95 Sonoma 2.2 Release Bearing help - S-10 Forum
post #1 of 5 Old 10-10-2013, 08:52 PM Thread Starter
User is: rstoltenberg1 is offline
Hello all!
I've replaced the clutch in my Snonoma. It has the T-5. When I removed the Tranny, I seperated it from the bellhousing and then removed the bell. In the process I Didn't see how the Release ( Throwout ) Bearing was installed. Now Im ready to re assemble and Im stuck. Does the actual bearing (wider part that spins) Go against the Feeler's on the pressure plate or? Ive included two PIcture's. Which is correct? thank you!
1.
2.
post #2 of 5 Old 10-10-2013, 08:55 PM
artsob77's Avatar
User is: artsob77 is offline
Re: 95 Sonoma 2.2 Release Bearing help
Pic #1 is right, the bearing spins with the diaphragm on the pressure plate.
95 S-10, Was ready for the scrap heap......but I brought it back
artsob77 is offline
post #3 of 5 Old 10-10-2013, 09:05 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
Yup. You should grease the ball that the clutch fork pivots on while you're in there too.
TelAmeriCorp
post #4 of 5 Old 10-10-2013, 09:07 PM
artsob77's Avatar
^ Good catch ^ Not thinking, it's been a long day.
artsob77 is offline
post #5 of 5 Old 10-10-2013, 09:08 PM Thread Starter
Sweet! Thank you! Yeah Ill grease it. It also has a grease fitting on the outside of the bellhousing that I didnt know about til I dropped it.
