91 S10 Fuel Pump Relay location? - S-10 Forum
post #1 of 10 Old 03-20-2012, 05:32 PM Thread Starter
User is: fotyfoe is offline
1991 S10 2WD P/U V6 4.3 - Facing the the front of the vehicle, there are two relays mounted next to each other on the firewall driver's side. Can any one tell me which is the fuel pump relay? Right or left side? And what is the other one?
fotyfoe is offline
post #2 of 10 Old 03-20-2012, 06:36 PM
lemasterj22's Avatar
User is: lemasterj22 is offline
Re: 91 S10 Fuel Pump Relay location?
fuel pump relay is on the right the other relay is ac compressor relay.
96 sonoma sls, CAI, E-fan,5/6 drop, flowmaster 40 series
post #3 of 10 Old 03-20-2012, 06:37 PM Thread Starter
Oops I meant V6 2.8
fotyfoe is offline
post #4 of 10 Old 03-20-2012, 06:40 PM Thread Starter
Thanks lemasterj22. Are they the same relay devices and swappable?
fotyfoe is offline
post #5 of 10 Old 03-20-2012, 06:46 PM
relays are in a different location for the 2.8. they are on the driver side fender well. if it is the 2.8 the fuel pump relay will be the closest to the brake booster. not sure if they are the same relays. best way to figure that out is to compare the numbers on top of the relays. if they are the same then you can swap them out. if you cant find any numbers on them then just look up a fuel pump relay for this truck and look up a ac relay for it and compare the numbers that way.
post #6 of 10 Old 03-20-2012, 06:49 PM
2.8 diagram
http://www.shopkey5.com/mric/common/...&COURTESYTAG=&
3.4 diagram
post #7 of 10 Old 03-21-2012, 11:53 AM Thread Starter
Thank you again lemasterj22. Unfortunately I cannot get your shopkey links to display any graphic. But thank you for your tip about the relays.
fotyfoe is offline
post #8 of 10 Old 03-21-2012, 09:00 PM
your welcome.
post #9 of 10 Old 03-22-2012, 09:20 PM
Bills Dad's Avatar
User is: Bills Dad is offline
If the fuel pump is not working, check the harness for corroded wires too.
1997 S10 reg.cab/base, 4wd. L35
1997 Gmc Sonoma sl 4 banger
post #10 of 10 Old 03-23-2012, 11:27 AM Thread Starter
Anybody know how to check the voltage at the relay? Not sure which pins to check.
fotyfoe is offline
