upgraded to something much better and the shifter i posted above is now just collecting dust.
http://www.s10forum.com/forum/f13/fo...review-423255/
-Jonathan
beandip is offline
post #12 of 36 Old 02-22-2010, 03:07 AM Thread Starter
drop the pressure
ILLS10's Avatar
ok the threads on the shaft on the bottom of the shifter are impossible to take off, i guess GM put one on mine where the knob and arm assembly are threaded to the shift arm on the trans/ and they used loctite gold and i stripped the whole not on my nut on the bottom of my shifter arm/knob
Wanted:
ILLS10 is offline
post #13 of 36 Old 02-22-2010, 04:41 PM
parker215's Avatar
beandip..that shifter is wicked! ill get a pic of mine then and post it to see what you think i could do.
post #14 of 36 Old 02-22-2010, 04:59 PM
parker215's Avatar
here it is...
post #15 of 36 Old 02-22-2010, 05:02 PM
Tech Mod
beandip's Avatar
Oh, never messed with a 96 before but it should be the same. i'd have to see it in person.
-Jonathan
beandip is offline
post #16 of 36 Old 02-22-2010, 05:59 PM Thread Starter
drop the pressure
ILLS10's Avatar
OP: heres my shifter, how do i get this bastard off?
Name:	shift knob01.jpeg
ID:	109441   Click image for larger version
Name:	shift knob02.jpeg
Wanted:
ILLS10 is offline
post #17 of 36 Old 02-22-2010, 06:19 PM
User is: skindeep is offline
lefty loosey righty tighty. o and add musle and both hands it helps.
2000 Sonoma base color white, with green and gold scolps lowered 3/7 belltech leafs ground force coils and local auto parts lowering blocks. 15 in baby moons.
DASH SWAP UNDER WAY, 57 chevy
98+ grey dash for sale!! its compleet wit air bag, ac vents, fuse cover, bezel! and if wanted radio,hvac control, gauge cluster etc
and complete ac unit minus the black box
skindeep is offline
post #18 of 36 Old 02-22-2010, 06:35 PM
thats mine i made for my truck not to long ago. i love it lol
the only thing tht i dont likk bout it is i head butted it when i got in my car crash and it gave me a black eye.
skindeep is offline
post #19 of 36 Old 02-22-2010, 07:46 PM Thread Starter
drop the pressure
ILLS10's Avatar
shift knob is off! i just heated it up with a torch and then cracked it with a pair of vice grips, need a caliper and drill press will update photos when finished and make a how to!
Wanted:
ILLS10 is offline
post #20 of 36 Old 02-22-2010, 11:02 PM Thread Starter
drop the pressure
ILLS10's Avatar
finished
Wanted:
ILLS10 is offline
post #21 of 36 Old 02-22-2010, 11:04 PM
my 8 ball is the playboy bunny lol
skindeep is offline
post #22 of 36 Old 02-22-2010, 11:12 PM
emniks's Avatar
User is: emniks is offline
Originally Posted by skindeep View Post
Attachment 109443
Where do I get something like that? Or how did you make it?
emniks is offline
post #23 of 36 Old 02-22-2010, 11:34 PM Thread Starter
drop the pressure
ILLS10's Avatar
looks like piece of steel rod he tapped threads on, bent and attached to a full thread connector
Wanted:
ILLS10 is offline
post #24 of 36 Old 02-23-2010, 05:50 PM
yeap thats it. real easy the hardest part was finding the thread size
skindeep is offline
post #25 of 36 Old 02-23-2010, 06:15 PM
Electrical Mod
deathphoenix99's Avatar
As for the threaded shifter or not, 94-95 have threaded shifters. And I believe that 96+ with the NV3500 also had threaded shifters. The NV1500's had the shifter moved closer to the seat than the other manual tranny's so I assume only they had the glued on shift handles.
post #26 of 36 Old 02-23-2010, 06:57 PM
Tech Mod
beandip's Avatar
NV3500 sits in the same spot the nv1500, as far as shifter location.
-Jonathan
beandip is offline
post #27 of 36 Old 02-23-2010, 07:13 PM Thread Starter
drop the pressure
ILLS10's Avatar
if you have the none threaded type you need to drill a 23/32 inch hole in your shifter
Wanted:
ILLS10 is offline
post #28 of 36 Old 02-23-2010, 07:55 PM
Electrical Mod
Not from what I've seen.
96 dime
It's farther forward than on the nv1500. My t5 is also in the same location as above. Whereas the NV1500's are closer to the seat as in your truck.
post #29 of 36 Old 02-23-2010, 08:30 PM
Tech Mod
beandip's Avatar
96 dime
BUT!!!11 my center console came out of a 2001 5 speed GMC Jimmy with a 4.3 which has a nv3500 and my nv1500 fits nicely in that same location. weird though because i have seen a 96 isuzu hombre with the nv1500
-Jonathan
beandip is offline
post #30 of 36 Old 02-23-2010, 10:39 PM
Electrical Mod
Maybe they changed it on later years. I know 94-95 are definantly more forward than in your truck. And some of the 96+ NV3500's do have the shifter farther forward. Either way, if the shifter is farther forward, they appear to have the screwed on knob whereas the ones closer seem to be glued on. I'm sure there are probably exceptions, but that's what it looks like so far.
EDIT: That picture above is "parker215" truck which is a 96 with the 4.3. So it has the NV3500, not the nv1500.
post #31 of 36 Old 02-24-2010, 10:11 AM
parker215's Avatar
yea im pretty sure mine is glued on i tried once to unscrew it and got no where with it. thinking about removing it and making my own custom one. sort of like skindeep's just not that high. his reminds me of the Ratfink or ratrod shifters....very nice
post #32 of 36 Old 02-24-2010, 04:01 PM
capspauld's Avatar
User is: capspauld is offline
96 dime
My '03 NV3500 is way closer to the seats than that one. Maybe they redesigned it in '98 or something. Mine is also the glued/pressed on type.
Originally Posted by Dogsofjune View Post
I race slower vehicles, by comparison, my truck seems fast.
Sorta like hanging out with people fatter than you.
post #33 of 36 Old 01-21-2013, 06:42 PM
User is: T.R.03 is offline
does anyone know the tread size of the shaft the shifter arm in screwed on
T.R.03 is offline
post #34 of 36 Old 05-27-2013, 12:22 PM
User is: Pignanelli is offline
Easy-Peasy-Lebanesy, as they say... (or maybe I just say that)
ID:	133219   Click image for larger version
ID:	133220   Click image for larger version
post #35 of 36 Old 05-28-2013, 10:41 PM
User is: shaun2193 is offline
I too have had a problem getting my shift knob off. i have a 94. i know it is a screw on.
post #36 of 36 Old 08-21-2015, 02:06 PM
User is: Cobo is offline
I have a 2002 S-10. I just removed the shifter shaft. The nut immediately under the shifter shaft is a lock nut. It needs to be tightened just a bit to loosen the shifter shaft which can then be unscrewed.
Cobo is offline
