ABS and Brake light come on - S-10 Forum
post #1 of 8 Old 02-24-2012, 09:42 AM Thread Starter
Take a back road
User is: may22 is offline
i have a 2000 chevy s10 ZR2 and after i drive for a few minutes the ABS and brake light come on simultaneously and stay on until i restart the vehicle. i just replaced both the wheel bearings and that should have fixed why the ABS light was coming on. could i get some help on this one please?
may22 is offline
post #2 of 8 Old 02-25-2012, 02:33 AM
User is: srm1313 is offline
Re: ABS and Brake light come on
I have the same 2 lights on in my 03 s10 4.3 zr2. For me the issue is the ebcm (electronic brake control module. Over 1000 from the dealer, but 125 on ebay. With mine and most likely yours, whenever those lights are on, i dont have abs. So be careful.
srm1313 is offline
post #3 of 8 Old 02-25-2012, 12:30 PM
User is: Ntrain2k is offline
Could be a wheel speed sensor as well.
Ntrain2k is offline
post #4 of 8 Old 02-25-2012, 04:57 PM Thread Starter
Take a back road
isnt the wheel speed sensor in the wheel bearing?
may22 is offline
post #5 of 8 Old 02-25-2012, 06:04 PM
Maybe later.
tytotheler92's Avatar
There's two grounds under your Air Filter assembly, next to the radiator. Unbolt them, clean the rust and other stuff of it, and bolt them back in with some dielectric grease. One is a direct ground for the brake module, and the other is some ground that you might as well clean while you're down there.
This has solved the same issue that you're having on my truck for the past 6 months.
2016 Toyota Tacoma TRD Sport 6 speed
1985 S10 Blazer 4WD
post #6 of 8 Old 02-25-2012, 06:07 PM
No.
Is is in there behind everything.
Looks like this:
http://www.autozone.com/autozone/par...=101186_0_4222_
Ntrain2k is offline
post #7 of 8 Old 02-26-2012, 06:03 AM
Vig Pimpin
viggy58's Avatar
User is: viggy58 is offline
it is fairly common to break the speed sensor and / or the wiring when replacing wheel bearings....
___________________________________________
2001 Blazer
4.3L 5 speed manual trans, 2wd
180k miles
ALL STOCK!
Profile Baja amp, 100w x4
Sony Xplod 1000w x1
Alpine type R 12in. sub
viggy58 is offline
post #8 of 8 Old 02-28-2012, 06:02 PM Thread Starter
Take a back road
i will try and clean up the grounds and see it that works. i bought new hub assemblies so that shouldnt be the problem
may22 is offline
