Alternator replacing?
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 10-27-2009, 09:51 PM   #1
My friend is gonna come over and fix the alternator. Anyone who has gotten this changed before, do you know how long, on average, it takes to change this? My friend knows exactly what he's doing. Just out of curiosity.
Old 10-27-2009, 09:57 PM   #2
Re: Alternator replacing?
2.2 4.3 350 ls1?
What are we talking here?
Old 10-27-2009, 10:04 PM   #3
4.3,,thirty minutes tops
Old 10-27-2009, 10:08 PM   #4
I have a:
2.2 Liter
4 Cylinder
It's a 1995 Chevy S-10.
Old 10-27-2009, 10:14 PM   #5
Drive it like ya stole it
evandonald's Avatar
About 20 min I could have the old one out and new one in and I have only done it once. Getting the belts back on is the trickiest part I found.
Old 10-27-2009, 10:20 PM   #6
The belts were easy. Mine was in kinda the middle. Was PIA to get out.
Old 10-27-2009, 10:47 PM   #7
CatDaddy52's Avatar
Just remember to disconnect the battery ground. Seen new alts get fried because guy was too lazy to undo a terminal.
Old 10-27-2009, 11:26 PM   #8
Meaning.... to disconnect the battery when replacing the alternator?
Old 10-27-2009, 11:37 PM   #9
Stock Height
slonlow2000's Avatar
Yeah take the black (negative) cable off. The 2.2s are a pain in the ass. Took me an hour or 2 the 1st time I did it.
Old 10-27-2009, 11:42 PM   #10
Air Force 1's
AirForces's Avatar
Yup!
And, to make life easier for yourself - there's a spot in the belt tensioner that will fit a 3/4'' ratchet, so you can just crank back on it to give the belt enough slack to come off. You can do the same thing to get it back on.
Depending on whether or not this new alternator has an underdrive pulley, you're going to want to consider a new, and possibly shorter belt while you're at it!
Old 10-28-2009, 02:57 AM   #11
Useless posting member
Wrkn prgs's Avatar
I think it took me about 3 hours when I did it.. I never worked on a car before that though, it was my first real job. My other truck took about 15 mins total though, but then again I had an e-fan, intake, no inner fenders, and no heat/ac components so it was a hell of a lot easier!
Old 10-28-2009, 01:29 PM   #12
You may also want to consider replacing the power and ground wires as is noted in the thread I posted below since it is a cheap replacement and could alleviate further electrical problems down the road.
http://www.s10forum.com/forum/f202/b...how-to-321330/
Old 10-28-2009, 01:35 PM   #13
firstgenon24s's Avatar
about 5 minutes...**EDIT** 2.2 maybe 20-30 mins.
Old 10-28-2009, 07:03 PM   #14
What's so different about the 2.2? How come it would take longer?
Old 10-28-2009, 08:09 PM   #15
Location Location Location...lol
Old 11-02-2009, 03:26 PM   #16
evandonald's Avatar
I don't see why its hard to get too. I only had to remove the long part of the air box.
Old 11-02-2009, 04:36 PM   #17
The place the alternator is on the 2.2 has to be the worst place to put one. Seems kinda odd they put it down so low.
When my friend did mine, all he had to do was take out the battery. There was somehow enough room for him to get to it. If it was me, I'd probably have had to take off something else too, cause there's little to no room to get to it.
Page generated in 0.58307 seconds with 31 queries
[Output: 93.34 Kb. compressed to 86.46 Kb. by saving 6.89 Kb. (7.38%)]
