Fuse keeps blowing - S-10 Forum
post #1 of 9 Old 04-23-2010, 09:50 AM Thread Starter
User is: SLVRBLT95 is offline
Question Fuse keeps blowing
on my 95 sonoma i have sirius satilite radio ran to my 12 volt cig liter plug and it keeps blowing fuses. it calls for a 20 amp so i thought maybe i would put a bigger one to keep it from blowing but now its gotten so bad that i cant even get the fuse all the way in before it blows.
post #2 of 9 Old 04-23-2010, 09:54 AM
Electrical Mod
deathphoenix99's Avatar
Re: Fuse keeps blowing
If you keep blowing fuses, don't put larger fuses in. Something is defiantly wrong and shorting.
Putting larger fuses in only increases the chance of frying the wiring. So how did you hook up the sirius? Is it hard wired or does it use the cig light plug? Unplug the sirius and put the fuse in, does it blow? I don't see any reson the sirius would pull any power hardly at all. So you have a short somewhere. Have you changed anything in your dash recently?
post #3 of 9 Old 04-23-2010, 10:06 AM Thread Starter
no i havnt changed anything and if i do unplug the sirius and put the fuse in as soon as i cut the sirius on it blow. and the sirius has a plug for the cig liter plug.
post #4 of 9 Old 04-23-2010, 10:10 AM
Electrical Mod
That's wierd, I've never heard of them pulling that much power. Have you tried plugging it into a nother vehicle. See if it happens there too? Because right now it sounds as if the sirius is bad or has a short in the wiring.
post #5 of 9 Old 04-23-2010, 10:12 AM Thread Starter
i havnt but i also didnt think about it. but i meen it is very possible cuz 3 prior to this one have went bad. but i will try it but if i have problems still ill be back on here. thanks
post #6 of 9 Old 04-23-2010, 10:16 AM
Electrical Mod
Good luck to you. The only other way it could blow the fuse is if there's already a large draw on the fuse and that pushes it over the edge per say. But the cig fuse only controls the cig lighter/acc. and the OBD connector.
post #7 of 9 Old 04-23-2010, 10:20 AM Thread Starter
the fuse that it blow is the horn, intirior light, and cig plug. i guess there could be a problem in one of those but ive never had a problem so i dont no why it would occur now.
post #8 of 9 Old 04-23-2010, 10:31 AM
Electrical Mod
Ok, I was assuming you meant the two auxiliary outlets on some trucks.
The Pwr Aux. Fuse number 7 (25A) controls the Data LInk Connector and the Power Auxiliary Outlets.
But you meant fuse number 2, Horn/DM (20A).
It controls any of the following, depending on submodel.
Horn
Courtesy lamps
Glove box lamp
Cigarette Lighter
Dome lamp
vanity mirror lamps
rearview mirror lamps
keyless entry module
So my bad on that call. But still, somethings not right since it only blows the fuse when you plug it in. Although I've never trusted using cig lighter outlets for aux. outlets.
post #9 of 9 Old 04-23-2010, 11:48 AM
rolling work in progress
Mr.woodscrewsNbondo's Avatar
User is: Mr.woodscrewsNbondo is offline
does the sirius plug have a fuse in it?
