coolant won't drain back into radiator from reservoir - S-10 Forum
post #1 of 20 Old 05-15-2008, 10:44 AM Thread Starter
Navy Seabee
SD44's Avatar
User is: SD44 is offline
I've been having a mild overheating problem the past couple weeks. What will happen is.....everything will be fine for a couple days, then it'll try to heat on me (210-220 degrees) alittle. I'll let it completely cool down, and check the radiator to find out it's low. I'll fill it back up, everything will be fine for a few days, then the same cycle again.
This happened yesterday. The day before, I had flushed the whole system and put new antifreeze in. I have a 40 mile trip home from work; everything was fine driving to work and going to lunch. On the way home, after about 30 miles, the temp started slowly climbing to the 210-220 range. I got home, raised the hood,but didn't attempt to open the radiator. But I checked the reservoir and it was completely full of my new antifreeze. I waited about 3-4 more hours and let it completely cool, so that antifreeze would go back into the radiator. Not a drop had drained back in.
There are two hoses on the reservoir; a hose from the radiator neck to the bottom of the reservoir, and a hose from the top/side of the reservoir that drains out underneath the truck. I took the cap off the radiator, pulled the reservoir drain hose out from the bottom, and literally blew into it with my mouth and slowly blew the antifreeze back into my radiator through the neck until it filled back up. So that tells me my antifreeze isn't leaking out anywhere.
What the hell is making the overflow not drain back into the radiator???
1995 regular cab S-10 2WD
4.3 TBI, 5 speed, 360,000 + miles!
SD44 is offline
post #2 of 20 Old 05-15-2008, 11:00 AM
jhankinson's Avatar
User is: jhankinson is offline
Re: coolant won't drain back into radiator from reservoir
Did you replace your radiator cap lately. It acts like a valve...if it sticks or anything it wont suck back in. That would be the first thing I would look at.
1994 S10 - was a 2.2l 5sp terd...now is LS1 4l60e with 8.5/Detroit Tru-trac disk brake rear, ZQ8 suspension, tore down to the frame and rebuilt.
PICS AND VIDS HERE
post #3 of 20 Old 05-15-2008, 11:29 AM
Water Pump Expert
cardboardbox's Avatar
User is: cardboardbox is offline
Send a message via AIM to cardboardbox
+1
1998 S10 SS
post #4 of 20 Old 05-16-2008, 09:48 AM Thread Starter
Navy Seabee
SD44's Avatar
Well it's the waterpump.
Got home and let it cool down, then topped the radiator off and got the temp back up. Some of you may have seen my other thread about having a pulley somewhere making a screeching noise, that's the waterpump too. I put the new cap on, yet was still low of water when i finally got home. After looking the topside over real good, I pulled it up on some ramps and looked at the bottom. There is actually a trail that has been washed clean from the diaphram hole in the bottom of the waterpump, down the water pump and dripping on the harmonic balancer. It's a slow weep, not pouring. It actually doesn't leak at all while running, but it starts a couple minutes after shutting it off. I guess it's from the pressure buildup. I shut it off and got back under the truck, and watched it weep, drop after drop, from the diaphram hole onto the harmonic balancer.
Mine is a 95' TBI. Looking closely from the frontside, it really doesn't appear that I'll need to take the alternator or AC loose to get the pump off. I know I'll have to remove the top of the shroud and the fan, obviously. Have any of you changed a pump that's the same setup as mine? What all did you have to take off?
SD44 is offline
post #5 of 20 Old 05-16-2008, 09:54 AM
Water Pump Expert
I'm all too familiar with this problem. You won't need to pull the AC or Alternator. The only thing you'll really need to pull is everything connected to the pump itself. It's really straightforward, just make sure not to fudge up the gaskets when you put it all back together.
1998 S10 SS
post #6 of 20 Old 05-16-2008, 10:22 AM Thread Starter
Navy Seabee
SD44's Avatar
Thanks, I was hoping i wouldn't have to pull those two. Looking at the water pump bolts, it looked like I could get to all of them with a swivel on my socket. Still gonna get my hands scuffed up, though.
SD44 is offline
post #7 of 20 Old 05-16-2008, 09:36 PM
2Low2Tow
GmcNoma95's Avatar
User is: GmcNoma95 is offline
Ill be replacing my waterpump and my p/s pump etc...on my truck on the 25th of this month. My p/s pump is leaking a slowly, so figured id replace my waterpump at the sametime b/c i dont think it was ever replaced. Would of replaced it when i put my new head on but didnt have it at the time...ill try to get some pics up of the replacement. Ill obviously have to take of the shroud and the shitty clutch fan to pull the water pump pulley off and replace the pump. Cant wait to get an efan, it will be so much easier to replace belts etc...!
PROJECT NOMA ~UNDER DE-CONSTRUCTION!~
1) 2/3 DrOp Kit
2) Rebuilt 4L60E Trans. W/ Performance Parts.
3) Rebuilding a 2.2L into a Stroker motor
Re: Driveshaft vibration when pulling out???? Quote: Originally Posted by s10xtremist Stop pulling out.
Originally Posted by rimara View Post
People are willing to help you...they just don't want to burp and diaper you.
post #8 of 20 Old 05-28-2008, 03:58 PM
User is: Norwood is offline
Sounds like your overflow reservoir problem might be Dex-Cool related. Did yours come with Dex-Cool from the factory?
Norwood is offline
post #9 of 20 Old 05-28-2008, 04:04 PM
Water Pump Expert
Uhm... They all did.
1998 S10 SS
post #10 of 20 Old 05-28-2008, 04:57 PM
No More SS
SmokeeJay's Avatar
User is: SmokeeJay is offline
When I flushed all the dex cool crap out of my system, most of the hoses were caked with junk on the inside and my hoses to my reservoir were almost completely clogged.
post #11 of 20 Old 05-28-2008, 05:04 PM Thread Starter
Navy Seabee
SD44's Avatar
I had posted in another thread that it was my water pump, which has been replaced and I have no more problems.
But yes, I have a gummy substance all over everything, like jello. Is that from the factory anti-freeze that it came with?
SD44 is offline
post #12 of 20 Old 05-28-2008, 06:55 PM
Water Pump Expert
Did you mix the factory coolant with anything from the aftermarket?
1998 S10 SS
post #13 of 20 Old 05-29-2008, 09:16 AM
No More SS
SmokeeJay's Avatar
If you put regular anti-freeze in your truck, you must flush out all the dex-cool. they do not mix well. With just the dex-cool in my truck, everything looked like it was coated in mud. I flushed it 2 times before i put anti-freeze and water back in it.
post #14 of 20 Old 06-03-2008, 10:31 PM
2Low2Tow
GmcNoma95's Avatar
Dex-Cool if im not mistaken, are for 96' or 97 and later model chevys or gmc cars/trucks..i have a 95 Noma and learned that it would f' up the coolant system or something; It was a really good reason, just cant remember what kind of problems they say it causes, enlighten me anyone if you can remember, b/c i know that dex-cool isnt recommend for 95-earlier model GM Vehicles. i obviously just use prediluted 50/50 Prestone.
1) 2/3 DrOp Kit
post #15 of 20 Old 06-03-2008, 10:52 PM
I AM CANADIAN
tt85_GM's Avatar
User is: tt85_GM is offline
Yeah my '95 Cavi was green coolant.
-'02 Jimmy 2dr 4x4, 2" lift & 31's
-'08 Altima coupe
-2000 Sonoma, 4.3L, polished ZQ8's- SOLD
Polishing ZQ8's thread:
http://www.s10forum.com/forum/f14/po...roject-366831/
Leather Seat Swap: http://www.s10forum.com/forum/f26/leather-seat-swap-346677/
tt85_GM is offline
post #16 of 20 Old 05-25-2015, 02:20 PM
Clapps1775's Avatar
User is: Clapps1775 is offline
I am having the same problem right now. 2003 4.3 zr2. 120k. I replaced the water pump last year and have the e fan on. I noticed today when I started my truck, I had the gurgeling sound on my dash. Checked coolant level and its low where my reservoir is full. Drove 30 miles today to half price books. Recheck and reservoir is still full and cool. I opened the cap enough and it pushed air into the reservoir. I should replace my cap. Also, replaced my radiator last year and I did a flush on it before I installed it. I need to flush my system again. Has brown junk again. Thinking cap is failing. I do not see or smell coolant. I will inspect my reservoir hoses and see if they are clogged.
Thanks,
Clapps1775
1994 Chevy S10 2.2 Auto 4X2 LS. Sold.
1995 Chevy S10 4.3W Auto CPI 4X4 LS. Traded off.
2003 Chevy S10 4.3X Auto 4X4 ZR2 LS current.
post #17 of 20 Old 05-25-2015, 05:18 PM
Clapps1775's Avatar
Found out my problem. Took radiator cap off and over full tube from reservoir. Capped it with my thumb and blew into the reservoir. Filled radiator no problem and no gunk came out. Out cap back on. Blew into reservoir and again capping off over full tube. Coolant came out around radiator cap. Need a cap. Cap had a slight sunkin look to it. $6 for one with a valve release. Thought about the mr. Gasket radiator thermostat cap. $26 I will pass. Anyone tried one?
Thanks,
Clapps1775
post #18 of 20 Old 05-26-2015, 04:31 AM
MEP1's Avatar
User is: MEP1 is offline
There's no reason to use anything better than an OEM Stant or AC/Delco.
MEP1 is offline
post #19 of 20 Old 05-26-2015, 11:59 PM
Clapps1775's Avatar
I got the stant on with the pressure release. Works great.
Thanks,
Clapps1775
post #20 of 20 Old 06-02-2015, 12:48 PM
Clapps1775's Avatar
Today is 67 out in Iowa where I live. S10 ran 220-230 today and not sure why. I turned my heater on blast to help cool it down. I do not see coolant leaks. I have noticed my top tranny cooler line leaking now. So, will look at the tranny cooler thread. I am thinking with 120 k on her. Its time to change out the thermostat. Also, my s10 is the zr2 with the brush guard on. Had anyone noticed cooling problems with it on using the e-fan?
Thanks,
Clapps1775
