Disconnected AC compressor
So I was having this issue where the AC was coming on for all settings, not just the defroster. Not sure why this was happening, but I figured I would go ahead and just disconnect the electrical to the compressor for the winter. Could this damage it in any way? I thought maybe I would plug it in once in a while and run the AC a little.
Mr. Fix-it Perfectionist
Re: Disconnected AC compressor
I have ran across tons of vehicles like that and most are still running to this day... so as from what I know.., this shouldn't hurt anything to disconnect wires from compressor....
as for the issue..., u may wanna check into the ac compressor switch near the evap..OR the actual switch inside the vehicle... either one can cause the ac compressor to stay on..... |
www.oaktowntrucks.com
just unplug it at the clutch. it will not hurt anything. it just will not come on. in the winter the a/c will help with defrost because it pulls out the moisture.
what year? |
1999 2wd 4cyl
My_nightmare - how would I diagnose if one of these switches was causing the problem or not? Sorry I've never worked on this kind of issue before.
a 99 runs through the bcm so it could be bad or a switch panel. you would have to hook up a tech2 to find out.
Not sure how to diagnosis the issue, however there is a plug that goes into the receiver / dryer, unplug that and you should be all good to go. The plug is the sensor for the pressure switch / low coolant switch in the dryer, if its not connected the system should not work... I will post a picture of it later when I get home from work...
