97 s10 2.2 starter replacement - S-10 Forum
post #1 of 7 Old 07-14-2010, 03:42 AM Thread Starter
User is: citadel2014 is offline
I'm currently in the process of replacing the starter on my 1997 2.2L s10. I have removed the starter but I am having problems getting the new one in. I have removed everything in the way, the back brace, support bracket, exhaust, and I still cannot manage to find the room to properly place the new starter back in. The old starter took at least an hour to find the right angle to push it back and pull it out, after a little bit of prying. I have tried jacking up the engine and that still didn't give me the room I need. I must be missing something...there is no way it can be this difficult to replace the starter on one of these things. what could I be missing?
post #2 of 7 Old 07-14-2010, 12:16 PM
nicknoma's Avatar
User is: nicknoma is offline
Re: 97 s10 2.2 starter replacement
with out seeing it telling you the angle to get in in there is hard but most of the problem is with the exhaust and the brace that runs from the motor to the bottom of the trans then try backing the starter into the motor side and then pushing it into the hole if that makes sense
nicknoma is offline
post #3 of 7 Old 07-14-2010, 05:27 PM Thread Starter
Alright I got it in. I took a grinder to the end that goes into the transmission and grinded a bit of it off..maybe 2-3mm. Probably not supposed to do that but that was the only way it was going in. I got it wedged up in there to where i couldn't push it any farther but it wont fall back down, then i took a sledge hammer and hit it and it popped right into place. And I hate chevy for designing such garbage. They should have gave way more room for a starter, or made the starter smaller.
post #4 of 7 Old 07-15-2010, 11:50 PM
Works too much!
laydout97's Avatar
User is: laydout97 is offline
It is just as bad on a 4.3 but glad you got it in.
92 4.3/700r4 315k- ole red
2011 altima- daily ride
post #5 of 7 Old 11-05-2011, 12:45 AM
zeek624@yahoo.com's Avatar
User is: zeek624@yahoo.com is offline
hey guys i need a list of all starters that will fit a 2000 2.2 5 speed if anyone could help i would thank them a lot .....looking for list cause i cant get a new one due to i was put out of work so if u could send or post a link thanks
post #6 of 7 Old 11-05-2011, 12:46 AM
this truck will be for sale if no job is gotten in a week
post #7 of 7 Old 11-05-2011, 03:57 AM
It's mostly BS
rimara's Avatar
User is: rimara is offline
Go to Rock Auto. Find your Delco starter. Click on the pn and it will list all the cars it's used on.
2001 S10 2.2 5sp ext cab
Don't hit and run...let us know how you fixed it!
rimara is offline
