fuel pump pressure - S-10 Forum
post #1 of 11 Old 12-13-2011, 03:16 PM Thread Starter
User is: firsts10 is offline
fuel pump pressure
hom much pressure should my fuel pump put out
firsts10 is offline
post #2 of 11 Old 12-13-2011, 07:05 PM
Vig Pimpin
viggy58's Avatar
User is: viggy58 is offline
Re: fuel pump pressure
year/make/model etc usually helps get responses....
___________________________________________
2001 Blazer
4.3L 5 speed manual trans, 2wd
180k miles
ALL STOCK!
Profile Baja amp, 100w x4
Sony Xplod 1000w x1
Alpine type R 12in. sub
viggy58 is offline
post #3 of 11 Old 12-13-2011, 07:44 PM
AWD V8's Avatar
User is: AWD V8 is online now
A TBI should be 12-13 psi, all others are 50 @ idle, and 60 @ WOT
post #4 of 11 Old 12-13-2011, 10:44 PM Thread Starter
its a 2000 s10 2.2l
firsts10 is offline
post #5 of 11 Old 12-13-2011, 10:52 PM
AWD V8's Avatar
Originally Posted by firsts10 View Post
its a 2000 s10 2.2l
41-47 psi
post #6 of 11 Old 12-13-2011, 11:01 PM Thread Starter
if there is presure in the fuel line and spark what would be the other reason it wouldnt start. it just turns over
firsts10 is offline
post #7 of 11 Old 12-14-2011, 12:53 AM
Vig Pimpin
viggy58's Avatar
just because there is pressure, doesn't mean it's enough. you'll need to rent a tester.
does it start with a shot of carb cleaner?
2001 Blazer
180k miles
ALL STOCK!
Sony Xplod 1000w x1
viggy58 is offline
post #8 of 11 Old 12-14-2011, 02:10 AM
AWD V8's Avatar
Did you actually check the pressure with a gauge, what is it?
If you are checking at the shrader valve, and it correct, for now it should be enough to get it started. After it's running and you still have problems then you would need to confirm sufficient flow, filter/pump.
Spark can be present, but like fuel delivery, it must be sufficient to do the job. A weak spark, or a good one at the wrong time will do you no good.
You need a good snapping blue spark. Less than that and you need to dig deeper. Is the spark going to the right cylinder at the right time? If the cap is carbon tracked or damp the spark goes to the wrong cylinders. If it's damp or cold where you are I'd pull the cap off and look around. Dry it out with a tissue. I've even seen plug wires so bad that it won't start when damp out. Crank it and look at the plug wires in the dark to see if they are leaking voltage.
You also need compression. Any problems with starting before this? Or did this just come out of the blue? A compression loss usually comes slowly so it would be getting harder starting over time.
If you have confirmed that you at least have fuel pressure while cranking it, put a timing light on #1 and crank it. See if it flashes when near the TDC mark.
If you have a good spark, give it a squirt of gas in the intake to see if it responds. You may have spark, fuel pressure, but the injectors may not be operating.
post #9 of 11 Old 12-14-2011, 01:21 PM Thread Starter
it never had problems starting just one day when i came back from the store it didnt want to start but thanks for the tips im going to check the plugs and wires next. it wont even start with starting fluid
firsts10 is offline
post #10 of 11 Old 12-14-2011, 01:50 PM
User is: Murkshev is offline
If new plugs and wires don't solve your issue. And it truly is an ignition relater problem. Start here.... http://easyautodiagnostics.com/gm_22...agnostic_1.php
Murkshev is offline
post #11 of 11 Old 12-15-2011, 02:43 AM
It's mostly BS
rimara's Avatar
User is: rimara is offline
Nice link.. Lots of good info on the 2.2
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
