98 s10 5speed shifter knob thread size. - S-10 Forum
post #1 of 6 Old 12-10-2010, 03:25 AM Thread Starter
fumplet's Avatar
User is: fumplet is offline
Hi, Im buying a custom shifter knob for a friend that has a 98 s10 5speed 2.2L motor. Problem is, I dont know if the stick is threaded or not. If it is, does anyone know the thread size?
1986 s10 put back together with new bone yard frame, cab, shitcanned 700r4.............5 speed put back in, msd box and coil, custom k and n filter, flowing exaust, 4.3L throttle bodyw/2.8L injectors, bored intake, e-fan,AFPR
fumplet is offline
post #2 of 6 Old 12-10-2010, 03:49 AM
Eric
Deja_Vu969's Avatar
User is: Deja_Vu969 is offline
Re: 98 s10 5speed shifter knob thread size.
To my knowledge there is no separate thread to swap between knobs. Could always break off the current one, I've seen it done on here (Good smack on the ground?) and then epoxy/glue on the new one?...
post #3 of 6 Old 12-10-2010, 04:06 AM Thread Starter
fumplet's Avatar
yeah thats the problem aint my truck. Not sure if he would go for that. What was wrong with a perfectly good threaded design??? Ive seen the posts brought by the search on this topic but wanted to be sure. Some of the posts, they werent sure of the switch over.
fumplet is offline
post #4 of 6 Old 12-10-2010, 11:30 PM
tj.hotrod's Avatar
User is: tj.hotrod is offline
Use the shift lever from a 94 or older, it is taller but it is threaded. I think it is 12mm. I have one from a 87 Blaizer in my 98 and I adapted a 13 speed semi. knob on mine.
post #5 of 6 Old 12-11-2010, 12:41 AM
Mikz86TA's Avatar
User is: Mikz86TA is offline
The 98 up 5sp shift handle and know are 1pc. If you pull the rubber boot down ,there is a lock nut to loosen and then unscrew the entire shift handle/knob,
Billet specialties sells a billet replacement handle that provides a threaded end to attach a knob of ur choice...or use the one they sell.
There is also some company on ebay and a coupe other billet companies making them as well
Hope this helps
2003 S-10 ZQ8 - 262/M5 1986 Pontiac Trans Am - 355/A4
The S10 Project : http://www.s10planet.com/forum/showthread.php?t=15987
The Trans Am Project : http://www.s10planet.com/forum/showthread.php?t=15435
Mikz86TA is offline
post #6 of 6 Old 04-05-2011, 12:10 AM
User is: rockwell is offline
98 s10 5speed shifter knob thread size.-rockwell.jpg cut the old one off then honed the 10 speed shifter out a little then heated the plastic and pushed it on by hand now its nice and tight
rockwell is offline
