3rd Door Won't Open... - S-10 Forum
post #1 of 14 Old 09-30-2007, 01:04 AM Thread Starter
NTL1991's Avatar
User is: NTL1991 is offline
So I can't open my 3rd door. The handle is broken and I have a new one but it seems the the problem lies deeper than the broken handle. When I pull down on the top latch "pole", the top of the 3rd door pops open. When I pull up on the bottom latch "pole" (with extreme force, mind you) it doesn't budge...
What could be wrong? Are there any tricks for opening it another way? Would I be able to assess the problem by removing the 3rd door interior door panel?
Nick
NTL1991 is offline
post #2 of 14 Old 09-30-2007, 06:14 PM
the_s10er's Avatar
User is: the_s10er is offline
Re: 3rd Door Won't Open...
Did you already install the new handle?
I know this is a common problem with the 3rd doors, but usually it's just the handle.
Have you tried some type of lube on the latches like wd40 or something? Maybe they are just really gunked up.
'87 Camaro 305/Auto-dd
'05 Evo VIII
'00 S-10 4.3/Auto-sold
'01 S-10 4.3/Manual-sold (but missed)
Looking for another...
post #3 of 14 Old 09-30-2007, 06:31 PM
eric00's Avatar
User is: eric00 is offline
take off inside panel and remove the inside lower latch, see if cleaning a wd40 will break it free to function, if not get one from the dealer. (thats what ive done with many trucks at work)
eric00 is offline
post #4 of 14 Old 09-30-2007, 11:44 PM Thread Starter
NTL1991's Avatar
Thanks, I need to get a Torx big enough to get the screws off first before I can take the panel off because the seat belt screws are there...
By the way, the old broken handle was already disconnected from the poles when I removed it, and I just tried to pull/push on them with some pliers and the top unlatched, but the bottom wouldn't, even under extreme force... So right now, the handle is not on.
Nick
NTL1991 is offline
post #5 of 14 Old 10-01-2007, 02:02 AM
SlammedSonoma96
SlammedSonoma96's Avatar
User is: SlammedSonoma96 is offline
Nick
Try to push in at the middle or bottom of the door as you pull the latch rod. That should get the latch to clear enough to open.
96 GMC Sonoma: Bagged SD 5 link, Slam RE7 front RE8 rear. 20" ADR Propulsion Wheels, Fully shaved,
AVS cowl induction hood, Blazer front end swap, SS Bumper, being prepped for paint.
Soon to have a 5.3/4L60E
post #6 of 14 Old 10-01-2007, 04:04 PM
bah humbug
User is: nigel is offline
yeah, my bottom latch was really starting to stick, so I gave it a good coat of wd40 and it's working like a charm now.
So, good luck getting yours working.
Nigel
no more s-10 for me very sad times ahead...
nigel is offline
post #7 of 14 Old 10-01-2007, 11:42 PM Thread Starter
NTL1991's Avatar
Thanks! I will try tomorrow when I install the power door lock kit I bought for it. Does anyone happen to have any tips for removing the door panels?
Thanks,
Nick
NTL1991 is offline
post #8 of 14 Old 10-09-2007, 10:20 AM
flamedx10's Avatar
User is: flamedx10 is offline
i broke 2 3rd door handles, the top always pops easy by pulling on the pole. the bottom is stuck like hell, i kicked it once and found a screwdriver wedged int he bottom of the door... but its still stuck.
post #9 of 14 Old 12-20-2007, 05:44 PM
CHEVYFREAK1822003's Avatar
User is: CHEVYFREAK1822003 is offline
Sorry for bring back a dead thread, but i just bought a truck with this same problem. Did the wd40 work?
Looking around i also found this:
http://townhall-talk.edmunds.com/Web...%20door%20hard
post #10 of 14 Old 12-20-2007, 09:11 PM
Ok getting the door panel off would help,
anyone know how to pull the third door door panel?
I found plenty of threads on getting the regular door panels off but nothing on the third door
post #11 of 14 Old 12-23-2007, 12:10 PM
User is: 96pickup is offline
I haven't tried it yet but I plan on buying an aluminum handle replacement from these guys http://www.thirddoorhandle.com/installation/index.html $12 on ebay. Their instructions don't involve removing the door panel either. Only if you need to get inside to lube the bottom latch. I'll let you know how it goes.
96pickup is offline
post #12 of 14 Old 12-23-2007, 10:23 PM
Yeah i sprayed the botom latch with wd40 and nothing its still stuck, the top latch is broken so i got to figure a way to get it open with out twisting the door. I dont know its freezing here so im not going to mess with till it warms up a bit hopfully then ill be able to free the bottom latch.
1998 s10 extended cab 4x4 4.3l
"If you dont live on the edge your taking up too much space"
post #13 of 14 Old 12-24-2007, 01:14 PM
chrome bumpers suck!!
mels98s10's Avatar
User is: mels98s10 is offline
i bought that handle and its awesome i never had problems with my 3rd door after i bought that....its definately worth it!
post #14 of 14 Old 12-24-2007, 01:15 PM
LSxtremin FoLyfe
02dime's Avatar
User is: 02dime is offline
the aluminum handle was the best thing i put on mine
1999 4dr 2wd Jimmy ,3" DJM drop coils/blocks & ND2 shocks, 2nd gen ZQ8s, LS swap coming soon
02dime is offline
