94 s10 2.2 5 speed speedometer questions - S-10 Forum
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 10-17-2012, 01:40 PM   #1
Ok I have a 94 s10 2.2 5 speed and Im building a gauge cluster for it.
My questions is what type of speed sensor or speed sender does it have factory? Its a VDO Speedometer and I have no idea if i can just use my factory sender since im still using an electronic sender. Heres the wiring diagrams for it. http://static.summitracing.com/globa...vdo-437353.pdf
All replies, tips, advice, etc etc will be greatly appreciated.
Thanks again,
Derek
Old 10-17-2012, 02:34 PM   #2
Electrical Mod
deathphoenix99's Avatar
Re: 94 s10 2.2 5 speed speedometer questions
should be able to just wire it into the stock wiring at the dash and the stock speedometer uses 4,000 pulses per mile if I'm not mistaken.
Old 10-17-2012, 02:59 PM   #3
thanks man...ummmm which wires lmfao can i just splice into the ones on the transmission?
Old 10-17-2012, 03:42 PM   #4
Electrical Mod
No, you will have to connect it either at the cluster's wiring or at the DRAC directly, but you might as well just use the stock connector for the wires.
Old 10-18-2012, 09:59 AM   #5
what the hell is a DRAC ya lost me on that
Old 10-18-2012, 10:04 AM   #6
Electrical Mod
http://www.tbichips.com/drac/
http://614streets.com/drac.html
Old 10-18-2012, 01:08 PM   #7
ok so how would i tap into the drac wiring with the speedometer?
Old 10-18-2012, 01:18 PM   #8
Electrical Mod
Just use the stock wiring that's already at the connector for the stock cluster. It's all right there.
Old 10-18-2012, 01:18 PM   #9
or a wiring diagram for the cluster harness?
Old 10-18-2012, 01:19 PM   #10
ok i guess i have to look for a wiring diagram for the cluster plug loolll
Old 10-18-2012, 01:38 PM   #11
Electrical Mod
Click the link in my sig.
Old 10-18-2012, 02:06 PM   #12
Ok...so lemme see if i get the right or not LOL I hate wiring and diagrams and all that shit LOL Anyway, so according to this diagram https://docs.google.com/file/d/0B9SE...TEw/edit?pli=1 it will be a light blue/black wire that comes off the vehicle speed sensor buffer and it goes to the VSS. Is that the wire I would need to wire it to? I know the speedometer i want can be wired 3 different ways, half effect which is 3 wires, an inductive sender which is 2 wires, and the electronic control box which is one wire...so in order to make the aftermarket speedometer work, just tap into that wire? Im sorry for bugging you so much man Its just I HATE WIRING and the diagrams are sometimes complicated for me to read LOL
Old 10-21-2012, 11:43 AM   #13
is that correct?
Old 11-07-2012, 11:14 AM   #14
Old 11-07-2012, 11:25 AM   #15
Electrical Mod
That is correct, light blue/black wire.
Old 11-11-2012, 02:46 PM   #16
Thanks man...I appreciate all the help you have given me.
