98 2.2 s10 clutch fluid leak? - S-10 Forum
post #1 of 6 Old 02-11-2011, 02:41 PM Thread Starter
omgs10's Avatar
User is: omgs10 is offline
Hey guys i have a 98 s10 2.2, I have to fill up my clutch fluid container like every 3 days or so? I didn't know if that was normal or not? I also noticed that it never goes completely empty and that it gets worse when it's cold outside? Any ideas or help would be appreciated.
| Red 98 S10 | Corvette C6 Rims| 3/4 drop |
omgs10 is offline
post #2 of 6 Old 02-11-2011, 03:53 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
Re: 98 2.2 s10 clutch fluid leak?
Either the master or slave cylinder. Look for the leak.
Teamsters Local 1150
SH-60B is offline
post #3 of 6 Old 02-12-2011, 12:48 PM Thread Starter
omgs10's Avatar
where should i look, sorry i don't know much about clutches. Also, yesterday it was above freezing and my clutch was strong and never got low on fluid. is there any way my fluid is freezing?
omgs10 is offline
post #4 of 6 Old 02-16-2011, 01:44 AM
Typoe99's Avatar
User is: Typoe99 is offline
unless it has a ton of water in it then no. If your using the right stuff which is just DOT 3 brake fluid for the 98 it is a petroleum based product
1998 S10 Pickup
2.2L 5-Speed Manual
Typoe99 is offline
post #5 of 6 Old 02-17-2011, 01:36 AM
User is: rockwell is offline
Probably the slave
rockwell is offline
post #6 of 6 Old 02-19-2011, 12:14 AM
User is: 1994ricers-10 is offline
look down at the trans where the hydraulic lines attach to the trans follow all the lines and everything, look for leaks.
