96 s10 won't start when hot (pcm?) - S-10 Forum
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 09-10-2010, 09:31 PM   #1
96 4.3 vortec starts ok cold and will run all day
but if engine is turned off it will not start back up till pcm cools down
pcm is hot to touch' no fuel pump prime or ignition.
does replacing pcm sound right or am i missing something
Old 09-10-2010, 09:34 PM   #2
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
Re: 96 s10 won't start when hot (pcm?)
ignition module would sound more like it...
autozone can test it for free, drive the truck to them and get it nice and hot, remove it quickly and bring it in...
its mounted to your coil.
allthough the fuel pump not turning on wouldnt be related. are you 100% sure its not coming on either? or 99%?
Old 09-11-2010, 06:08 AM   #3
i saw what you did there!
fast68chevy's Avatar
ICM or CS
one or the other
is crapping out due to heat
it happens pretty often
everyone always automatically think its the computer
but its not
9 times out of 10 its failed sensor or ICM or FP
Old 09-12-2010, 09:44 PM   #4
100% on fuel pump not coming on and when I cool the pcm truck starts right up
Old 09-15-2010, 09:25 PM   #5
If it won't even turn over, then the starter solenoid is too hot. It is very close to the exhaust. Installing a heat shield over it will help.
Old 09-15-2010, 09:27 PM   #6
NotaDime's Avatar
wow, sounds like it may well be the pcm then...
try to get ahold of a spare one to try it out
