Bleeding Brakes on s10 with ABS - S-10 Forum
post #1 of 26 Old 10-24-2007, 09:03 PM Thread Starter
User is: 984x4 is offline
Just put new brake lines on the s10 and have to bleed the brakes, I tried but couldnt get anything to come out, I know its because ABS brakes are funky and I dont want to take it to the dealer, any suggestions
984x4 is offline
post #2 of 26 Old 10-24-2007, 09:18 PM
montecarloman90's Avatar
User is: montecarloman90 is offline
Re: Bleeding Brakes on s10 with ABS
you must have something in the line blocking it because even tough you have ABSit will bleed like normal.
post #3 of 26 Old 10-24-2007, 09:20 PM
Needs a clutch... BAD!
EYEOPNR's Avatar
User is: EYEOPNR is offline
<Kent><1998 Chevy S10 - 5 Speed - 2.2L>
Originally Posted by jchargu3 View Post
I cant have my own baby batter near my mouth....
Originally Posted by nox View Post
anybody who buys a miniature horse and names it "mini-horse" is ok in my book.
EYEOPNR is offline
post #4 of 26 Old 10-24-2007, 09:28 PM Thread Starter
I dont think thats the case, they are brand new brake lines
984x4 is offline
post #5 of 26 Old 10-24-2007, 11:20 PM
SlammedSonoma96
SlammedSonoma96's Avatar
User is: SlammedSonoma96 is offline
It doesnt matter if you have ABS or not, the brakes all bleed the same. The only thing ABS does is react when you have the vehicle in motion and stomp the pedal. When bleeding there is no pressure change in the lines. Did you flush the master cylinder before changing the brake lines? If not, you probably have something in the line blocking the flow.
96 GMC Sonoma: Bagged SD 5 link, Slam RE7 front RE8 rear. 20" ADR Propulsion Wheels, Fully shaved,
AVS cowl induction hood, Blazer front end swap, SS Bumper, being prepped for paint.
Soon to have a 5.3/4L60E
post #6 of 26 Old 10-24-2007, 11:38 PM
LT. Morgan
miself's Avatar
User is: miself is offline
Send a message via AIM to miself Send a message via MSN to miself
is there nothing coming out? or just air?
-Mike
miself is offline
post #7 of 26 Old 10-25-2007, 06:28 AM Thread Starter
Just air
984x4 is offline
post #8 of 26 Old 10-25-2007, 06:29 AM Thread Starter
didnt flush the master cylinder, thought it would be better not to bother it since i only replaced the back brakes. Could this be it?
984x4 is offline
post #9 of 26 Old 10-25-2007, 08:34 AM
B4U Task Force
Rhotpursuit's Avatar
Bench bleed the master.
U.S.C.G. "So others may live"
Apple Red 96 SS
post #10 of 26 Old 10-25-2007, 11:05 AM
LT. Morgan
miself's Avatar
Just air
it may be that you just need to stay on one brake until you get all the air out of that line....this took several minutes when we changed my room mates master cylinder.
-Mike
miself is offline
post #11 of 26 Old 10-25-2007, 10:23 PM
goin broke but n style
S15vortecpwr's Avatar
start at the right rear brake and bleed until you get fluid and then move to the left. Work yourself closer to the master cyl. It may take a few minutes ot get all the air out. I have always gravity bleed my brakes b/c I do not have anybody else to help. Just open the bleeder and let gravity do the work. Works every time.
All brakes bleed the same. I does not matter what kind, type or brand ABS it has.
01 GMC Noma 2.2L auto - SOLD
99 blazer 4dr 2wd - SOLD
GOIN BROKE BUT N STYLE
post #12 of 26 Old 07-05-2008, 03:15 PM
User is: Questor is offline
Hey. I'm just new here and having the same problem.
1996 Sonoma SS that my son just bought. I've bled brakes lots of times (Including my 1965 Cobra replica I'm building) but this one has me stumped. I replaced the long line from front to rear and the driver's side rear line. When I bleed the brakes (starting at the passenger's side rear) i get a slight sputter of fluid and nothing else. When I tried a vacuum bleeder, it pulled spits of fluid but never got much. I've been trying for over a day and even tried gravity bleeding. The master was not off the truck and the lines were never off the master.
I'm thinking it might be something to do with the proportioning valve or ABS, but am pretty frustrated at this point. Any suggestions?
Questor is offline
post #13 of 26 Old 07-05-2008, 07:07 PM
Okay. I finally got it.
My son got to take it around the block and a stick of dynamite wouldn't take the smile off his face. You see he just got his license and the truck is in very nice shape. It has been sitting in a garage for 5 years though so there are a few things to do.
The truck is the SS version so it is lowered and has the wide wheels and tires. I'd say from the way it pulls off the start it probably has a higher ratio rear end too. I'll bet that 4.3 will guzzle gas though.
Questor is offline
post #14 of 26 Old 07-05-2008, 07:32 PM
B4U Task Force
Sorry...no such animal as a Sonoma SS.. Run your RPO codes thru the decoder.
Apple Red 96 SS
post #15 of 26 Old 07-05-2008, 11:03 PM
Umm. So what do I get if it is an SS?
I did find a Link to an SS in the S-10 version.
Are you really sure cuz it sure looks like what's described with the SS in that thread?
I'll grab the SN and you can check it out because I'm not sure how to read it for a GMC.
Questor is offline
post #16 of 26 Old 07-06-2008, 12:01 AM
B4U Task Force
Is it an S10 or Sonoma?? SS's are S10 only. Check the glovebox door for RPO B4U. Post a pic of your truck.
Apple Red 96 SS
post #17 of 26 Old 07-06-2008, 11:31 AM
Found the original window sticker in the glove box and it doesn't say SS but it lists the options as in the other thread including the wheels, tires and locking diff. It is definitely a Sonoma according to that and the title.I'll give the SN except for the last 5 digits. 1GTCS14W0T85XXXXX
I'm not sure what you mean by RPO. The paint certainly looks original and the Badging does too. According to the original sticker, the tires on it now are bigger than the originals though.
Questor is offline
post #18 of 26 Old 07-06-2008, 12:08 PM
Okay. I found what you were talking about. It doesn't have B4U. It has B30 and B32, but it does have all the other codes. It does have the badging and it has all the options listed. I'm wondering if the code might be different on a Sonoma or in Canada.
Questor is offline
post #19 of 26 Old 07-06-2008, 12:53 PM
Last time. I found This for checking codes and it doesn't have the B4U, but it does have another that says essentially the same thing as it does for that code. The original owner (My son's uncle) said he bought it as an SS.
I really don't care, but I do find it interesting that it has every option the S-10 SS has and it does have the SS identification on it, but there is supposedly no such thing as a Sonoma SS. Judging by the price (A little over 24k Canadian) on the original sticker I'd hope it was something special. Perhaps I'll just say the SS stands for Something Special
Questor is offline
post #20 of 26 Old 07-06-2008, 01:05 PM
B4U Task Force
The RPO decoder is at the top of the page under LINKS. SS badges are available on ebay.
Apple Red 96 SS
post #21 of 26 Old 07-06-2008, 02:49 PM
Sooo, which Sonoma would have the same options as the S-10 SS?
If you can PM me an e-mail address, I'll send some pics including one of the options codes. (I don't have a web host right now) I'm kind of intrigued now. I wonder if the dealer pulled a fast one. This thing even has the proper wheels except they have GMC centers instead of the Chevrolet ones. I even checked underneath for the proper suspension and it has that right down to the big bars and horizontal shock.
Questor is offline
post #22 of 26 Old 07-06-2008, 03:25 PM
B4U Task Force
Go to www.photobucket.com it's free
Apple Red 96 SS
post #23 of 26 Old 07-06-2008, 08:25 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
DAMN you ebay and your SS badges!
LOL
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #24 of 26 Old 07-06-2008, 08:51 PM
B4U Task Force
LOL
Apple Red 96 SS
post #25 of 26 Old 07-06-2008, 09:27 PM
Static Truck owner
cuda_'s Avatar
User is: cuda_ is offline
Send a message via AIM to cuda_
Well the ZQ8 package for GM included the suspension,sway bars and wheels. Maybe it was a Sonoma GT. Thats sounds like a "SS" package.
'95 S10 ext. cab- 4"/4" Belltech, K&N intake, sts pulley's, e-fan, Pacesetter Header, MagnaFlow, ZQ8 wheels, Shaved Tailgate, roll pan..very slow Work In Progess
'07 Nissan Maxima SE...stock DD
'00 Impala LS- 1.3"/1.7" Eibach Springs, SLP sway bars, custom intake, 35% all around, 18" Hot Wheels. Daily Driver....SOLD IT
cuda_ is offline
post #26 of 26 Old 07-06-2008, 09:28 PM
Okay. Are you ready for this. I was mostly wrong.
I did some investigating and found out what happened. I hadn't talked to my son's uncle (Only to my ex) so didn't get 100% of the story. Are you ready for this?
The truck did come from the dealer with the SS badging. It does have all the options the S-10 SS has, but it's not an SS. The dealer admitted, they had added the SS decals to the truck after they had made the sale when they were questioned about it.
They special ordered the truck with all the options. A total of over 7K according to the sales sticker. They thought they could sell it easily with those options and found out they couldn't. They, apparently thought adding the SS stickers wouldn't hurt and would make it sell faster, which I guess it kind of did.
So the bottom line is this truck was ordered with every option the SS had EXCEPT (Of course) the B4U which couldn't be ordered. It was then made to look the same as the SS by adding the decals (As you had already surmised.) Even though it's the same in every real way as an SS, it isn't one. Mystery solved. Personally, I'd have taken them to task for fraud, but.....
The truck still looks great and should perform well: Especially for a first vehicle.
Oh yeah. I managed to get some pictures hosted.
Questor is offline
