98 s10 won't start in cold weather - S-10 Forum
post #1 of 13 Old 12-01-2010, 03:58 PM Thread Starter
omgs10's Avatar
User is: omgs10 is offline
Ok i have a 98 s10 2.2 5spd. I live in oklahoma, i go to work around 4 pm and get off around 2-3 am. Car starts up fine when i go to work, but when i get off it won't start. (A lot colder at 3am.) The engine cranks over just fine, but won't start. My egr tube is cracked so i figured maybe it was sucking in cold air? I also bought some HEET, but that didn't solve anything. Any ideas.?
| Red 98 S10 | Corvette C6 Rims| 3/4 drop |
omgs10 is offline
post #2 of 13 Old 12-04-2010, 02:28 PM
S-Series Addict
SonomaGT's Avatar
User is: SonomaGT is offline
Re: 98 s10 won't start in cold weather
Look around for any vacuum leaks, thats where i would start.
'92 GMC Sonoma GT #0219
'02 GMC Sonoma ZQ8 4.3W 4l60e
Follow me on Instagram: @mightycarlitos
SonomaGT is offline
post #3 of 13 Old 12-04-2010, 04:00 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
Weak coils could cause it also. Never had it on my 2.2's but had a 4.3 I had put an Accel coil in it and when it got below a certain temp it wouldn't start. If it was above freezing it was fine.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #4 of 13 Old 12-12-2010, 10:31 PM Thread Starter
omgs10's Avatar
I fixed my vacuum leak but still having problems in the cold. Idk what to do?
omgs10 is offline
post #5 of 13 Old 12-12-2010, 11:52 PM
Zeeke98's Avatar
Have you checked your coils?
Wade
Zeeke98 is offline
post #6 of 13 Old 12-14-2010, 12:42 PM
King Tut
JLiRD808's Avatar
User is: JLiRD808 is offline
Update on this? My 98 2.2 wont start either...just had the crank sensor replaced and it seemed to work fine for a couple days but today was REALLY cold and the problem persists!
[IMG]<a href=http://www.myspace.com/jasonleez target=_blank>http://i36.photobucket.com/albums/e1/Jlird808/0619001549-1-1-1-1.jpg</a>[/IMG]
JLiRD808 is offline
post #7 of 13 Old 12-08-2011, 09:53 AM
King Tut
JLiRD808's Avatar
Wow...almost 1 year later to the date...and my problem persists.
Just got a brand new battery too.
Any ideas?
THX!
JLiRD808 is offline
post #8 of 13 Old 12-08-2011, 07:19 PM
Zeeke98's Avatar
Did you ever check your coils as I suggested a year ago?
Wade
Zeeke98 is offline
post #9 of 13 Old 12-12-2011, 12:39 PM
User is: dustincp is offline
someone told me these trucks have a cold start sensor located by the throttle position sensor that could b causing this problem..........mine is a 4.3 auto, 2001
dustincp is offline
post #10 of 13 Old 12-14-2011, 01:03 AM
Vig Pimpin
viggy58's Avatar
User is: viggy58 is offline
dist cap allowing moisture in? something is either killing spark, or you have a weak fuel pump that can't pull enough pressure when it's cold.
try starting it with a shot of carb cleaner. if it starts, you have a fuel delivery problem
pull the plugs and see if they're covered with gas when the no-start occurs. if they're wet, you have no spark.
___________________________________________
2001 Blazer
4.3L 5 speed manual trans, 2wd
180k miles
ALL STOCK!
Profile Baja amp, 100w x4
Sony Xplod 1000w x1
Alpine type R 12in. sub
viggy58 is offline
post #11 of 13 Old 12-17-2014, 08:56 PM
User is: bigglac66 is offline
Hey I wanted to add to this cause my s10 is having the same problems. I bought mine off my sgt, which he brought it from California. It has never seen cold weather, but the coils in it are brand new, spark plugs are new and wires are new. I still have the California emissions on it and my Sgt chopped the exhaust right at the passenger rear tire. Any ideas on what it could be???
post #12 of 13 Old 12-17-2014, 09:08 PM
4-Banger
97Spirit's Avatar
User is: 97Spirit is offline
Try some dry gas. You could have some freezing water in the fuel line or injectors
Originally Posted by GypsyParker View Post
Actually...when you do a chop like that...the cab of the truck understands what is going on...and braces itself for what is about to happen.
1997 Chevrolet S10 LS
  • 2.2l
  • 5-Speed
  • 220k+ miles
97Spirit is offline
post #13 of 13 Old 02-04-2016, 08:55 AM
User is: jdkid93 is offline
I just bought a 98 2.2 5 speed and it's doing the same thing every sensor coil, coil control module have been replaced re ran grounds done the wiggle wires test new computer, everything I can think of I've thrown at this thing and when it's below around 40 outside it won't start, it's a spark issue getting fuel to the cylinders
jdkid93 is offline
