drive shaft question - S-10 Forum
post #1 of 8 Old 04-03-2012, 11:01 AM Thread Starter
LOG
LOG's Avatar
User is: LOG is offline
ok so i have this weird clanging sound under my 2002 s10 and from what i found is this collar looking thing like in this pic came off and is making all noise. what the heck is it for?
can i just pull the drive shaft off and remove that thing and keep driving?
you learn the true meaning of life when you see houses and cars blow by like leaves on a windy day.
LOG is offline
post #2 of 8 Old 04-03-2012, 06:32 PM
Catrell92's Avatar
User is: Catrell92 is offline
Re: drive shaft question
LOL do you have four wheel drive? Your truck shouldn't be moving if that came off because that's what transmits power to your rear wheels/ axle, it's called a U joint
My LSX Swap- http://www.s10forum.com/forum/f213/f...swap-o-504055/
98 Noma Stepside ECSB
2/3 on ZQ8
5.3 LSx Swap- 228r- 3.73 Ford 8.8- 4L80e-Circle D 3200 Stall- midmount on3 76mm Turbo
post #3 of 8 Old 04-03-2012, 08:31 PM Thread Starter
LOG
LOG's Avatar
nope 2wd thats not my part its a pic i found to show what my problem is. my drive shaft is fine had u joints done 6 months ago. its the weirdest thing. its the collar part in the pic.
im still driving my truck the only thing was that collar thing was slappin around, couldnt see any place it come off of didnt know if it was part of the tail end of the transmission or not,
i was able to slide it up on the tail end of the transmission out of the way of the drive shaft and no more noise.
im guessing its not vital ive been hearing the noise for a week and have drove it that way till i got a day off to look at it. it drives fine now no noise was just wondering what it was for and if i needed it lol.
LOG is offline
post #4 of 8 Old 04-03-2012, 08:44 PM
AWD V8's Avatar
User is: AWD V8 is online now
That's just to keep crap out of the seal, many trucks don't even have one.
It won't really hurt to get rid of it.
post #5 of 8 Old 04-04-2012, 03:12 AM Thread Starter
LOG
LOG's Avatar
thnks was hoping it wasnt needed.
LOG is offline
post #6 of 8 Old 04-04-2012, 08:36 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
It's a vibration damper and as far as I know only the 5 speed trucks got them. I've never had one fall apart on me so I don't know what it could effect in the long run. I'm sure GM had a reason for putting it there though otherwise they wouldn't have put money into the part.
TelAmeriCorp
post #7 of 8 Old 04-05-2012, 08:41 AM Thread Starter
LOG
LOG's Avatar
yea thats what i found out its a vibration damper its runs fine no vibration at all even at 100 mph so for now i'll just zip tie it out of the way till i can get the $$ to get it replaced. odd it just started doing it out of the blue, i just did front wheel bearings,brakes,calipers and replaced the shocks all the way around in the last 2 weeks. well on to my next project replacing my power steering hose, return line leaks, then on to new speakers and stereo.
LOG is offline
post #8 of 8 Old 04-05-2012, 08:12 PM
Fronk-en-Steen
mostizzle's Avatar
At least drop the driveshaft and remove the broken piece rather than ziptying to something.
TelAmeriCorp
