How to grease u-joint? - S-10 Forum
post #1 of 5 Old 12-10-2010, 12:53 PM Thread Starter
fatphatboy88's Avatar
User is: fatphatboy88 is offline
I have a 2 month old u-joint that is already clicking. The shop swore that they greased it but I really doubt that now. So how am I supposed to grease it because none of my 3 grease guns will fit between the yokes.
Do I have to jack up the truck or have it at a certain position to be able to grease it? I am about to make a 100 mile drive later today and really dont want to drive like it is.
1999 S-10 Reg Cab Short Bed 4.3 3" AIM spindles, 2" Dick Cepek coils, 2" shackles, 2" body lift, Classic IIs, 31x10.50x15
Full Infinity Audio Kappa 462.9cfp and 62.9i Reference 1062w sub, 1300a and 475a amps
AD244 with Big 3
post #2 of 5 Old 12-10-2010, 12:55 PM
Dump em' Out
Bootylicious's Avatar
User is: Bootylicious is offline
Re: How to grease u-joint?
you may have to drop it to be able to get in there
post #3 of 5 Old 12-10-2010, 01:02 PM Thread Starter
I was hoping not to have to do that. But if that's what I have to do then ill do that.
AD244 with Big 3
post #4 of 5 Old 12-10-2010, 05:16 PM
AWD V8's Avatar
User is: AWD V8 is offline
I try to install a U-joint so that the grease nipple has as much clearance as possible, and sometimes that isn't enough to allow most grease gun fittings in.
Sometimes if you let the rear axle drop it will give you some angle on the joint and that may be enough, and sometimes you would have to drop the rear of the shaft.
However, you can buy a grease needle that you can attach to the grease gun and you jab it into the grease fitting and pump. These are used in the double cardon joints and sometimes you need this to grease ball joints. Under $20
AWD V8 is offline
post #5 of 5 Old 12-11-2010, 04:14 AM
chadzx11's Avatar
User is: chadzx11 is offline
The new napa severe duty ujoints have the grease fitting in one of the caps. Problem solved.
chadzx11 is offline
