2003 S-10 Crew Cab
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > S10 / Sonoma
Old 08-18-2008, 03:06 AM   #1
pincky
2003 S-10 Crew Cab
my truck did not come with factory fog lights in the turn signal corners
is there a way i can add them if i were to buy corners with fog lights
and buy a factory fog light switch?
Old 08-18-2008, 08:20 AM   #2
94 2.2, feel the power?
deathphoenix99 is on a distinguished road
Re: 2003 S-10 Crew Cab
When it comes to lighting, you can always add fog lights etc. It just may take some wiring or work to get it done. I don't know what for lights you are talking about though? Do you mean running lights? But either way, you can manually wire in any type of lights, you just need a relay, the switch, wires, and lights.
Old 08-18-2008, 06:02 PM   #3
shifting gears
johnmyster is on a distinguished road
My truck actually has the relay in the box for the fog lights. Further, it actually has a wiring plug behind the headlight switch for the foglight switch. I assume that all the wiring to the relay is present, and perhaps beyond. I've added a factory foglight switch (for other reasons) but toyed with the idea of using it.
Old 08-18-2008, 08:22 PM   #4
I would assume that everything is there then. just check for continuity between the relay and the plug. I know my 94 truck came with the harness for cruise control, just never had the module or switches to engage it. Hopefully its an easy add-on for you.
Page generated in 0.08465 seconds with 11 queries
